Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-27-2005, 07:02 PM   #1
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
Default raising seats?
its not that im too short, although i could use a few extra inches ( who couldnt ) , im taking my baja to the performance shop tomorrow, gonna get the seats in the baja raised by about an inch b/c i want to fit a diamond amp underneath each one... has anyone done this or have any thoughts on this? im pretty sure they will have to fab brackets to raise the seats b/c one of the bolts that bolts the seat in is horizontal (right-rear on drivers side, left rear on passenger's), while the other three are vertical. how much should something like this cost?
cliffhanger is offline   Reply With Quote
Old 05-27-2005, 11:04 PM   #2
YooperBaja
Member#: 64311
2003 Baja
I think many of us have voiced concern about not having enough head room as it is. I am 5' 11" and I barely have enough head room. If you have the head room to do it more power to you. One thing about sitting higher..... it is more difficult to see the stoplight turn green unless you lean forward.
My two cents..... and worth every penny of it.
YooperBaja is offline   Reply With Quote
Old 05-28-2005, 12:25 AM   #3
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Open up the sun roof...
holland_patrick is offline   Reply With Quote
Old 05-28-2005, 09:30 AM   #4
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
It might be cheaper or near the same cost to pick up a set of WRX or power Legacy seats ($250-350 range). Those will allow you to go up from your current position to give you more room under the seat and if you ever take the amp out you can lower the seat back to the stock location.
Good luck and take some picts of the bracket once they are done.
02_Forester is offline   Reply With Quote
Old 05-29-2005, 11:06 PM   #5
opimax
Member#: 85940
I am going to use Phoenix gold zx series amps, they fit
Mark
opimax is offline   Reply With Quote
Old 05-30-2005, 07:59 AM   #6
cliffhanger
Member#: 80446
2005 5spd Baja-T
i measured and we have about 2-3/4" of clearance underneath the seats, my amps are both almost 3" thick... gotta leave some breathing room unless you really like overheated amps! how thick are the pg's?
Old 05-30-2005, 08:51 AM   #7
opimax
Member#: 85940
2" w/fans
zx 500 rated at 600x1 into 4, runs about at least 600-900 rms into a 2 ohm sub never found accurate info
zx450 measured at about 145 x4 into 4 ohms, running just a front stage rated at 250x 2 into 4 ohm at least 300 I think.
http://www.phoenixgold.com/webfaq/ZX.htm
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Mark
Old 05-30-2005, 11:49 PM   #8
cliffhanger
Member#: 80446
2005 5spd Baja-T
nice, im going for a matched diamond set, ive got a d7 401 mono amp to power two cm3 8" subs in a custom enclosure (hopefully to be put in by the end of this week), a d7 056 six-channel to power my m6 components front and m6 raf's back, cant wait to get these seats up!
Old 05-31-2005, 04:01 PM   #9
opimax
Member#: 85940
Pics are required! you are close enough for a visit too! my system is mostly together, just not installed, job worries have put on the brakes. basically the same system in my G35 different speakers, focals, PG sub on rear seat most likely . Let me knoewhen yours is listenable too...
Mark
Old 06-01-2005, 12:22 AM   #10
cliffhanger
Member#: 80446
2005 5spd Baja-T
alright, will do, but im a little boozed up right now and it is dark so no pics, but we got an extra inch up; the amps will fit no prob now, just a matter of when i can drop the baja off for a couple of days for the install of everything else... im short (5'7") and the extra inch takes away a lot more than i thought... luckily ( i guess in some respects ) i am not any taller, b/c it would be close to getting uncomfortable... but right now it feels like i gt alift kit.. sitting a lot higher now is nice...
How can I raise the seats on 09 Impreza 2.5i Genius at work Interior & Exterior Modification 3 07-05-2011 07:43 PM
FS : lugnuts, panel filter,etc.. scooby_wooby MAIC Private Classifieds 48 09-14-2010 02:38 PM
FS : 2006 STi Rear seats theasianeffect Interior/Dressup/Audio & Security 9 06-05-2010 07:59 AM
Raising height on aftermarket seats? Mr. Sadface Interior & Exterior Modification 7 09-11-2006 10:26 PM
