Old 06-27-2005, 02:16 AM   #26
silvrsti
Member#: 49778
04 sti
so i have some questions.i have a friend who's trading in his 05 and is willing to let me swap anything to my 04.is it possible and or worth the swap to 5x114.it looks like i'll have to do alot of work ,but i would love to run 255/40's on my stock rims.so do i swap axles too?i want to plan this out as best poss. thanks for any help.-Z
silvrsti is offline   Reply With Quote
Old 06-27-2005, 01:40 PM   #27
silentbob343
Member#: 57307
the 05 has wider rims than the 04, 8invs7.5in. I don't know that 255 would fit on 04 rims, but they ould if you took his 8in wide 05 ims.
silentbob343 is offline   Reply With Quote
Old 06-29-2005, 01:12 AM   #28
silvrsti
Member#: 49778
04 sti
i was wondering how much other stuff is possible to transfer from 05 to 04.i.e rotors ,bearings.hub, axles trailing arms.just wanted some input front someone thats dine it before.
Old 06-29-2005, 09:34 PM   #29
javid
Member#: 54304
04 STi
TopSpeed-dAng!
silvrsti: What I have swaped (05 rotors, wheels, hubs and knuckles) will work. The front 05 axles WILL NOT work with an 04 front diff so you will be stuck with the wheel speed problems that I have described above until the new sensor gear are made...
javid is offline   Reply With Quote
Old 06-29-2005, 10:19 PM   #30
shumai_boi
Member#: 40818
does 05 STi front axles go into 04 WRX hubs?
shumai_boi is offline   Reply With Quote
Old 06-30-2005, 12:07 PM   #31
silvrsti
Member#: 49778
04 sti
thanks for the info.i was also wondering about the rear arms(that are aluminum on 05)and swaping them as well.do you think it would work?oh and by sensor gear is that for the abs?so 04 axles will fit in 05 hubs just the sensor is off?thanks again for all your help.
Old 07-01-2005, 02:32 PM   #32
shumai_boi
Member#: 40818
anyone???
Old 07-01-2005, 03:08 PM   #33
aznatama
Member#: 60316
2004 STi
wow, REALLY? lol
might as well swap over the entire suspension.... seems like you'd be able to just unbolt the entire thing and swap it over instead of doing this conversion and messing with the hybrid parts. Might as well swap the entire rear diff and maybe tranny too so you have the '05 axles... get the longer rear links and helical frint diff as well... and the 05 headlamp housings too... lol... might as well swap the seats and centerconsole/dash... ROFL
I can just imagine whoever buys that used 05 trying to upgrade the suspension or wheels, buying parts for a 05, and saying WHAT THE .....
aznatama is offline   Reply With Quote
Old 07-01-2005, 03:36 PM   #34
Porter
Member#: 486
2004 Forester XT
bug spattered
The fitment of the wide tires has nothing to do with the 05 conversion. It is facilitated by his widebody setup in the front and the rolled/clearanced quarterpanels in the rear.
Javid did this swap to increase reliability for track use. If you just want wider wheels/tires, go buy a wider set in 5x100.
Porter is offline   Reply With Quote
Old 07-05-2005, 08:02 AM   #35
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Bingo. Of course, wide 5x114.3 wheels are going to be cheaper and much more available than 5x100...
Old 07-05-2005, 11:02 AM   #36
silvrsti
Member#: 49778
04 sti
yeah just too much work for a stuff that i can do with aftermarket options.would have been cool just to have done it.
Old 08-05-2005, 12:14 AM   #37
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Sounds like a pimp upgrade J, but I can't run STi V7 rims on 114.3 so on that- I wonder if the actual hub from an 02 can be used in the 05 carrier housing?
btw, ever replace "teh elvises"?
MK19_ is offline   Reply With Quote
Old 08-05-2005, 01:44 AM   #38
silentbob343
Member#: 57307
I'm going to guess no, but don't hold me to that.
Old 08-05-2005, 06:41 PM   #39
javid
Member#: 54304
04 STi
TopSpeed-dAng!
What up Killa, my borther got me a fresh pair of shades for my graduation gift.
There is no practical way to run 5x100 wheels on the new front bearing. It comes as a sealed unit (complete hub, bearing, housing, bolts to the knuckle which is not the same knuckle as the 02-04).
Old 08-28-2005, 05:11 PM   #40
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
javid, any updates on the wheel speed sensor?
drivrswntd is offline   Reply With Quote
Old 08-29-2005, 10:17 AM   #41
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Unfortunately I am still out of town. This will be a top priority when I return.
I will update the thread when it gets done if you want to subscribe.
Old 09-19-2005, 04:24 PM   #42
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
any updates??
Also curious about the knockback correction this has. Right now all 4 corners "klunk" really bad and my peddle pressure is pretty poor. I'm guessing this is knockback. But the weird thing is....it's the worse at a slow roll. Like if I'm in a drive through getting food and i'm slowly creeping up. When I hit the brakes to come to a stop, they clunk the worst. Is this knockback or some other "gremlin" I have to deal with?
I currently have 2 seasons of auto-x on the car.
SloRice is offline   Reply With Quote
Old 09-19-2005, 04:39 PM   #43
SloRice
Member#: 44351
2004 Mitsubishi Evo
also do you have a list of part numbers we need from the dealership. My dealership is pretty stupid and in order to get the correct parts, I have to give them part numbers.
Old 09-19-2005, 05:46 PM   #44
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Update: I have not driven the car for some time, I have been out of town working in Ohio just north of you ironically. The problem that I thought was in the rack was actually the rear links loosening up and developing about an 1" of toe out in the rear. That combined with slight toe in up front makes for some pretty strange fead back in the steering wheel, especially during turn in or transient. The car was never alighned after the swap, but freind picked it up last week and got the alighnment done. Anyways, I figured I would let everyone know that the suspected rack problem had nothing to do with the swap.
Knock back is more noticeable the more you load the bearing. The load is generally greater at higher steering angles and of course with more grip. In a controlled setting, tap the brake pedal up. If your fluid is fresh you should be able to tap a couple times and start feeling the car jerk with little pedal movement (pads are tight against the rotor). Then give some sharp steering input back and forth (note you don't have to go fast or make the car slide, just quick lanes changes at 30 mph should induce the problem). After the transient, slowly start pressing on the pedal, if you can press the pedal down a good bit before the car starts to slow, then you have some knock back (initial pedal movement is pushing the pads back to the rotor). The pads move off the rotor because bearing flex moves the rotor realtive to the pad and pushes them back into the caliper. In my experiance, once the bearings were starting to flex, I could get them to flex more (initial pedal movement before the car stopped was the largest) by doing 5 mph U turns at full lock. Try that after you try the transient lane changes. Just before the swap I could do a U turn and fully depress the pedal and th car wouldn't stop. At that point the bearings were also starting to whin a little (not a blown bearing whine, just a slight whine) which is a sign that they need replacing.
In any event, my bearings got bad quickly because of all the track time with track pads. The extra heat will cause the bearing to go quicker.
I could notice a fair amount of knockback during my 3rd track day with the car (2nd event with the track pads). There is no official word on how long the 05 bearings will last but many 05s have already done a few track days with no signs of knockback.
Your clunking may just be backing plates that are getting load. I just ignore it. You can grease the pistons up next time you are working on the brakes and that should solve the problem.
Parts numbers: I have my reciepts back in atlanta. If your lazy you could just call Subaru of Gwinnett and talk with Scott Siegel and tell him you want to do the same swap, he will know what you need as far as subaru parts go(front hubs, front knuckles, rear hubs and bearing, and front struts if you don't have coilovers). Then you need to pick some rotors and wheels. Note that aftermarket 05 rotors are still coming out. Some makers have them others quote 'a few more weeks'. I have my eye on some TWR two piece floating rotors.
The custom gears should be available next month.
Javid
Old 09-29-2005, 10:05 PM   #45
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Javid,
If you get the speed sensor wheels please PM me. I will buy a set just in case I want to do the swap in the future.
Much appreciated,
Justin
PS - great info on this thread!
crystalhelix is offline   Reply With Quote
Old 09-29-2005, 11:13 PM   #46
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
My contribution to the thread. Thanks for the great information
petawabit is offline   Reply With Quote
Old 10-01-2005, 03:07 PM   #47
stealthsvx
Member#: 93664
This is pretty cool info, now something to laugh at. Most of this stuff was on a SVX and its pretty funny to see the same part numbers pop up on a 05 STi. The SVX has the 5x114 bolt pattern and thank you Subaru for putting it on the STi. Now we SVXers have a pick of rims and suspension that werent available before. Im still trying to see if the Brembos will bolt onto my SVX.
Does anyone have the bolt pattern on the knuckles(meaning the distance between the mounting holes for the calipers)
stealthsvx is offline   Reply With Quote
Old 10-01-2005, 03:41 PM   #48
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
the brembos should bolt up to the svx, the suba 4pots also bolt up, but you need to get custom rotors because of the spacing of the bracket... i think it was somewhere around 14.6" rotors to use the 4pots, but the brembos should bolt right up
nomadtw is offline   Reply With Quote
Old 10-01-2005, 08:18 PM   #49
stealthsvx
Member#: 93664
ok how and where do you get custom rotors? My other option is just to get the 05 STi knuckles/hubs.
Old 10-03-2005, 12:53 PM   #50
SloRice
Member#: 44351
2004 Mitsubishi Evo
So are you saying I can buy the SVX knuckles and hubs instead of the STI hubs and they will be the same thing?? Because we all know anything that has the letters STI in it, Subaru jacks the price up ~50%
04 sti to 05 sti axle/hub swap questions mesa50w Transmission (AT/MT) & Driveline 0 03-23-2009 05:46 PM
04 STi to 05 STi bumper swap? Admission_Regret Interior & Exterior Modification 10 09-23-2008 11:19 AM
04 STi to 05 STi Center console swap Drake13 Interior & Exterior Modification 4 12-28-2007 06:25 PM
04 sti to 05 sti climate control swap LUKEWMC Electrical & Lighting 6 01-18-2007 05:41 PM
04 wrx to 05 STi, alittle srt left out StealthfishWRX Newbies & FAQs 2 10-05-2004 01:58 AM
