Old 08-01-2001, 11:46 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Flywheels and Turbos?
Tonight my clutch showed that it is tired or transfering all the extra power of the turbo. It last well at 6psi for a stock cluth though. Anyway my question is what are people's thoughts about the value of a lightened flywheel? Is it worth it? I don't plan on going past 8psi if that matters. Also this car is my daily driver. Any input would be apprecited.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 08-01-2001, 11:58 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I was thinking about doing a clutch and flywheel change on mine but decided against the flywheel. No real good reason other than need and money....
I no it's no help.... but it is an example....
kastle is offline   Reply With Quote
Old 08-02-2001, 12:04 AM   #3
Member#: 67
1999 Outlasting
the competition.
Old 08-02-2001, 12:16 AM   #4
mcgyver
Member#: 1655
MY98 RS w/WRX Conv
I-Speed Tech
Thumbs up
Joshua,
I have pretty much the same setup, MY98 RS-T.
I put in a lightened flywheel, ACT PP & Stock Clutch when I had New head gaskets replaced under warranty. I did this when I was still NA.
I've always thought it was a GOOD mod, especially if you're replacing the clutch. Stock weighs 25lbs., mine is 14.9lbs. from Primitive. There are lighter ones that are chromoly that weigh in about 12lbs. As for mine, I don't have any drivability problems.
-Adam
mcgyver is offline   Reply With Quote
Old 08-02-2001, 01:10 AM   #5
Ethan
Member#: 246
Hey remember I told you I was doing these exact parts like 2 months ago? Well I should have them in next week. So I'll report how they work with this kit (remember I have the same thing as you).
Ethan is offline   Reply With Quote
Old 08-02-2001, 05:30 AM   #6
Hyperex
Member#: 7680
Thumbs up Change 'em together
Its a shame if you need to change clutch but not wanting to lighten the flywheel. Rev faster is the advantage, rocket ship!! vroom vrooooommm.......... go go go !!!
(loosing some low end torque is the dis-advantage , but i still opt for lightening it)
Hyper
Hyperex is offline   Reply With Quote
Old 08-02-2001, 08:09 AM   #7
HRE | giulio
Member#: 481
That combo makes the car a lil harder to drive.
The ACT just wants to grab, and the lightened flywheel makes the car want to stall. So you gotta baby the clutch from a standstill. Get set for bucking until you relearn it.
Once it's moving though it's great!
g
HRE | giulio is offline   Reply With Quote
Old 08-02-2001, 09:10 AM   #8
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Default My 2 cents...
A heavy flywheel will allow you to store energy. If you are at a standstill and you rev up the motor to like 4000 RPM and "dump" the clutch, you will launch very hard because of the stored up energy in the flywheel. However, with a light weight flywheel, if you let out the clutch at lower RPM and then floor it, you will be able to accelerate quicker because the power from the engine is not having to turn a heavy mass. More power is directly transfered to the wheels. I don't know if that helps any or not. A lighter flywheel will allow the engine to rev faster and have better throttle response. A heavy flywheel is easier to drive and can make the car launch harder. I think if you had the EXACT same car and ran a quarter mile with a heavy and a light flywheel, the light flywheel car would be a little quicker. Also keep in mind that a lighter flywheel takes weight off of the car as well. Removing 15lbs of weight anywhere from the car helps some. Removing it from a rotating mass helps even more. One more note: I think a heavy flywheel improves idle quality some and prevents stalling when you let the clutch out. If you had a RIMMER super-charger on your car, I don't think it would even idle with a light weight flywheel. Having said all that, I am getting the 12lb chromemoly flywheel and Kevlar clutch...
subarumantoo is offline   Reply With Quote
Old 08-02-2001, 09:13 AM   #9
efoo
Member#: 80
it pretty much comes down to how streetable you want your car to be.
a lighter flywheel will make it harder to idle smoothly too if you get too light, so keep that in mind. also, a grabby clutch + lighter flywheel = lots of fun in stop and go traffic.
I have a STi clutch and flywheel, works great. The flywheel is about half the weight of a stock RS flywheel, around 13 lbs of so.
-Edwin
efoo is offline   Reply With Quote
Old 08-02-2001, 12:24 PM   #10
EddyRS
Member#: 1257
2000 GC8 WRX
93 RS-W Wagon (White) RIP
Hi all,
I just had a Jun Flywheel (12.34 lbs) and ACT clutch installed. I have not seen any negative side effects to the combination. The car idles just spot on. As for driving in heavy traffic, I would say that was not much of a prob as some say it would be. I learned from the first start to ease the clutch out.....while giving a little more gas. I have yet to stall the car, or even to cause it to jerk. Just don't try to lift off the clutch pedal so fast and everything is ok (that is only for first.....no problem once the car is moving)
As for loss of low down torque.....I have noticed no ill effect, infact I could say that it pulls even harder down low. But I must mention that I do not rev the car up when I take off. I tend to start out at about 2000-2500 rpm when going from a start...so I guess the lightened flywheel just complements my driving practices.
All I can say is "get it, if you don't like it, replace it" I kept my stock flywheel JUST in case. But now I think I'll make it into a base for my garage chair. ITS HEAVY ENOUGH!
Cheers All
EddyL.
Scoobie Newbie, now, tomorrow, and when I die.
EddyRS is offline   Reply With Quote
Old 08-04-2001, 02:23 AM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Get the flywheel now while the tranny will be out, it will save you money in the long run, and will really improve performance.
EXAMPLE:
1) I ran gtech pro times stock with only GanzFlow intake before my turbo at a consistent 16.7 @ 84 (a stock RS is about a 17.5 - 18.0 here at 6,000 feet)
2) Then I did the JC Sports GB turbo kit with small IHI compressor and ran a 15.1 @ 94 at 5 psi boost.
3) Two weeks later I did a 12lb flywheel and ACT clutch and ran a 14.65 @ 97.5 with the same basic turbo kit.
Remember, at 6,000 feet an NA car will be about 1.5 - 2.0 seconds slower in the qtr than at sea-level. A turbocharged car, which compensates better for altitude, is still about 0.5 seconds slower up here than at sea-level. Whatever the case, the flywheel and clutch took off 1/2 second on the qtr mile times!
Larry
www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 08-04-2001, 09:58 AM   #12
Blindeye_03
Member#: 4418
2016 Focus ST
-Edwin
What is the sti flywheel made of?, and where can you get it?
-justin
Blindeye_03 is offline   Reply With Quote
stock seat belts and flywheel and oem clutch disk and drivers glass portangelessubie NWIC Private Classifieds 6 04-06-2010 12:28 PM
fidanza flywheel, sbc turbo kit, downpipe crossfire dukeduster Private 'For Sale' Classifieds 10 04-27-2006 10:10 PM
OEM Audio system and Flywheel and OEM stuff + Jdm goodie Sevaru Private 'For Sale' Classifieds 8 03-21-2006 10:58 AM
FS: Exedy clutch and flywheel, and more Crash477 Private 'For Sale' Classifieds 8 03-16-2005 04:47 PM
STi turbo flywheel and clutch $1 on eBay (Used 600 miles) Jude DeMeis Private 'For Sale' Classifieds 4 07-13-2004 12:27 PM
