#1 |
Member#: 36303
TXIC
Vehicle:06 Evo IX silver |
ok master tuners:
I think I have a fuel trim problem. when I start the car up in the morning it runs just fine. By the time I get to my first stop sign though, my engine has reached normal operating temparature, and when I push the clutch in and let off the gas my rpms plumment to like 300 (for a split second), rebound to 750 and I get a CEL. a minute or later everything is peachy. When I let off the gas the needle drops quickly until about 1500, where it's fall slows noticably and it settles into idle nicely. Every single morning it is the same thing: CEL at my first stop sign. My guess is that the ECU learns one set of fuel trims when the engine is cold, and when the motor is warmed up those fuel trims cause the engine to stumble (upon letting off the gas) for the minute or so it takes for the trims to re-learn. Anyway, that's my hypothesis. Anyone have thoughts or advice on how to fix? I do have deltadash and a TXS tuna. I should mention that this is on a hybrid WRX/STI motor with modded stock injectors. The problem is especially bad if I let off the gas right after the car being under load (i.e. hauling ass before stoping at the first stop sign).
#2 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
So what kind of EM are you running with this? UTEC?
#3 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
Try this.....
In the am when the car is as cold as it is gonna get.......do an ECU re-set. Get in the car and start the car WITHOUT TOUCHING THE THROTTLE AT ALL. Let the engine come to operating temp....the fans will come on when it is at temp.....Shut the car off, and take the key out. Start the car and drive it normally. See if that helps. |
#4 |
Member#: 36303
TXIC
yes UTEC
Uncle Scotty: Are you suggesting that as a permanent fix? Thanks |
#5 |
Member#: 16200
....I'm suggesting it as a potential cure for the current issue.......if you have not reset the ECU for a while, it may just work wonders for ya.
#6 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
If you have DeltaDash, then check what your fuel trims are once the car is fully warmed up.
Air/Fuel Learning #1 <-- The important one Air/Fuel Correction #1 <-- This should be oscillating at/about 0%. If not, wait longer. ![]() Report back with your results. Also, exactly what CEL are you getting? (read this using F4 in DeltaDash) |
#7 |
Member#: 36303
TXIC
the CEL's are MISFIRE 1,2,3,4
I'll check the fuel trims and report back. |
#8 | |
Member#: 27108
Many people are noticing that if you turn the key to the "ON" position and then WAIT for a few seconds before actually starting the car, most "cold misfire CEL" issues go away. |
#9 |
Member#: 36303
TXIC
I start the ignition, let the fuel pump prime and start the car. the cels are n't when it is cold. it throws the cel right after it gets warmed up.
the problem is worse if I am on the brakes, by the way. I have quadruple checked every single fitting and hose already looking for a vac leak, by the way... |
#10 | |
Member#: 16200
...how about the brake booster hose.....????? |
#11 | |
Member#: 27108
#12 |
Member#: 36303
TXIC
I know it's not leaking coming out of the intake, but it may be leaking by the booster. I'll check tonight.
Thank you very much for the help everyone. I'll be sure to post the cure once I figure it out.... |
| Thread Tools | |
| Display Modes | |
| High Idle not dropping once operating temp is reached | vica153 | Pre-2002 Factory Turbo Powertrain | 1 | 06-20-2009 04:11 PM |
| OT computer gurus: GPU operating Temp question. | wvallwheeldrive | Off-Topic | 2 | 05-17-2008 07:32 PM |
| Fuel trims off causing start & stall? | overdose | Engine Management & Tuning | 3 | 04-11-2005 09:42 PM |
| stalls out after re-fuel | Womble407 | Factory 2.0L Turbo Powertrain | 4 | 03-16-2004 04:30 PM |
| stall out right after start up cold | Ahzlon | Normally Aspirated Powertrain | 8 | 10-24-2003 11:10 AM |
