Old 05-26-2005, 12:00 PM   #1
keirnna
Member#: 50167
1996 Subaru STI RA
Default EJ20 engine differences
I did a seach and I can't find what I am looking for. Your assitance would be greatly appriciated. I am wondering what the difference between all of the STI EJ series engines are. I want to do a swap, and I want a closed deck EJ20, but it seems they are very rare. So I am trying to find what the difference is between the EJ20k, EJ20g, EJ207, etc...
keirnna is offline   Reply With Quote
Old 05-26-2005, 12:12 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
search in the conversions forum. It is all there. But only early STi's through '95 will have a closed deck...
Old 05-26-2005, 12:30 PM   #3
keirnna
Member#: 50167
1996 Subaru STI RA
According to ravensblade the type RA had a closed deck after 95. I did a ton of searching. I'll check out the conversions forum, but if you have a link hook me up.
Old 05-26-2005, 04:43 PM   #4
napphappy
Member#: 56170
95 Impreza L
Ugly
Here is a link
http://sti.catherineandken.com/
Hope it helps
napphappy is offline   Reply With Quote
Old 05-26-2005, 05:24 PM   #5
keirnna
Member#: 50167
1996 Subaru STI RA
Thanks.
Old 05-26-2005, 05:32 PM   #6
keirnna
Member#: 50167
1996 Subaru STI RA
This is some decent information, but it seems that Subaru does it's normal thing to sell 5,000 variations in the same shell:
http://www.catherineandken.co.uk/sti/engine.html
Old 05-29-2005, 04:10 AM   #7
Impreza01
Member#: 152
2002 Impreza WRX
the chart is incorrect; for the sti version 5 and 6, the engine code is a ej207, which is a semi-closed block
Impreza01 is offline   Reply With Quote
Old 05-29-2005, 10:12 AM   #8
keirnna
Member#: 50167
1996 Subaru STI RA
Really, so do you have a link for the with that information? I am just trying to find which swap I want to get.
Old 06-02-2005, 11:54 AM   #9
IslandSTI
Member#: 87534
1997 Impreza WRX
Default Engine types
Here is a site with some info for JDM engines if that helps.
grahamberry2.co.jp/impreza_gc8/
IslandSTI is offline   Reply With Quote
Old 06-02-2005, 01:03 PM   #10
sub666
Member#: 38052
v5 and v6 aren open deck
sub666 is offline   Reply With Quote
Old 06-02-2005, 05:33 PM   #11
keirnna
Member#: 50167
1996 Subaru STI RA
Thanks, the EJ207 (V7 STi block) is semi closed right?
Old 06-02-2005, 11:18 PM   #12
EXPLICIT
Member#: 15055
2006 S204
CGM
correct
EXPLICIT is offline   Reply With Quote
Old 06-02-2005, 11:24 PM   #13
keirnna
Member#: 50167
1996 Subaru STI RA
Okay thanks. So the EJ207 has been used in V6+ STi's according to that article right?
Old 06-03-2005, 12:29 AM   #14
prescottsti
Member#: 84902
04 Chevy Silverado
Duramax Diesel 500Hp
I thought 22b's were closed deck turbo legacy blocks
prescottsti is offline   Reply With Quote
Old 06-03-2005, 12:59 AM   #15
keirnna
Member#: 50167
1996 Subaru STI RA
They are not turbo legacy blocks. Both the turbo legacy and 22b have 2.2 litre closed deck blocks; however the 22b doesn't have oil squirters and the turbo legacy block does. That is the only difference as far as I know. I think bore and stroke are the same.
Old 06-03-2005, 03:18 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
The Ej20G found in the 22B is also a phase II engine with the thrust bearing end mounted and not centered like the EJ22T. Has forged pistons as well. The Ej22T has moly coated cast pistons...
Regardless, closed deck vs open deck vs semiclosed deck is pretty meaningless...
Old 06-03-2005, 03:37 PM   #17
keirnna
Member#: 50167
1996 Subaru STI RA
Please explain further Matt.
Old 06-03-2005, 07:06 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
Closed Deck vs Open Deck was a major issue about 5 years ago before the WRX hit. Mike Shield's of SPD wrote a treatise on why his company would not develop a turbo kit for the EJ25, and a large part of it was the open deck design. This set the stage for a long series of debates about it, and basically gave the open deck a bad name.
But it is apples and oranges to compare the old EJ25 with the EJ20 open decks. One major thing is the bore size. The smaller bore of the EJ20 is far less likely to flex. The other part of it is the bottom end and crank girdles. The EJ20 was designed as a turbo engine that was going to see significantly higher stress than the EJ25.
Now, if you are really going for broke in the power department, a semi-closed or closed deck engine would be a good option. But for 400-450chp, it really is a non-issue. On an Ej20, rods an other things are going to be the weak link before the deck is an issue. And even then I have seen semiclosed deck engines blow cylinder walls! As in a 3 inch long split in the cylinder.
If you are swapping for a swap, and are going to run it near stock or slightly tuned, open deck is fine. IMO, the '97-98 JDM WRX engines are great choices, and pretty easy to find. The heads flow great, and they are really solid engines. They are EJ20K's that are stronger than the EJ20G open deck engines that continued in the world market. If you do a search for Mike's old article (it also may still appear on the SPD site) he goes into some of the differences in spec on the engines as they evolved. Actually, for WRX tech, SPD's site is a great resource...
Old 06-03-2005, 08:50 PM   #19
keirnna
Member#: 50167
1996 Subaru STI RA
Yeah lightly tuned and my cars don't go in the same sentence. Thanks for clarifying what you meant.
Old 06-04-2005, 10:38 PM   #20
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I think most people don't understand the REAL reason for the different deck styles. Subaru started closing the deck on all engines with the EA71 I believe. This was to combat headgasket issues. Up until the EJ series all engines were closed deck. But with the newer style of engine it wasn't needed on NA engines. They stuck with it on the turbo engines for a while though. Why they stopped doing it is up for grabs. Could be that even the EJ20G/EJ22T didn't need to be closed deck to begin with, and some EJ20G's weren't, but who knows what changed between the open and closed deck versions. Or it could be that with the EJ20H and EJ20K they could manufacture engines that wouldn't blow the HG's. As I said, I don't know for certain.
THAWA is offline   Reply With Quote
Old 06-05-2005, 03:21 AM   #21
bugeyes
Member#: 64494
2001 V7 sti
I was led to believe the change from closed deck to open deck Ej20 was a side effect of WRC regulations. Prior to the rule of engines having orifice plates the EJ20 blocks were cast to be able to handle high hp. However an engine fitted with the orifice plate had a hp limit of about 350hp.
Basically subaru was wasting money casting fully closed deck blocks and changed to open deck designs in order to save manufacturing costs the open deck design was easily able to handle the new 350hp limits.
bugeyes is offline   Reply With Quote
Old 06-05-2005, 08:16 AM   #22
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Edited for misreading Matts post!!
DuoMaxwell is offline   Reply With Quote
Old 06-05-2005, 12:25 PM   #23
THAWA
Member#: 44581
3 Boxers 2 AWD
Did you really read what he said or did you just pick certain words out and post a reply?
Old 06-05-2005, 05:13 PM   #24
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you mean ej20K right
Old 06-06-2005, 12:16 PM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
Nope. While the engines of that era were EJ20K's, the 22B is most definitely known as an Ej22G. Every technical document I have ever seen on it says so...
[search] engine emission sheet for ej20 engine tougeGER Newbies & FAQs 0 04-20-2010 02:08 PM
Lots of EJ20 Engine parts- parting out 2 engines SedonaRed03WrX Engine/Power/Exhaust 31 03-05-2009 02:13 PM
Engine oil for turbo engine differs from regular engine oil? cinemaster Service & Maintenance 9 04-29-2006 03:34 PM
will the 2.2L impreza L tranny fit on the EJ20 engine zsnoborder Transmission (AT/MT) & Driveline 0 09-06-2001 04:54 PM
about that EJ20 engine Darryl General Forum Archive 2 11-20-2000 05:39 AM
