Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 05-26-2005, 05:44 PM   #1
ton43ab
Member#: 87827
2005 Sti
Default help me with the boost controler...PLEASE
now i'm using the Profec B spec II Greddy boost controler.. my frind at the mod shop set up for me, but i chcked my last boost was 20. psi.. and i think 20 is too much for my stock turbo..(but its only spike on the 4th gear +
oh.. and i have intake Dp+ cat back - BOv.....
so if anyone have the same set up as my car please let me know what i should put in the Hi and Lo set up to make it safe for my engine...
thanks
ton43ab is offline   Reply With Quote
Old 05-26-2005, 06:50 PM   #2
teh sash
Member#: 79329
ditch and sell the BOV & Boost controller, (why are you using a boost controller on a sti with ur stock turbo) Buy a reflash and you'll be happy...
teh sash is offline   Reply With Quote
Old 05-26-2005, 07:14 PM   #3
powerleak
Member#: 72571
04 STI
you seriously need to get some engine management (ecutek reflash, utec, accessport, etc). do some more research before making your next modification. buying a blowoff valve and boost control were not things on my list although the TBE was a good idea.
you can run 18-19psi with your current setup but without the proper tuning, why?
if you really want to keep it the way you have it... run 18-18.5 high, 15.5-16 low from there you can tweek the low slight higher if the 20psi spikes stop happening but that sounds hit or miss to me. btw, 93octane or 91 octane?
powerleak is offline   Reply With Quote
Old 05-26-2005, 07:29 PM   #4
wgknestrick
Member#: 32576
04 STI
wgknestrick is offline   Reply With Quote
Old 05-27-2005, 03:35 AM   #5
ton43ab
Member#: 87827
2005 Sti
thanks everyone... you are helping me a lot... i didn't plan to do all this set up, but my friend recommended me to this basic upgrade which has bov. Dp, catback and intake , so i believed them.... But thanks to all of you.. i'll try to set up like how you guys told me too
thanks
Please Help Me With My Boost Gauge!!!! vytutis Electrical & Lighting 4 07-25-2006 12:55 PM
Help me with the boost gauge readings datwrx Electrical & Lighting 10 02-05-2004 09:23 PM
Anyone want to help me install a Boost controler? XT6Wagon North West Impreza Club Forum -- NWIC 17 08-29-2003 08:21 PM
Please help me with the dumbest question ever sonicsuby Bay Area Impreza Club Forum -- BAIC 7 05-30-2003 01:35 PM
('93-'01) Please would you help me with the following part numbers Wheels Impreza Forum 0 06-03-2001 05:57 PM
