Old 05-27-2005, 12:53 PM   #1
kpalena
Member#: 82431
2006 06 wrx limited
CGM
Question I need help...again
Ok. This car is starting to test my patience. First the leak...fixed it. Then the coolant teperature sensor...fixed it. Now the car is rev searching when I start it. It will start, hit 1000 rpm then drop to almost nothing then bounce until it is happy at around 700. Any ideas. It's not serious, just annoying and worrysome.
P.S. '93 legacy wagon 2.2 NA with K&N drop in. (4 years old)
kpalena is offline   Reply With Quote
Old 05-27-2005, 01:01 PM   #2
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
What part is 4 years old? The K&N filter? If so, when was the last time you cleaned and re-oiled it? If never, do it now. If recently, I'm guessing perhaps you over-oiled and the MAF sensor is oily. But an idle hunt could be a number of things... you'll have to tell us what normal tune-up steps you've taken already.
P.S. Fill in your location and car info.
-Brian
KD7000 is offline   Reply With Quote
Old 05-27-2005, 02:16 PM   #3
4wdrift
Member#: 1403
99 RBP GC8 Impreza
bad gas??
4wdrift is offline   Reply With Quote
Old 05-27-2005, 02:41 PM   #4
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Try resetting the ECU.
Teh Legacy is offline   Reply With Quote
Old 05-27-2005, 02:48 PM   #5
kpalena
Member#: 82431
2006 06 wrx limited
CGM
Well, the filter is 4 years old. I cleaned and re-oiled it about three weeks ago. I did just reset the ecu when I replaced the coolant temperature sensor. I change the oil every 4500 miles and clean the filter twice a year. I am really anal about maintence. The MAF makes sense, I just didn't want to limit the thread to only that possibility.
Old 05-27-2005, 03:03 PM   #6
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Hmmm. You have symptoms that have cropped up a number of times for other people. Do a search for IACV or IAC or IAC solenoid
It'll show a bunch of threads about the "Idle air control valve" or IAC solenoid...
(Use the "advanced seach" not the "search this forum")
-Brian
Old 05-27-2005, 07:32 PM   #7
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Most of the time if you spray GM Top Engine Cleaner (The Aeresol Kind) down into the IAC hose (The 1" dia 12" or so long hose that connects to your Intake Setup) it will smooth out. Just make sure you put the hose back on before you start the car, otherwise the car won't idle!
wrx_driver_2002 is offline   Reply With Quote
Old 05-27-2005, 08:01 PM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
My engine acted like that when I spewed my head gasket.
tora is offline   Reply With Quote
ATTN: NOVA need help again...P.S.R.S.. this time i need torque specs... psyber_0ptix Mid Atlantic Impreza Club -- MAIC 12 12-14-2004 06:03 PM
Need help again IMPREZIV Tri-State Area Forum 8 05-17-2002 08:16 PM
Need help again- might be transmission jk147 Transmission (AT/MT) & Driveline 3 04-22-2002 01:09 AM
Need help again. This time its tires... gimpless Legacy Forum 13 02-26-2001 09:39 PM
Need help....again :) Keiho Car Audio, Video & Security 4 06-20-2000 04:19 PM
