Old 05-30-2005, 03:08 PM   #1
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
Default 91 Legacy Transmission parts into a 99RS
ok heres what im doing
starting with a 99RS 4eat
i found a 00RS transmission/driveshaft/rear diff
for my auto to Manual swap
i found a parts car that would take car of the rest of the parts needed for my swap
my question is will these parts from a 91 legacy fit onto my 99RS?
-pedal box
-clutch master cylinder
-clutch hardlines/softline
*Ide be using the slave cylinder from the RS*
-transmission xmember
-tranny mount
-rear lsd axels
-anything else i might need for the swap
any comments/suggestions are welcome
thanks
-cameron
2.5 Blue Roo is offline   Reply With Quote
Old 05-30-2005, 04:26 PM   #2
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The pedal box will fit, but you need to make sure your donor car is a turbo legacy, otherwise you will end up with Cable Clutch setup instead of a hydraulic clutch setup.
The only cars that had Hydraulic clutches were 2.5L engines and all EJ Turbo Engines (1991-1994 Turbo Legacy, 1997+ Legacy Outback (1995 and 1996 Outback had a 2.2L with cable style clutch), 1998+ Impreza RS, 1998+ Forester, 2002+ Impreza (All had either a 2.5 or a 2.0 Turbo), and 2000+ Legacy (All had 2.5L)
The crossmember from any AWD Legacy, Forester, or Impreza will work on your swap. I think the 2wd Crossmembers are the same, but I can't remember.
Whatever axles you get, make sure they match the rear diff. The older rear diffs have stub shafts that stick out of the them and the axles are attaches by a roll pin, and the newer diffs have the stub shafts built onto the axles, and are held in the diff with a circlip inside of the diff. Your Rear diff should need the newer style axles with the stub shafts built onto them.
For the Clutch Hard / Soft Lines, just go to your local hose maker, and have a hose made from the Master to the Slave Cylinder. It looks cool, and it's not rubber line. Most of the time, they make them with Braided Stainless.
wrx_driver_2002 is offline   Reply With Quote
Old 05-31-2005, 12:13 AM   #3
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
yup its a turbo legacy, eventually ill be swaping engine xmembers, and using the manifolds for a mild turbo setup
thanks
Old 05-31-2005, 11:00 PM   #4
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
anymore help?
Old 06-01-2005, 08:07 PM   #5
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
picking up all the parts on sunday hopefully
implanting a 91 legacy turbo motor into my 98 impreza subarumafia700 Subaru Conversions 13 11-17-2008 10:56 AM
WTB, So.cal: front brakes, Speakers, 16/17in subaru wheels/tires, 91 legacy body part narenji Private 'Wanted' Classifieds 1 05-10-2005 02:21 PM
WTB used,90-91 Legacy body parts Hondaslayer Private 'Wanted' Classifieds 0 04-06-2004 12:20 AM
Would a B4/Legacy transmission swap into our WRX's? Butt Dyno Transmission (AT/MT) & Driveline 3 06-27-2003 10:23 AM
91 Legacy Transmission lag - help simiele Legacy Forum 3 07-26-2000 08:05 AM
