Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-29-2005, 03:25 PM   #1
wkw
Member#: 17352
2008 Catrike 700
Default Morette vs. Prodrive lights
I am thinking about getting some of the LHD prodrive projector lights. I have morettes now on my 02 wrx wagon. Will they be any better than the morettes? I have not been completely satisfied with the beam pattern. It seems when I move the beam up a bit to see down the road far enough I start getting flashed by oncoming traffic. Does anyone know if they use the same bulbs? I would like to be able to switch my HID kit over to the prodrives if I get them
thanks
wkw is offline   Reply With Quote
Old 05-29-2005, 05:32 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Prodrives are H7, same as the Morettes, and also have the same E-code light pattern so I don't think you would find the results with them to be much different than with the Morettes. You have to be very careful when aiming E-code lights, you should aim them against a wall using the proper specs rather than just raising them until you can see as far as you want. Here is a link to an aiming procedure-
http://danielsternlighting.com/tech/aim/aim.html
Also the projectors should be aligned so that the flat part of the beam pattern is horizontal, if it's not and the pattern makes somewhat of a "V" shape the slight rise to the left can bother oncoming traffic especially if you have the lights aimed too high. This can be an issue with both Morettes and Prodrives.
And, unless you have a line on a used set, Prodrives are no longer available new in the US AFAIK.
Comparison of Morette and Prodrive Orson Electrical & Lighting 15 02-15-2006 03:36 AM
morette vs oem head light{2.5rs} trinistyles Tri-State Area Forum 12 12-14-2004 01:16 PM
Morette/Prodrive light kits from RockBlocker RockBlocker Vendor 'For Sale' Classifieds 56 03-05-2004 01:41 AM
JDM vs Morettes vs Triplus/prodrive AK_2002_WRX Electrical & Lighting 20 04-09-2003 08:13 PM
Prodrive uk300 vs Triplus lights vs WR Sport Twin Headlamp Edvig Interior & Exterior Modification 4 11-30-2002 01:30 PM
