Old 05-28-2005, 12:46 PM   #1
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
Default Got the 2.5 swapped in, now a bunch of questions...(HELP!!!!!)
I started working on the 1.8 to 2.5 swap last night, and it's almost finished. Couple questions are:
Is this blue plug off the 1.8 harness important? What does it go to and how do I get it there?
I assume that it plugs into this?
What about this hose? I don't really remember disconnecting it. It comes out of the coolant pipe below the intake.
Is this retained at all?
I've been working on it all night, and let me tell you, it's been interesting. In case anyone was wondering, you can take the engine and tranny out as one unit. The two were seized together, and I had to take them both out to get them apart.
I really hope that I can get this wrapped up soon
Seth
BTW, engine is a 2001 2.5, car is a 93'
EcksJay is offline   Reply With Quote
Old 05-28-2005, 01:02 PM   #2
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
hey, i did that swap about a yr. ago, that i forget which is which, but theres 2 connectors that look like the blue one in the picture, a blue one and a red one. One is for the egr and one is for the map sensor, for the throttle body. Did u take pictures or mark what everything was connected to before you pulled the motor?
g/l
mikey
mcu81 is offline   Reply With Quote
Old 05-28-2005, 01:05 PM   #3
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
oh, also that hose, its suppose to flow coolant through the throttle body, and back into the block, just bypass the throttle body and put it back into the block on the other side of the throttle body.
And that canister i think is the charcoal canister, you prolly should retain that, i didnt, i kinda half ass'd some stuff, but my car only runs 85-90%
-mikey
2.0 to 2.5 swap in WRX, need some help. Samurai_jim Built Motor Discussion 3 11-22-2008 11:37 PM
questions about parts needed to do 2.5 swap in '02 WRX cegpcola Subaru Conversions 8 01-21-2006 03:22 PM
2000 2.5 engine in a 99 Impreza L questions. jkjersey Subaru Conversions 8 09-10-2005 04:00 AM
Hacking the 1.8 ecu after the 2.5 swap EcksJay Normally Aspirated Powertrain 7 06-16-2005 03:03 AM
Do they sell the 2.5 RS in Japan? driver General Community 8 02-22-2004 06:52 PM
