Old 06-01-2005, 09:39 AM   #1
909
Member#: 18776
Default Need HID diagnosis help, relay?
I have an issue with my 05 STi. I purchased the JDM fogs and they work great. When I installed them I put the OEM relay in as per the directions.
I decided to upgrade to HID H3's and everything went fine with the install. I have used them for several months now and am very happy.
The problem is that sometimes the left or the right will shut itself off, randomly. And sometimes on start up one won't ignite one.
I read that they should be grounded to Chassis, so I pig-tailed an extra ground off the stock wiring and grounded them to chassis with no change in performance.
I read that adding a relay may help, but I'm not sure what kind of relay and where/how to install one for each light. I truely feel that I have a relay issue where it isn't capable of handling the current draw.
Any suggestions?
BTW, the stock HID headlights have not been affected in any way, they work flawlessly.
909 is offline   Reply With Quote
Old 06-01-2005, 12:21 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
1) You are blinding people with HIDs in those fogs.
2) Fogs/ HIDs are worse for visibilty than fogs with proper bulbs.
3) Defintly sounds like an insufficinet current issue to me. Install some separate relays and see what happens.
mcowger is offline   Reply With Quote
Old 06-01-2005, 01:12 PM   #3
909
Member#: 18776
wow, thanks for your insight tard.
1) No I'm not. You aren't even aware of the new H3 bulb designed for H3 fogs.
2) Same as 1, if you paid attention to the HID market you would actually know something about the new bulbs and how they work better than regular bulbs in this particular H3 application. Sure the old ones did, but before you go spout off your "wisdom" get with the program.
3) I already state that. READ.
Old 06-01-2005, 01:30 PM   #4
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Hmm, I was going to send you my wiring diagram for a relay setup, but after that response, you can get it somewhere else.
Old 06-01-2005, 04:12 PM   #5
909
Member#: 18776
Thanks anyway, I just figured it out on my own. We'll see if the relays remedy the issue long term.
HID kit without relay whiterice42019 Electrical & Lighting 5 10-28-2006 01:34 AM
Diagnosis Help? Since the SE is so cool zoomfactor South East Region Forum 14 01-09-2004 12:09 AM
I need HID help, you guys are my last hope! grundig5 Electrical & Lighting 14 09-29-2003 10:46 PM
need a diagnosis TerenceT Brakes, Steering & Suspension 3 07-18-2003 07:52 PM
diagnosis help nyaconis Transmission (AT/MT) & Driveline 2 06-14-2003 01:32 AM
