Old 02-28-2014, 07:34 PM   #1
TUNE_UP
Member#: 155800
Default Help me identify newly aquired ej20
I picked this motor up on ebay and I cant seem to figure out what version it is. The sticker on the timing cover is gone. Thanks for the help!
TUNE_UP is offline   Reply With Quote
Old 02-28-2014, 09:39 PM   #2
thelloyd
Member#: 348314
1997 Outback
Looks like a 97-98 ej20g Forester, or WRX wagon. I am no expert though. I did get one off ebay for a swap. Looks just like it.The MAF housing has the sensor held in by two screws, wich the earlier ones were a part of the tube it connects to as a assembly. The next newer style of MAF was used in 02 and later and mounted at the top of the tube. As far as I know, again not a expert. The turbo inlet is also under the manifold instead of a 90. Coil sits on top of manifold off center.
thelloyd is offline   Reply With Quote
Old 02-28-2014, 10:24 PM   #3
TUNE_UP
Member#: 155800
I think your right I just couldn't get a definite answer
Old 02-28-2014, 11:58 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the coil pack off set to the right makes me think that its newer than that, i would say its 99-02 ish.. does that make it a 205? naming got really fuzzy in that time period
pull the crank pully to see if it is high density or low density crank sensor
Old 03-01-2014, 12:05 AM   #5
iamshayan
Member#: 338484
judging by the intake under the manfiold and the yelllow injectors I'd call it an ej20k ver5-6 motor. 97+ jdm .
iamshayan is offline   Reply With Quote
Old 03-01-2014, 05:55 AM   #6
TUNE_UP
Member#: 155800
I'll pull the crank pulley tomorrow and see what I can find
Old 03-01-2014, 01:34 PM   #7
wrxr4ti
Member#: 100724
98 Impreza RSTi
RED
Its not a K. The IAC is on the throttle body and the maf is of the 99-01 period I would call the this something like v5 or v6, take the timing cover off i suspect the timing gear for the drivers side intake will be metal making it a 205 or 207.
wrxr4ti is offline   Reply With Quote
Old 03-01-2014, 02:59 PM   #8
TUNE_UP
Member#: 155800
The top left drivers side intake pulley is metal
Old 03-02-2014, 08:27 AM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Coil location, manifold bolt pattern and flex plate tells me it is a 205.
i_c_the_light is offline   Reply With Quote
Old 03-02-2014, 11:31 AM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
EJ205 MY99-00. Forester or Impreza Wagon WRX. High compression ratio (9.0:1).
Marnix is offline   Reply With Quote
Old 03-02-2014, 11:56 AM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
For sure it is an 99-00 EJ205
