Old 05-27-2005, 06:42 PM   #1
WolfDrive
Member#: 49506
2004 Impreza WRX STi
Java Black
Default U-LAME -- The UTEC Lazy Ass Multitasking Environment
U-LAME
Current Version: 1.6a
or
UTEC Log Analyzer and Map Editor
Program's mission:
To provide a non-realtime tool that can can be used to take care of tuning needs and provide
useful information in a quick, easy to understand, and easy-to-reference-between-areas way.
Features:
1. Log Analyzer
* Displays all the map points hit by the log.
* Ability to show averages of different values in the log:
* Knock Count -- how many times knock was found at that load site
* Average AFR -- uses a specially developed algorithm to display the most reasonable
average AFR value for that load site and also displays guess-timated
data if/when there is insufficient or sporatic data at the site.
* Average TPS
* Average MAP -- displays the average MAP (boost) value at each site
* Average IDC -- displays the average injector ducty cycle at each site
* Average Timing -- displays average timing across the load sites, using UTEC values
when the UTEC is in control (ie: shows the average timing that
the car actually acted on.)
* Average ECU timing -- displays just the average ecu timing values
* Average UTEC timing -- displays only the average UTEC timing values
* Average MAF V -- displays the average actual MAF Voltage at each site
* Average Mod Maf V -- displays the average modified MAF voltage used by the car at
each site.
* Transparent layering of selections
* A pink cell displays what cells are being selected in the map editor section
* A RED cell indicates that that load site saw knock
* A Cyan cell indicates which load site is selected in the log map (also selects the
same site within the Map Viewer section)
* When looking at the average AFR values,
teal indicates a rich load site compared to the AFR target site
orange indicates a lean load site compared to the AFR target site
* Ability to list all the data lines found at a given load site when you double click on
that load site.
2. Map Viewer
* Displays a loaded map (typically used to show the map used during the log)
* Transparent layering of sections like on the Log Analyzer
* Displays average and range data for the selected load site
3. Map Editor
* Uses the same control and navigation interface of the UTEC's map editor
* Shows real time checksum values
* Can save the map to a file uploadable to the UTEC
* Displays diferences between the map being edited and the map loaded in the Map Viewer
Red indicates a value lower
Green indicates a value higher
4. Afr Target Mapper
* Has the ability to save the map
* NOTE: There is no standard for AFR Target maps. It is best to simply click "Save AFR
Map" when you open the program in order to see how this program lays its map out.
Install files: (For Windows, Mac OS X, and *nix)
http://www.monosoft.com/ulame/
WolfDrive is offline   Reply With Quote
Old 05-27-2005, 09:27 PM   #2
cpturbo
Member#: 49175
2004 STI
This looks very promising, but does it work with the STI UTEC. Thanks for all the hard work. You rock!
CP
cpturbo is offline   Reply With Quote
Old 05-27-2005, 09:41 PM   #3
Axan
Member#: 17569
2011 Impreza WRX STI
good job, looks very good
Axan is offline   Reply With Quote
Old 05-27-2005, 10:24 PM   #4
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Given that WolfDrive owns a STi, I suspect it does.
CP
mcowger is offline   Reply With Quote
Old 05-28-2005, 12:32 AM   #5
Member#: 65392
09 Holden
Magnetic grey
This is so sweet. Keep up the good work. Thank God for your committment. This will make logging and editing so easy. TXS should take a look at this windows based, user friendly application!
Thanks
BE@ST is offline   Reply With Quote
Old 05-28-2005, 01:28 AM   #6
WolfDrive
Member#: 49506
Java Black
(Shameless plug alert) actually its not "windows based" its Java Based... so it'll work in unix/linux/windows/osx/etc... :-D
and yes it works on the STi... so far I havnt heard of any utec logs that it doesnt work for... I hope someone finds one so that I can make sure I get the bugs out... but feel free to try it... not gonna hurt anything if it doesnt work -- and you can let me know if it doesn't.
Old 05-28-2005, 04:52 PM   #7
AaronWRX
Member#: 7194
2011 997.2 Turbo
im using the latest JRE.
java.lang.UnsupportedClassVersionError: ulame (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknow n Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
AaronWRX is offline   Reply With Quote
Old 05-28-2005, 05:15 PM   #8
Focus4
Member#: 20107
2004 STi
sick program! Thanks!
Focus4 is offline   Reply With Quote
Old 05-28-2005, 10:29 PM   #9
WolfDrive
Member#: 49506
Java Black
Yeah :-\ At the moment I'm having some trouble getting the jar files to work correctly (I compiled it on JRE 5.0). My brother worked for Sun until about 6 months ago so I'm going to ask him to help me with these kind of errors. I'm sorry if the .exe file isn't going to work for you, but I promise I'm working on it.
Ulame 1.5 is out as an exe and it includes the ability to save map files with a working checksum as well as Afr Target information.
Old 05-29-2005, 01:04 AM   #10
WolfDrive
Member#: 49506
Java Black
Okay, I updated with install files for Windows, Mac, and *nix... so far I know it works in Windows and Mac... let me know about *nix.
Old 05-29-2005, 01:09 AM   #11
ImprezaWRX02
Member#: 12500
Just wondering if you could make the interface more like UtecEdit? I think that interfaces saves a lot of time making changes to maps etc and is just all around more efficient.
ImprezaWRX02 is offline   Reply With Quote
Old 05-29-2005, 02:03 AM   #12
WolfDrive
Member#: 49506
Java Black
I'll look into doing that.... though I think UtecEdit is a great piece of software with abilities I'd be hardpressed to mimic... perhaps they both have their own place in the tuner process.
Old 05-30-2005, 05:00 PM   #13
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Hello again,
Can you fix the timing and IDC bugs if i send you a log of my EDM utec ?
thanx
WhiteKnight is offline   Reply With Quote
Old 06-03-2005, 07:43 AM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it does not seem to be parsing my rex utec + tuner log files properly... i get a ? NaN ? in the cells while viewing avg afr.
any ideas?
ken
Old 12-05-2005, 11:01 PM   #15
antrey
Member#: 87454
2005 SAAB 9-2X Aero
Can someone describe for me how the "Min AFR Diff." and "Max AFR Diff." values work when analyzing average AFR in the "UTEC Log" tab in ULAME?
9-2x project car web page: http://9-2x.dynamic-dyno.com
antrey is offline   Reply With Quote
Fs/va/dc/md Utec For Sale And Map Selector LGTONCOKE MAIC Private Classifieds 43 04-08-2010 11:37 AM
WTB: Utec remote switch and map sensor scutzi128 Private 'Wanted' Classifieds 2 03-21-2008 02:31 PM
FS:NY/NJ TurboXS Utec rev. 6b and map switch blue_ninja Engine/Power/Exhaust 7 11-07-2006 03:04 PM
Analyze my UTEC logs TravisSTi UTEC 29 03-15-2006 08:16 PM
Someone analyze my Utec logs.. jefersun Engine Management & Tuning 6 03-03-2005 09:11 AM
