Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 05-26-2005, 11:02 AM   #1
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
Question Help me buy my birthday present
Decision: I ordered a Cusco 22mm rear swaybar, Whiteline rear endlinks and a Kartboy shifter and bushing kit. Should be pretty good bang for my $.
Hey Guys,
I think I'm going to get gauges (boost, EGT, Oil Temp) for my b-day. The problem is that I was all ready to order suspension, but it just isn't in the budget.
Is Autometer OK? If so what level? What's the best A-pillar 3-gauge pod? etc?
Thanks.
-J
Jitenshakun is offline   Reply With Quote
Old 05-26-2005, 01:36 PM   #2
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
FWIW
I have a little toy from TurboXS that I picked up while in Australia you may want to look at and wait for its release. I'm at SOC for lunch and again around 4 pm.
IMHO
Gauges required in order for the track.
Knock detection
EGT-high quality, fast reading
Oil temp
Water temp
For tuning with only a few mods
Boost
EGT
A/F
Suspension is probability your cheapest. Lots of improvement with just these 3 items. No roads to use it on thou in Calgary unless at Race City.
Whiteline 22mm front swaybar
Whiteline 24mm adjustable rear
ALK
Wombat North is offline   Reply With Quote
Old 05-26-2005, 01:44 PM   #3
Jitenshakun
Member#: 61586
2005 STi
I'll be at SOC around 1:00~1:15. If you're still around I wouldn't mind seeing your "gadget".
I'd like to do pinks and hats before I do sway bars.
-J
Old 05-26-2005, 02:18 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
http://ecutek.com/products/dashdisplay/
I'd get this instead of guages. It is clean, fits in stock location, has dozens of possible inputs, is WAY cheaper than buying and installing guages, uses ECU info and can even display when your engine pulls a code.
If you want to see one in an STi give me your e-mail address and I will send you a picture.
tora is online now   Reply With Quote
Old 05-26-2005, 02:38 PM   #5
Jitenshakun
Member#: 61586
2005 STi
Cool, but at 425 pounds I don't think its cheaper that Autometer gauges. Maybe cheaper that a DEFI D-link set-up (maybe).
-J
Old 05-26-2005, 02:49 PM   #6
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
Hey Jitenshakun, my brother-in-law has that in his WRX. Really nice, his is black. He had gauges before and dumped them for this instead... really clean. He installed it in instead of his clock in his '03. Nice. I'll ask him where he got it and how much he paid for it, if you want. There must be a better price than 425 pounds somewhere..
Okeo is offline   Reply With Quote
Old 05-26-2005, 03:21 PM   #7
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
Defi's! Only way to go for gauges.
Zuffy is offline   Reply With Quote
Old 05-26-2005, 04:02 PM   #8
Jitenshakun
Member#: 61586
2005 STi
Okeo:
That'd be cool. I'm open to options, as long as they aren't crazy expensive.
-J
Old 05-26-2005, 05:50 PM   #9
Okeo
Member#: 21254
2002 Impreza TS
Blue Ridge Pearl
J:
Turns out the b-i-l does not have the Ecutek, but a model made by a company named Psi3, also based in the UK. Check it out, seems to be a bit cheaper, and you'll also see it was an easy mistake to make..
http://www.psi3.co.uk/
Hope that helps.
Old 05-26-2005, 06:01 PM   #10
tora
Member#: 5851
09 Forester XT
+ NA Miata
We sell the delta in dash display for $1025. Yes it is expensive and my comparison was referring to getting something that had similar readings and accuracy which you will not be able to find. You will also not be able to find all the features that this display unit has. You can get mechanical guages for cheap but you are getting piss-poor readings. If you want accuracy and MANY inputs this is the way to go.
Old 05-26-2005, 06:29 PM   #11
Jitenshakun
Member#: 61586
2005 STi
Hmm. I had thought that mechanical were the way to go. Are electonic gauges better?
-J
Old 05-26-2005, 08:18 PM   #12
tcam33
Member#: 54515
05 WRX STi
WR Blue
I have the Ecutek dash display, I love it. Lachute Subaru has them so does Rocket Rally(found out after I bought mine). Lachute is a bit cheaper, but it took over a month to get. Julien is the guy you want to talk to there. Taxes with shipping included was $975 ish not too bad considering what it does
tcam33 is offline   Reply With Quote
Old 05-26-2005, 08:44 PM   #13
Zuffy
Member#: 35268
added PDX goodness
The replay, peak hold, and warning setpoints function of the Defi's are worth it.
Old 05-27-2005, 01:20 PM   #14
B WReX
Member#: 50747
2004 WRX
I have autometer A/F z-series, Boost and Oil press in an a-pillar setup. I am happy with them. They were all I could afford, but would probably go Defi if I had more $.
For my needs autometer is fine, but I am not a tuner. I am told the quality/accuracy isn't as good as others like Defi. When I compare my boost readings to my Accessport the Autometer consistently reads ~0.5 psi less, but it is zeroed at -0.5 psi (I'm not sure why. higher altitude => lower press than it was calibrated at?). Also, the A/F doesn't give a digital number, it has red, yellow and green leds to indicate lean, stoich and rich. It's a cool look, but many tuners seem to frown on it!
tcamm33s Ecutek dash display is awesome, too!! Very clean looking...and probably the best way to go....
...but I like look of gauges.
Brian
B WReX is offline   Reply With Quote
Old 05-27-2005, 09:38 PM   #15
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Just buy DeltaDash and one of those shmancy in car LCDs with an in car computer. If you get bored looking at your gauges, you can always watch Blade Runner while the cruise is on...
fragment is offline   Reply With Quote
Help Me Celebrate My Birthday! xxthat girlxx New England Impreza Club Forum -- NESIC 206 04-01-2009 11:06 PM
My birthday present to me is..... ein86 South East Region Forum 6 12-21-2004 01:55 PM
Help pick my Birthday Presents! 2k2 Off-Topic 9 10-15-2004 02:56 AM
Girlfriend gave me the best birthday present EVER!!! StealthWagon Off-Topic 11 11-14-2003 11:02 AM
('93-'01) Birthday coming, car just paid off - Help me pick out a present :) StormCrow Impreza Forum 7 05-05-2003 11:30 PM
