Old 05-27-2005, 07:13 PM   #1
aakrusen
Member#: 77308
'02 WRX
Default Base map and Realtime map
I just installed stage 2 and completed my TBE. I did the whole initializing thing and put on the base map. Now, do I have to go back and put on a realtime stage 2 map or do I just leave? I ask this because after you install the base map, the instructions say to unplug everything and go driving. What should I do?
aakrusen is offline   Reply With Quote
Old 05-27-2005, 07:44 PM   #2
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Subaru Banner
If you flashed stage 2 base map your done and you don't need to do anything else.
MD04WRX is offline   Reply With Quote
Old 05-27-2005, 08:10 PM   #3
aakrusen
Member#: 77308
'02 WRX
Perfect, thanks.
Now what about doing the "Vishnu Reset"? Will that help?
Old 05-27-2005, 10:09 PM   #4
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
It will help.
mcowger is offline   Reply With Quote
Old 05-27-2005, 11:54 PM   #5
aakrusen
Member#: 77308
'02 WRX
I just downloaded the lastest stage2 base map version (v 1.22). I want to know if I should flash this base map on there or if I should just leave the current stage2 base map on there and flash on the realtime stage2 v 1.22 map?
Old 05-28-2005, 12:49 AM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
The realtime is fine.
Old 05-28-2005, 01:24 AM   #7
Boostfiend04STI
Member#: 73415
2004 WRX STI
Blue Pearl/Silver
I need a refresher on what the "Vishnu reset" is. Anyone care to refresh my memory
Boostfiend04STI is offline   Reply With Quote
Old 05-28-2005, 01:31 AM   #8
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Basically, its reset the ECU, then ROMP the throttle. Encourages the ECU to learn the IAM at 16 immidietly, and apply maximum timing advance.
Old 05-28-2005, 08:55 AM   #9
aakrusen
Member#: 77308
'02 WRX
Boostfiend04STi - Here's the Vishnu Reset
Old 05-28-2005, 09:35 PM   #10
Boostfiend04STI
Member#: 73415
2004 WRX STI
Blue Pearl/Silver
Ok, thanks, I remember reading that thread like 6 months ago.
Old 05-28-2005, 11:10 PM   #11
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Just drive the car around like you normally would. The IAM will advance pretty quickly assuming everything is okay. The ECU is smart...let it do it's thing
Mike
crazymikie is offline   Reply With Quote
Old 05-29-2005, 11:18 AM   #12
aakrusen
Member#: 77308
'02 WRX
Well then why bother doing it at all? I was under the impression that Vishnu did this reset to quicken the learning for dyno runs. So are you basically saying that unless I'm doing dyno pulls, I shouldn't bother doing it?
Old 05-29-2005, 11:32 AM   #13
crazymikie
Member#: 56321
Green
I don't believe in forcing the ECU to learn unless you are doing dyno pulls and need to quickly check how the car behaves with maximum advance.
The Vishnu trick quickly advances timing across the board. This should happen as matter of course the first time you drive the car on the highway (unless you drive like a grandma). If you let the ECU do it's thing and don't force it to learn, it will also have time to learn things like fuel trims as well as fine ignition corrections in the meanwhile.
Opinions vary- I just don't see any reason to force the car to learn when it will happen relatively quickly anyway and seems safer to just let it learn at it's own pace.
Mike
Old 05-29-2005, 11:43 AM   #14
hondaeater69
Member#: 60324
I agree with MIke. You could potentially be placing your car in harms way too. By advancing timing falsely, you may be advancing it farther than say the current gas or envirnoment like it to be, then guess what? DETONATION that's what.
Let the car learn on it's own, it was designed to do it that way.
Difference between Stage1 map and ACN map? burnrubber AccessPort 10 01-26-2010 11:08 PM
16g base map and realtime map. subietech420 AccessPort 1 09-15-2006 09:19 PM
realtime map vs base map dodiox Engine Management & Tuning 25 11-19-2005 04:58 PM
Should i be using the stage 1 realtime map or just use the base map ? wrxhunter Engine Management & Tuning 2 06-10-2005 12:38 PM
Base map, Realtime map CaptainMorgan Engine Management & Tuning 2 05-15-2005 12:45 PM
