Old 06-01-2005, 01:12 PM   #1
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Default The Legacy motor swap thread
I'm curious, how many folks in the Legacy group has gone thru with a motor swap.
Things I'm curious about.
What motor you chose.
Power mods you did after the swap.
Pics? Just want to see pretty pictures of Boosted motors in the Legacy.
Bragging rights (timeslips, dyno runs)
It will be a few months before my swap, but I'm already looking at what power mods to do after the intial swap.
Kraziken is offline   Reply With Quote
Old 06-01-2005, 01:38 PM   #2
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
I'm working on a swap for my friends 98 legacy.
2002 WRX motor with 2003 JDM Forester 5 speed.
I hope to have the motor and trany installed tonight.
AFBeefcake is offline   Reply With Quote
Old 06-01-2005, 01:40 PM   #3
RoundtheBend
Member#: 5034
2004 Money Pit
silverish-mud
Car: '96 Legacy LS w/ '99 GT front bumper and hood
Swapped: 2003 JDM ver8, ver6 STi RA gearset, STi helical front LSD, STi 20kg center LSD, Cusco type-RS rear LSD.
Power Mods: 34mm restrictor, custom 3" exhaust
Pics:
Bragging rights: 7th overall, 2005 ROTW
Note: It is a rally car after all.
RoundtheBend is offline   Reply With Quote
Old 06-01-2005, 01:40 PM   #4
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
AF: I may need to speak with you @ the wikked big meet...
are you going?
iamrazor is offline   Reply With Quote
Old 06-01-2005, 02:06 PM   #5
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
How much does one need to set aside for this project? I am starting to save for a swap in the BE in about a year I hope. Are most people getting used motors or buying them new from someone? Also anyone know if the stock 5 speed tranny from a BE will bolt up and handle the power?
Just want to start getting info together now.
Thanks
bhall is offline   Reply With Quote
Old 06-01-2005, 02:27 PM   #6
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
stock BE tranny shoudl be fine unless you drop an STi 2.5 in and go crazy with power mods. The Legacies trannies are supposedly beefier than the WRX.
.02
Jared
gtwagon941 is offline   Reply With Quote
Old 06-01-2005, 04:30 PM   #7
Teh Legacy
Member#: 9853
to keep your mouth
shut.
I plan on doing an EJ22T build up after mine is paid off. Will probably be going with EJ25 SOHC heads and a LINK for engine management. I don't have a turbo picked out yet, but as a teaser, I plan on 20+ PSI on the stock transmission with STi (non R/A)5 speed gears.
Now I just need a second job to hurry up the "paying off" process.
Teh Legacy is offline   Reply With Quote
Old 06-01-2005, 04:50 PM   #8
Bakergtt
Member#: 59207
'05 X was 98 LGTT
can i just post my mod list?
Bakergtt is offline   Reply With Quote
Old 06-01-2005, 05:34 PM   #9
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
Car:96 legacy, 2.5 gt
swapped: 95 Sti Ver 2 RA engine/transmission, custom 3 inch exhaust, bunch of other crap
Tizzle is offline   Reply With Quote
Old 06-01-2005, 06:11 PM   #10
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
are you going?
Well, I don't know anything about this meet yet.
Old 06-01-2005, 07:12 PM   #11
Kraziken
Member#: 38629
I'm unfamiliar with the JDM Forrester tranny.
What are it's benefits? Lower gearing?
Old 06-01-2005, 07:50 PM   #12
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Well some of the gears are different, but that was what came with the motor.
Old 06-01-2005, 07:58 PM   #13
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
You sure it wasn't a Forester turbo motor that came with that Forester tranny?
Cheers,
Paul Hansen
www.sevenphotos.com
www.apexjapan.com
AVOjapan is offline   Reply With Quote
Old 06-01-2005, 09:27 PM   #14
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Engine Management
LinkPlus EMS Plug and Play
w/boost control not currently used, and ambient air sensor
TurboXS MBC
HKS turbo timer
Motor
EJ22T short block w/oil squiters closed deck
Pauter connecting rods
Ceramic/molly coated cast pistons
ARP head studs
JDM V.2 DOHC heads w/~7.8CR
STi timing belt
OE MY98 intake mainfold + TB
Billet fuel rails w/Bocsh 550cc top-feed injectors
PVC vent canister
SYMS radiator cap
HKS filter
*UR underdrive pulley
*255lph fuel pump
Turbo and Exhaust
Garrett t3/t4 custom, oil and water cooled, .57 trim and .63a/r
Tial 35mm wastegate routed down stream on DP
Greddy Type-S BOV
TMIC Spearco core 19*(w)2.5*(d)9*(h)
Borla N/A header
2.25* up-pipe
3*TBE w/3 chamber DynoMax
Drivetrain
OE GT 5 speed 4.11
ACT Stage 2 clutch
SYMS short throw shifter
STi motor mounts
STi tranny mount
RedLine fluid
*lightened flywheel (14lbs)
Old 06-01-2005, 11:08 PM   #15
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
www.subarumeet.com
check it..
Old 06-01-2005, 11:29 PM   #16
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
well I tried to get the motor and trany in, but we had a problem with the axle stubs not staying in the trany.
Old 06-02-2005, 01:37 AM   #17
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I am also interested in a cost analysis. Is swapping in a newer, more powerful motor going to mean you also have to upgrade CV joints, axles, and diffs, or is swapping in a motor a plug and play affair (ie. drop it in, bolt the stock tranny up, figure out the wiring and you're done)?
I was thinking in a few years I'll probably want a new car, but I love mid nineties styling and unsuspectingly quick cars, and if I can get away with say, a $6k investment into motor/trans (wrx turbo motor), paint, and bushings/suspension, it'd be like having a new car for less. But then I think of a car with 150k miles on it, getting a strong young motor, and I cringe at the thoughts of parts breaking like crazy. Your guys' thoughts?
Plays_With_toys is offline   Reply With Quote
Old 06-02-2005, 04:08 AM   #18
RoundtheBend
Member#: 5034
2004 Money Pit
silverish-mud
We upgraded the internals (ver6 STi RA gearset, uprated diffs) of the stock tranny and otherwise kept the stock running gear (axles, etc.). We're just now (after two rallies, including ROTW) upgrading to a WRX case because of the clutch options available for the WRX that aren't available for the LGT/RS tranny.
I'm not an expert though, I just campaign a legacy rally car.
Short answer, you should probably think about upgrading your gearset but the rest of the '99 2.5GT parts seem to be up to the task. YMMV
Old 06-02-2005, 08:44 AM   #19
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Originally Posted by RiosubaGT
Engine Management
TurboXS MBC
HKS turbo timer
Motor
ARP head studs
STi timing belt
PVC vent canister
SYMS radiator cap
HKS filter
*255lph fuel pump
Turbo and Exhaust
Greddy Type-S BOV
Borla N/A header
2.25* up-pipe
Drivetrain
OE GT 5 speed 4.11
ACT Stage 2 clutch
STi motor mounts
STi tranny mount
RedLine fluid
How much did all this cost you? It's basically the same thing I'm looking to do.
Old 06-02-2005, 11:53 AM   #20
Bakergtt
Member#: 59207
'05 X was 98 LGTT
Its about an 8k set up cuz everything was custom at the time.
Old 06-02-2005, 10:10 PM   #21
Kraziken
Member#: 38629
The motor I got was a 2004 USDM WRX motor. Only 2000 miles on it. $3k for motor, turbo, ecu, intercooler, complete wiring, wrx fuel pump.
I was going to just use a heavy duty clutch on my Legacy, but the one I ordered from Rallitek was meant for a WRX, so instead of returning it, I figured I'll go with a WRX tranny, it is stronger.
I wish I had the time to learn how to do it myself, but I don't, so factor in the labor, and I'll be right around the $6k mark you've mentioned. As far as the other parts on my car, I've swapped out a lot so most of the "wear" parts on my car are fairly new.
Old 06-02-2005, 11:44 PM   #22
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Engine:
2002 WRX Engine
STI 565cc Pink Injectors
Perrin Turbo Inlet
Perrin Intercooler Hoses
K&N Typhoon Intake
Walbro 255 litre Fuel Pump
Engine Management and Electonics:
Defi BF Boost Gauge (Oil Temp, Oil Pressure, and EGT coming soon)
Defi Center Gauge pod for WRX (Coming soon)
Ecutek Reflash by me
Turbo and Exhaust:
IHI VF34
Hyperflow TMIC Coming Soon
Stock Gutted uppipe
3" Perrin TBE (Modded to fit the legacy)
Transmission:
2002 WRX Tranny Case
1999 Legacy GT Gears
1999 Legacy Front Diff
1998 Outback Rear Diff
1991 Turbo Legacy Transfercase and Center Diff
Exedy Stg 1 Clutch (For WRX)
STI Short Throw Shifter
RedLine fluid
Brakes:
JDM Red 4pot Front Calipers
Stock WRX Rotors
ATE SuperBlue Fluid
wrx_driver_2002 is online now   Reply With Quote
Old 06-02-2005, 11:51 PM   #23
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Before I started on my swap, my 1995 Sedan had 165k on the clock. Still on stock suspension. (Kyb AGX coming soon). My dad's car had almost 300k on it when he did his swap (1990 Legacy Wagon with Version 2 STI drivetrain).
Old 06-03-2005, 01:34 AM   #24
Tizzle
Member#: 44472
Ver2 Legacy StiRA
looking good Mike!
Old 06-03-2005, 01:37 AM   #25
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
look up xcntrk75. that car is badass. (all but the red anyhow, IM[very]HO. black or dark blue or silver... mmmmm ) $5,000 i think, but thats with all drivetrain bits, and his work.
ooberdoob is offline   Reply With Quote
The MWSOC trunk swap thread Hondaslayer MWSOC Private Classifieds 1346 11-30-2016 12:54 PM
The new trunk swap thread 1st quarter 2010 Hondaslayer MWSOC Private Classifieds 62 04-06-2010 09:07 AM
Legacy motor swap YamazakiSubaru Subaru Conversions 1 04-25-2009 10:04 AM
Please help me, 99 legacy motor swap spdracr00 Legacy Forum 8 08-01-2005 11:03 PM
96 subaru legacy motor swap fastlegacy Subaru Conversions 3 07-22-2004 07:36 PM
