Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 05-29-2005, 11:32 AM   #1
chadlee
Member#: 88124
Default apexi avc-r super install
I have an apexi avc-r super - first version NOT the blue digital one. It was connect up to the turbo but when i bought the car it was disconnected. It was installed correctly.
I have 2 hoses coming from the boost valve - one from the NO and the other from the COM section. My question is - Where do these 2 hoses fit into the vaccum lines that run from the solenoids to the turbo etc. Cant figure it out and apexi site only has the new installation doc. My car is an JDM V2 sti enigined rallycar with a TD04L turbo(cheaper to use and abuse).
any info will help, I can also post a pic if needed.
thanks
chad
chadlee is offline   Reply With Quote
Old 05-29-2005, 02:25 PM   #2
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
The COM hose goes DIRECTLY to the wastegate actuator bung. The NO hose goes DIRECTLY to the turbo housing bung. This is the correct way to connect the solenoid to the turbo. There is a also hose that is supposed to go from the display/control unit to the manifold vacuum line that is connected to the fuel regulator diaphragm.
Kreeger is offline   Reply With Quote
Old 05-29-2005, 11:40 PM   #3
chadlee
Member#: 88124
hey kreeger, thanks for the info. Can I send you a pic for you to see what i have? May-be that way you can help me sort out this mess.
thanks
chadlee
Apexi AVC-R EBC Install On 04' STi ;HELP Kushmasterh Impreza Forum 0 12-25-2005 11:26 PM
Apexi Avc-r Install Help CommandoRabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-18-2001 10:28 PM
Apexi Avc-r Install CommandoRabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-18-2001 01:08 PM
Apexi Avc-r Install CommandoRabbit Normally Aspirated with bolt-on Forced Induction Powertrain 2 11-08-2001 11:11 PM
Apexi AVC-R Installs??? JohnWad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-17-2001 09:28 AM
