Old 05-26-2005, 09:07 AM   #1
jaywrx
Member#: 16254
'02 WRX WRB
'07 Tribeca OBP
Default 124k ej22t,g,z,abcdef......whatever turbo legacy block
I am looking at doing the turbo Legacy block swap into my WRX soon and have found a used block for a decent price. It has 124k miles on it and I was wondering, as a general rule of thumb, what I would need to replace. I will get better pistons at least, but I don't know if the rest of the internals should be replaced. Should the rods and crank and bearings be ok after 124k miles?
thanks
jason
jaywrx is offline   Reply With Quote
Old 05-28-2005, 12:57 AM   #2
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
All seals, gaskets, rings and bearings have to be replaced! Its not a rebuild without it.
The only thing thats great about the EJ22T is the bare block. The rest of the internals can hold their own, but I'd replace just about everything on a 124k mile motor. The crank should be fine. Take all your measurements after its been torn down and see if they're in spec. You could also go with a EJ25 (Phase I, IIRC?) crank and end up with a 2.4l motor. You also need to take measurements of the cylinders to see if they need to be bored.
And whats a decent price?
eastcoastbumps is offline   Reply With Quote
Old 05-28-2005, 05:36 AM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
new oil pump
Drac9 is offline   Reply With Quote
Old 05-31-2005, 12:15 PM   #4
jaywrx
Member#: 16254
'02 WRX WRB
'07 Tribeca OBP
eastcoastbumps, I thought I found one for $400 shipped but that turned out to be a non-turbo block. The 124k one is $450, not including shipping. Do you know of a better/cheaper source?
Old 05-31-2005, 01:24 PM   #5
Boxologist
Member#: 21118
thats a good price. the ej22t block and its internals are excellent, but they give a very low compression ratio.
Boxologist is offline   Reply With Quote
Old 05-31-2005, 01:40 PM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Yup, has to be a phase I, because the phase IIs have the thrust bearing in a different location.
$450 is very reasonable.
jamesfacts is offline   Reply With Quote
Old 05-31-2005, 05:29 PM   #7
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Impreza GC8 they are
strong motors.....mine had 212K on the odometer when I took it out of a junkyard car, it's heading for 300k and I've never opened the motor (that happens this winter).
But if your just using the block replace all the seals/gaskets and inspect the rest for wear.
Scoobyslack1 is offline   Reply With Quote
Old 05-31-2005, 08:35 PM   #8
sjl1614
Member#: 56791
06 OBS
I have a 2.2 turbo block i am trying to get rid of....excellent shape!!
sjl1614 is offline   Reply With Quote
Old 05-31-2005, 09:47 PM   #9
jaywrx
Member#: 16254
'02 WRX WRB
'07 Tribeca OBP
sjl1614, What condition? How much are you asking for?
Old 05-31-2005, 11:12 PM   #10
Millencolin!
Member#: 88219
1992 Legacy SS
EJ22t + 16g = :)
I undertsand that the 2.2L block is strong but why swap it into a WRX, is the displacement loss worth it?
Millencolin! is offline   Reply With Quote
Old 06-01-2005, 02:32 AM   #11
Rickyh
Member#: 40453
the wrx is a 2.0. the 2.2 is bigger.
Rickyh is offline   Reply With Quote
Old 06-01-2005, 09:31 AM   #12
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
i thought that the lower the compression the more boost you could run. Correct me if i am wrong but a EJ22T runs 8.0:1 so wouldnt that be better?
Kawikid20o2 is offline   Reply With Quote
Old 06-01-2005, 09:41 AM   #13
kheff46
Member#: 66739
2002 WRX wagon
lower CR helps with higher boost levels(prevents detonation). especially if your running crappy gas! the sti has higher CR than wrx does. i'm running high(for a turbo) CR in my OBS-t. i run good gas 90+ and sometimes octane booster for crappy fill ups. i've had no prob. but turn up the boost and say bye to my motor. keep the ratio low and live happily!
ej22t block is what is good about it nothing else. i'd still rather have an ej257 short block swap. more $$ but they still produce them new. if you get ej22t it's probably still stronger than stock wrx in the long run. so you're going in the right direction high, HP and durability!
kheff46 is offline   Reply With Quote
EJ22t Turbo legacy 2.2 Engine or long block or short up for grabs serious Engine/Power/Exhaust 19 09-04-2009 01:31 PM
WTB: EJ22t Block / Turbo Legacy jkutzsch Private 'Wanted' Classifieds 2 06-28-2009 06:03 PM
FS:CT.Moving Sale!! 255/257 Turbo Legacy Block, $450 OBO Not All There Tri-State Area Forum 4 06-17-2007 08:23 AM
Turbo Legacy Block FS on Ebay blackbart Private 'For Sale' Classifieds 0 10-24-2005 06:48 PM
whats the difference in the 1990-94 turbo legacy block to the 22b block STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-08-2002 10:52 AM
