Old 05-27-2005, 12:32 PM   #1
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
Default warmer weather=rich running?
Since I am not an EM guru, I wanted to confirm my thoughts.
Western Washington weather has taken a marked turn for the warmer recently, up to 85 yesterday....it appears that this has caused my stage 2 wrx to run a bit richer than before.
When cooler the light backfires/pops were almost non-existant but have started happening far more often with more burbling during engine braking.
I suspect as the warmer air is less dense the amount of air has gone down, causing a richer condition.
Does this make sense? I thought that the ECU was able to adjust by using the MAF sensor, but maybe it just isn't quite as good as I thought.
Anyone else with a similar situation? Sorry this is my first summer with a WRX
ptaaty is offline   Reply With Quote
Old 05-27-2005, 12:34 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yeah...warmer = richer.
ya may want to try resetting the ECU on a warm day and see wassupwidat
Old 05-27-2005, 12:40 PM   #3
scoobyracing
Member#: 54676
2002 impreza wrx mbp
People falling pwns!!!
Listen to your Uncle Scotty.
scoobyracing is offline   Reply With Quote
Old 05-27-2005, 01:21 PM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Originally Posted by ptaaty
I suspect as the warmer air is less dense the amount of OXYGEN has gone down, causing a richer condition.
^^^^ See edit.
jblaine is offline   Reply With Quote
Old 05-27-2005, 01:28 PM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
And yes, it should be handling the fueling for the temperature change...
Old 05-27-2005, 01:37 PM   #6
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
well yeah...air mass per volume (density) has gone down, meaning that oxygen has gone down, along with nitrogen, and the trace gases O2 is always exactly 20.95% of the gas content of air...everest, sea level, hot cold...no matter.
I may try a reset and see how it works, it really isn't this horrible rich pig, just richer than it was, and I thought the ECU would adjust because it is basing fuel amount on the air mass flow amount. I suppose this means that the MAF sensor isn't linear?
Old 05-27-2005, 03:18 PM   #7
kcook
Member#: 78074
2005 STi
what is EM?
kcook is offline   Reply With Quote
Old 05-27-2005, 03:51 PM   #8
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
EM - Engine Management
mcowger is offline   Reply With Quote
Old 05-27-2005, 03:58 PM   #9
hondaeater69
Member#: 60324
I know there's a air temp sensor pre turbo, does the ECU use this sensor in manipulating fuel for temp changes?
Old 05-27-2005, 04:10 PM   #10
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
I am not sure if it is related? I always thought the MAF (mass air flow) sensor was measuring the actual amount of air being used, but if the MAF functions by measureing air speed alone, a temp component would be needed and a lookup table to find the actual air mass.
*edit* if it wasn't measuring air mass and needed the temp probe it would need a pressure probe as well to take into account altitude so it must not....
Maybe what is happening the the MAF sensor isn't as accurate because the density of the air at the different temperatures causes a different flow pattern that it was calibrated to in the factory? They assume a certain type of flow to be accurate I guess.
Old 05-27-2005, 04:53 PM   #11
hondaeater69
Member#: 60324
know that i thought about it, i bet the temp sensor is for coldness on startup. It takes collant temp into consideration for high idle, but our cars will also run very rich on startup (around 10:1!) for about 1-2 minutes under extrememly cold situations, that's probably what the temp sensor is for
I don't believe it uses the temp sensor for fueling beyond start up.
Measuring the air "mass" takes temp into account.
Low boost /w warmer weather Jrags87 Newbies & FAQs 28 06-24-2009 11:46 AM
How bad is it to drive on snow tires in warmer weather??? Farnsrocket Tire & Wheel 4 12-16-2006 11:26 AM
What oil is recomended for warmer weather, 10W 30 or 5W 30? Tommi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-15-2004 01:18 PM
clutch chatter more often in warmer weather six1five Transmission (AT/MT) & Driveline 1 04-01-2004 11:06 PM
Utec in Humid warmer weather kenchan Engine Management & Tuning 10 07-06-2003 09:26 AM
