Old 05-28-2005, 01:53 PM   #1
peterex
Member#: 27021
2015 WRX
Question GM solenoid / Perrin EBCS on the stock WRX turbo
Does anyone have firsthand data showing earlier spoolup when running the GM solenoid or Perrin EBCS on a TD04 turbo? Is it worth the effort/expense?
I scoured all the relevant threads, and it seems that most people who run these upgraded boost solenoids have larger turbos. If there is any benefit whatsoever on the stock turbo, I wouldn't mind spooling 100-200rpms faster for the relatively cheap price of the GM solenoid. Of course, tuning would be required to prevent spikes and stuff.
peterex is offline   Reply With Quote
Old 05-28-2005, 04:09 PM   #2
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Running in interrupt mode you may see a slight increase in spool as the wastegate see's no pressure until the solenoid opens. With the stock setup the FBC is used to reduce the pressure the wastegate sees. This can let the wastegate leak a little and slow spool time. The benefit is more noticeable on larger turbos but not useless on the TD04. And once it's on, you don't have to change it out when you upgrade either.
phantomsr is offline   Reply With Quote
Old 05-29-2005, 12:18 AM   #3
peterex
Member#: 27021
2015 WRX
Thanks for your input. Can you estimate, in terms of RPMs, the amount of spool increase?
Old 05-29-2005, 12:23 AM   #4
MrH00nel2
Member#: 80474
2002 Z06
1200whp
id guess around a 150-250 ish rpm less???
MrH00nel2 is offline   Reply With Quote
Old 05-29-2005, 06:01 AM   #5
Barge
Member#: 62941
2004 WRX
Rally Blue
With the streettuner I've been able to get it to get up in the boost pretty quick. The biggest difference is in 1st and 2nd gear. In 1st gear I can usually hit 16 psi instead of the stock 10-12.
Barge is offline   Reply With Quote
Old 05-29-2005, 09:27 AM   #6
peterex
Member#: 27021
2015 WRX
Cool. Sounds like it's worth it.
Old 05-29-2005, 11:47 AM   #7
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Just don't try interrupt mode without tuning as you WILL overboost. This mode is opposite of the stock setup and opening now allows the pressure to reach the wastegate instead of bleeding it off.
Old 05-29-2005, 01:05 PM   #8
TheMadScientist
Member#: 23717
2005 Big red
Ohh really? Thats nice so if the solenoid fails you get all the boost the turbo will make?
If you hook up the GM the way it is shown in the thread you get wastegate boost if the solenoid fails.
More duty cycle to the solenoid = less duty cycle to the waste gate =higher boost = the way stock works
Don't know how the EBCS is being hooked up but if your description is correct then that is very dangerous.
TMS
TheMadScientist is offline   Reply With Quote
Old 05-31-2005, 06:49 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
fwiw, in both scenarios, the ecu applies 12vdc (or, more accurately, provides a "pull down" in the ground conductor) to INCREASE boost.
in other words, in both scenarios, if the electrical circuit becomes open or shorted, you get wastegate boost.
i know mark knows this, but some folks don't.
Big 16g turbo better than the stock wrx turbo? standard-1080 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-19-2009 11:31 AM
opinion on the stock upgrade turbo from forced performance slammedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-02-2002 04:45 PM
What is the Wastegate Set At on a Stock WRX turbo (TD-04L) BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-23-2002 10:40 PM
Can the wastegate on the Stock WRX turbo be adjusted for lower boost? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 8 09-08-2002 05:27 PM
does anyone have the part numbers to the stock wrx turbo fittings? inpreza kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-12-2002 06:45 PM
