Notices
Old 05-26-2005, 02:41 PM   #1
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Default sr20 side feeds on a EJ20G (56k no!)
so its running
i took the rails from a 93 1.8 (glad i didn't throw it away)
the bracket for the 1.8 faces down
the bracket for the g faces up so i left the 1.8 bracket on there
cut the bracket off the ej20G rails and welded on to the 1.8 rails (i should say had then tig welded)
hard return line had to be bent back slightly but not bad other wise it was a complete bolt up
i changed the o rings in the fuel line and the grommets in the manafold (using 1.8 part numbers)
Old 05-27-2005, 04:20 AM   #2
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Jaxx please explain the benifit of this to me. I thought the biggest SR stockers are 480cc. I could be wrong but anything you can tell me would be appreciated!
DuoMaxwell is offline   Reply With Quote
Old 05-27-2005, 10:20 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not stock at least they are not suposed to be they are suposed to be 550s
sr injectors are about 2/3 the cost of subaru compatible injectors ..if you can find them (the elusive ver 2 injector)
i tuned yesterday afternoon they sure don't seem to flow that much more than the grey/light brown tops that i took out though
Old 05-28-2005, 04:06 AM   #4
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
btw, usdm sti yellows fit in thoes rails, when i say thoes i mean early usdm gc imprezza and 92-94 N/A legacy rails.
azn2yunr is offline   Reply With Quote
Old 05-28-2005, 05:21 AM   #5
kaos200
Member#: 2692
we tried a set of ver 6 STi sidefeeds into ej20g rails today without luck
Any ideas for drop-in injectors at or above 550cc for a reasonable price?
kaos200 is offline   Reply With Quote
Old 05-31-2005, 12:11 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
edit: yes! you are correct
what i did was pretty easy
it does envolve destroying your G rails though
nismo makes a 550 yellow top and a 720 injector (red top)
i paid 300 shipped for the 550s got them off the clasiffies on sr20forums.com
kinda funny that i got sti injectors off the sr 20 forum eh?
AC compressor, STI engine harness, side feed fuel rails V8Nate Engine/Power/Exhaust 17 07-10-2010 02:28 PM
Side Feed 850cc injector 02beast Private 'Wanted' Classifieds 1 06-02-2010 08:55 PM
wtb: 550cc sti side feed injectors or bigger ej20g blueGC Private 'Wanted' Classifieds 2 10-14-2009 10:21 PM
JDM STi V2 Front lip on! STi C/F side markers on! [ Camera Phone 56K Welcome ] minx1225 Member's Car Gallery 23 07-11-2006 09:59 PM
Scratches on my WRX!!!56k...no no That_Azn_Guy Member's Car Gallery 13 09-12-2005 12:21 AM
