Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2015
Old 05-30-2005, 11:06 AM   #1
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Default clutch
so, i just read something about this the other day, and i had never thought of it. on my 99 RS i want to do a V7 swap. do i actually need to swap out clutches with a W or can i keep my current set up? i have an exeddy clutch and like it alot. don't want to swap. but also don't know if i need to.
-Eli
squirrelmasta is offline   Reply With Quote
Old 05-30-2005, 01:14 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
depends on which tranny you are using.. If your retaining the RS tranny, then you need to use an RS clutch. If your swapping to a wrx tranny, then you need to switch it over to a wrx clutch. Different operation between the two.
subbyspeed is offline   Reply With Quote
Old 05-30-2005, 09:08 PM   #3
squirrelmasta
Member#: 33445
Cherry Red
ok, since i'm keeping the stocker till i blow it, then i'm ok. Thanks much.
-Eli
Old 05-30-2005, 09:59 PM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
-Eli
hahaha.. as long as you don't dump the clutch, the exedy is pretty tame. Your tranny should hold.
FS : wrx 02-05 wrx exedy stage 2 clutch new tdi_hatch Drivetrain 9 06-28-2010 10:30 AM
FS : (OH): 2004 STi six speed transmission/axles/R180/driveshaft/clutch/flywheel coolblue05 Drivetrain 15 06-21-2010 07:31 AM
Clutch Fork Boot part#...please. motocooney Private 'Wanted' Classifieds 5 06-05-2010 02:27 PM
FS : 04+ STI OEM Spec Exceedy Clutch Kit NOW TurboSetch AKIC Private Classifieds 4 06-03-2010 03:49 PM
stage 2 clutch jospgut Newbies & FAQs 13 06-02-2010 03:54 PM
