Old 05-31-2005, 02:37 PM   #1
tahrndt
Member#: 1315
Question Paradise by the (burned out) dashboard lights
Can anyone help me here? My '01 Leg's dashboard light burned out, the one that lights up the gas gage, is this something that I can replace or do I have to get rapped at the stealership and have them do it. Are there any instructions online?
TIA,
Tim
tahrndt is offline   Reply With Quote
Old 05-31-2005, 04:47 PM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
You can DIY.
omahasubaru is offline   Reply With Quote
Old 05-31-2005, 04:49 PM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
did all the lights burn out, or just one? Might wanna check fuses if more than one went at the same time...
as for changing bulbs, you need to disassemble practically the entire dash. Its pretty straight forward and only requires a screwdriver:
Take off shifter surround(pops off).
Unscrew 2 screws holding tray in.
Unscrew 2 screws where ashtray is connected(hard to see/access)
removel center console(pops off)
Remove switch plastic(left of steering colum), pops off.
Then 2 screws above cluster and i believe 2 below where you popped off platic.
take a/c vent/cluster shroad off, disconnect hazard wiring, remove entire piece.
Then theres 6 or so screws holding the cluster on, remove them.
Remove 3 harness', and the cluster is out and you can change bulbs.
Pretty straightforward, but takes a little creative shifting of plastic pieces to get things off with the steering column there. You'll figure it out.
fibuz
fibuz is offline   Reply With Quote
Old 06-01-2005, 08:01 AM   #4
Oquipah
Member#: 9689
1998 Legacy GT
Try a search for HVAC lights or check out ScoobyMods, I know they have detailed instructions with pictures. It's easy to DIY.
Oquipah is offline   Reply With Quote
Old 06-01-2005, 09:11 AM   #5
tahrndt
Member#: 1315
Thanks for the info, it is only 1 light, the left hand one, I can still see the speed - tach gages, so I am guessing it is the bulb and not a fuse.
Looks like I will have a good weekend project.
'Nuther dumb question. The replacement light...is it something I can pick up at a auto parts store or do I have to go to a Scooby dealer to get the light?
Thanks again,
Tim
Old 06-01-2005, 02:10 PM   #6
Oquipah
Member#: 9689
1998 Legacy GT
Someone correct me if I'm wrong, since I'm speaking from a BD knowledge base, but the bulbs can be bought at most auto parts stores or Radioshack. the dealer should stock them as well.
Old 06-01-2005, 04:15 PM   #7
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
yep...
Dashboard lights out...only on the lefthand side Flea New England Impreza Club Forum -- NESIC 10 06-15-2007 10:24 AM
Dark Messiah (new game by Ubisoft is out) trustWRX Off-Topic 11 10-28-2006 02:08 PM
Should I kareokee "Paradise by the Dashboard Lights" at my reception? jblaze5579 Off-Topic 17 04-27-2006 05:26 PM
who else got burned by the time change? alacrity024 Off-Topic 16 04-04-2004 03:28 PM
('93-'01) Dashboard lights out, any advice? Wiring Dia... Max Umbarger Impreza Forum 4 04-17-2001 04:43 PM
