Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 05-31-2005, 04:19 PM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Impreza GC8 20lbs of boost daily what type of axels?
I currently have a 98 2.5rs dohc, im in the process of installing a 93 legacyT block and run 20lbs of boost daily what type of axels would be recomended for such an aplication as this. I would also like to keep the price to a minimum.
2.5rsDOHC is offline   Reply With Quote
Old 05-31-2005, 10:05 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
you should be fine on stockers
Old 06-01-2005, 05:09 AM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
how does 20psi correlate to needing new axles? 20psi on what turbo? 20psi is just a measure of pressure, not power, for example 20psi on a vf10 may give you 200whp, while 20psi on a GT40R would give you 500whp. now that we are done with that lesson, as white2.5rs said, you should be fine on stockers more specifically i bet you will be fine up to 300whp+, it all depends on how you drive.
Ben
Old 06-01-2005, 10:51 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah unless you drop the clutch everywhere you go...youll be fine
Men-Types - Do you buy clothes at REI? What types of shirts do you wear? Sharkbait Off-Topic 192 07-26-2008 02:16 PM
What type of axels are on a 03 JDM forster turbo? AFBeefcake Transmission (AT/MT) & Driveline 0 06-03-2005 07:45 PM
New owner of 05 STI what type of suspension mods to do? 1 BLOWN V8 Brakes, Steering & Suspension 24 10-04-2004 05:48 PM
What type of boost controller (if any) should i get for my WRX? Magman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-13-2003 12:03 PM
R180 diff uses what type of axels? alex_umn Transmission (AT/MT) & Driveline 2 02-22-2003 08:55 PM
