Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 06-01-2005, 08:48 PM   #1
sti_crazy2
Member#: 88333
Default Autometer boost guage install help!!!
can anyone give a detailed description of how to wire up the electronic autometer boost guage to a 97 V3 STI, with pics would be usefull, i have looked all over the site and can only see guides for MY2000+
i also have searched the net and it has been a pain.
thankz in advance
sti_crazy2 is offline   Reply With Quote
Old 06-01-2005, 11:42 PM   #2
sti_crazy2
Member#: 88333
and bump again
Old 06-01-2005, 11:42 PM   #3
sti_crazy2
Member#: 88333
someone in this forum must be abale to help!!
Old 06-01-2005, 11:45 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are you in the US? We didn't have that model here in 97. Regardless, hooking up a boost gauge is not difficult, you need a direct manifold connection for the sensor and switched 12V for the power.
Old 06-02-2005, 06:11 PM   #5
sti_crazy2
Member#: 88333
no i'm not in the US? oh ok, yeah i know where to put the T peice, i just need to know which wire where behind the dash also i want to know if you can put multiple gauges on the same 12V volt source. if you could help me with where to hook up the inigtion wire, + and - wires, and i think there was another wire too i would be sweet.
thanx
Old 06-02-2005, 06:12 PM   #6
sti_crazy2
Member#: 88333
oh yeah, would it be the same wiring as your model STI's
Old 06-02-2005, 06:15 PM   #7
sti_crazy2
Member#: 88333
oh yeah the last wire was the black ground wire, can you just hook that up anywhere on the chasis and it would be ok.
Old 06-03-2005, 08:28 PM   #8
sti_crazy2
Member#: 88333
damn doesn't look like anyone wants to help here too!!
Old 06-03-2005, 08:49 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Geez don't be so impatient, do you really expect an instant response whenever you post?
Anyway I doubt it is the same as a USDM STi, which is a GC chassis MY04-05 vs. your GC chassis MY97. Although there may be similarities the actual wiring is different including important things like wire colors, circuit designations etc. I would suggest that you obtain the wiring diagram for your particular vehicle which will answer all of your questions, alternately you can check in on other forums where they are familiar with your model such as Scoobynet in the UK.
Old 06-03-2005, 09:49 PM   #10
dscoobydoo
Member#: 57152
---- Subaru fleet
garage ( 5 and counting)
OK, the standard autometer boost gauge has the vacuum fitting and the white/black for the light. The black ground can be put just about anywhere. You should tap into the radio harness ( dash adjustable) lighting for the light ( the white wire on the gauge) . That way it is controlled by the same reostat.
dscoobydoo is offline   Reply With Quote
guage pod for Autometer boost guage JPinn Private 'Wanted' Classifieds 0 03-07-2006 05:33 PM
Need help quick w/ Autometer boost/egt install 05 WRX Ohannon7 Interior & Exterior Modification 5 07-25-2005 07:50 PM
boost guage install help wrxnut South East Region Forum 15 01-28-2005 10:27 AM
Autometer Boost guage. Help needed guage is reading wrong. Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-30-2002 01:46 PM
Autometer boost guage install pics. Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 09-18-2001 03:09 PM
