Old 05-31-2005, 11:48 PM   #1
jayan357
Member#: 71099
2002 Impreza WRX
Default Lamco boost gauge is slow.
I bought a used 2002 wrx that already had the lamco steering column boost gauge installed and i noticed the needle moves very sluggishly.
I was under the impression that boost gauge needles were supposed to move quickly so you could accurately read the amount of boost.
Has anybody found a way to speed up the needle or is this thing junk (which would be unfortunate because there are holes in my steering column now)
jayan357 is offline   Reply With Quote
Old 06-01-2005, 12:57 AM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Well, I am not sure how sluggish it is moving for you. But I can tell you there are reasons why the Lamco gauge is a much cheaper boost gauge than some others (Defi, Nexus, etc.). You basically get what you pay for. But regardless of it's sluggishness, the Lamco is better than not having any boost gauge IMO.
offset
offset is offline   Reply With Quote
Old 06-01-2005, 01:24 AM   #3
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
there is a restrictor by the throttle body. this will make it move faster but you will get a tapping noise. i believe the tapping noise is from the exhaust set up causing 2 pulses at the turbo instead of 4.
Joe
scoobdude is offline   Reply With Quote
FS (OH): 07 STi oem column mounted Lamco boost gauge, also JDM Greddy boost gauge... coolblue05 Interior/Dressup/Audio & Security 7 05-21-2009 01:24 PM
FS: 02-03 WRX Cluster, Stock Lamco Boost Gauge, Autometer Boost Gauge SlammedREX Interior/Dressup/Audio & Security 8 03-31-2009 06:07 PM
wtt: lamco boost gauge for vacuum gauge bue car Private 'Wanted' Classifieds 25 02-16-2009 05:22 PM
WTT: Lamco boost gauge + pod for Defi or MD boost gauge + pod wrx2oo2 NWIC Private Classifieds 11 08-27-2008 02:53 AM
Wanna get rid of your LaMco Boost gauge? SoLiDbReAkZ Tri-State Area Forum 10 02-21-2003 09:04 PM
Message Board Statistics All times are GMT -4. The time now is 03:37 AM.
