Old 05-30-2005, 06:03 PM   #1
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default Strange elec gremlin
I've got Morettes with a Brightstar HID kit and about two weeks ago, my passenger side light went out. My first thought was bad ignitor or balast, but a few other strange symptoms exist.
When I run the low beams, only the drivers side works, but my High Beam indicator lamp glows dimly. When I select High Beams, both highs come on, but my indicator goes out completely.
I've also been having trouble with my EGT gauge (Omori). In the past, it has worked well, but if the probe got wet, my readings would go to zero for about 5 or 10 minutes till everything warmed up. Now it just sits on zero. Not related you say? If I run either the parking lights or the headlights, my EGT readings start to go nuts (happens slowly at first, then gets worse). To the extent that my gauge pegged at 2200 degrees. If I turn off the lights, the gauge goes back to zero.
I know Brightstars are kinda cheap, but I'm starting to think its not the balast (I've already ruled out the ignitors by swapping side to side). Maybe a dead relay is sending current through ground or pulling up the 12v?
Any trouble shooting tips would be appreciated.
Steve
fragment is offline   Reply With Quote
Old 06-01-2005, 02:24 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There may be a bad ground in the dash area. Also check the grounding near the lights. Some Subaru models make a ground connection for the headlights to turn on. Yours may be the same. You could make a ground jumper with a long lead that is tied to the negative of the battery and the other end to the dash area. If that helps then try to find the bad ground lead.
Old 06-01-2005, 06:18 AM   #3
John UK
Member#: 81042
2000 5 door turbo
You've got a bad earth somewhere. A low beam is earthing through bot hig beams. This causes the high beam warning light to see about 5 volts so it glows dimly.
John
John UK is offline   Reply With Quote
Strange turn signal gremlin Kraziken Legacy Forum 5 05-25-2007 09:52 AM
Overheating Gremlins (Update) Tattoo Collector Normally Aspirated Powertrain 2 10-07-2002 05:39 PM
Overheating gremlins back Tattoo Collector Normally Aspirated Powertrain 10 09-27-2002 12:12 AM
Gremlins? Matt South East Region Forum 4 02-06-2001 06:24 AM
Power door locks gremlin glenstiles SVX Forum Archive 2 11-14-2000 08:34 AM
