Welcome to the North American Subaru Impreza Owners Club Thursday April 2, 2015
Old 08-02-2001, 01:51 PM   #1
GarySheehan
Member#: 2450
1996 2005 Subaru STI
Default Warning-Torque Spec Error in Shop Manual for Cam Shaft Cap Bolts
This may be common knowledge, but I figured I'd let you folks hear about what we learned the hard way.
The shop manual calls for 14.5 ft/lbs of torque (20 N-m) for all of the cap bolts that secure the camshaft to the head. The front cap is the one that holds the camshaft oil seal and has bolts that are thinner than the other cap bolts. This torque spec is way too high for the front cap bolts. If you try to torque to this spec, you will be left with half a broken bolt in your hand and the other half lodged in the head.
The proper torque is around 8-9 ft/lbs.
Gary
Sheehan Motor Racing
#72 Subaru WRX USTCC
www.teamSMR.com
GarySheehan is offline   Reply With Quote
Old 08-02-2001, 01:54 PM   #2
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
You found that out the hard way I gather.
It sucks how much one little type-o can screw your whole day up.
Scoobyslack1 is offline   Reply With Quote
Old 08-02-2001, 03:49 PM   #3
trboCIVIC&WRX
Member#: 6426
Thanks a ton, I'll correct that in the manual when I get home. That was extremely thoughtful of you to bring it to our attention.
trboCIVIC&WRX is offline   Reply With Quote
Old 08-02-2001, 04:37 PM   #4
GarySheehan
Member#: 2450
Fortunately, the bolt pulls apart under tension at so low a torque that none of the threads in the aluminum head get damaged. We were lucky enough that the end of the bolt in the head unscrewed with a little finesse. Thankfully it didn't get jammed in there.
So we're on a hunt for new cam cap bolts because we need to fire the motor up tonight!
Gary
www.teamSMR.com
Cam bearing cap bolts caz1562 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2003 05:00 PM
need shop manual for my '00 RS aussiebrydon Bay Area Impreza Club Forum -- BAIC 1 11-08-2001 02:23 PM
Those with shop manuals for WRX ... need stock alignment specs LttLDGN Brakes, Steering & Suspension 2 11-01-2001 12:00 AM
Shop Manual for a 98 2.5 RS? tsfxRS New England Impreza Club Forum -- NESIC 4 08-06-2001 11:16 PM
Anyone with shop manual for MY00? (O2 Sensor ?) BugBomb Technical Forum Archive 1 06-11-2000 12:13 AM
