Old 05-30-2005, 12:14 AM   #1
02blue4you
Member#: 87008
gng njyjyj
njyjn
Default 1/4mile cobb vs. vishnu
i would like to see your timeslips of cobb stage 2. against vishnu stage 1 im leaning towards getting a accessport, but vishnu seems ok. and also what problems do they have
02blue4you is offline   Reply With Quote
Old 05-30-2005, 01:03 AM   #2
my_sti_1
Member#: 86713
04 STi GT35r .82
C16 Java Black Pearl
i have a vishnu stage 1 with a 100 octane map.
dyno dynamics: 307whp
dynojet: 335 whp
i should see a time of 12.6. i was planning on going to infineon on wednesday to time my sti but i just had my coilovers installed and the camber on the rear is too negative about -1.7 and there is not enough traction. i just raced a camaro and both 1st and 2nd gear was spinning. i never done that before. i thought it was pretty cool but i know my time will suffer so i'll have to get some rear camber bolts and have it realigned again with some r compound tires before i hit the 1320...sorry.
my_sti_1 is offline   Reply With Quote
Old 05-30-2005, 01:19 AM   #3
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
my_sti_1, have you dyno'd w/ a 91 octane map just wondering? I have a feeling he's talking about a wrx however.
02blue4you, cars have large variances in power even with the same mods and the same tuner. Since you are considering an accessport, I'm assuming you aren't getting your car tuned. If so there is just so much variance depending on what brands of hardware you are using. Problems with Cobb: some people have been running lean. But then that's a problem with "mail-order" maps in general.
Anyways my point is that you are asking people to give you timeslips in order to conduct research as to which reflash to go with and I'm just saying that's not the best way to go about it. It's more important that you get tuned (or tune yourself).
verc is offline   Reply With Quote
Old 05-30-2005, 07:02 AM   #4
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Yep, I have a feeling that a Vishnu Stage 1 WRX would not put down 335awhp on a dyno, any dyno, even on race gas.
I also make the assumption that he would like this done on pump gas.
I want an STI
BlackEyeII is offline   Reply With Quote
Old 05-30-2005, 10:28 AM   #5
02blue4you
Member#: 87008
gng njyjyj
njyjn
yea i was talking about wrx but yea i was planning on learning more about tuning and do it myself i was also thinking about utec
Old 05-30-2005, 10:40 AM   #6
my_sti_1
Member#: 86713
04 STi GT35r .82
[quote=verc]my_sti_1, have you dyno'd w/ a 91 octane map just wondering?
yes i had a map on 91 octane.
dynamics: 263whp
dynojet:284whp
numbers are with a catalytic converter. nothing special. i like my 100octane numbers better.
Old 05-30-2005, 03:22 PM   #7
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
My best with COBB stg 2 was [email protected] in cold weather-60 degrees(I had like 10-20 passes with this setup).
Best so far with Vishnu stage 1 is [email protected] in hot weather(80+ degrees).
I dont race at a fast track(always a headwind), and I run on 91 octane. Most of the fast COBB stg 2 WRX's are being run on 93octane and are on the east coast, not in cali. I have way more power with the Vishnu now, but my timeslips dont show that....however, my dyno charts do. Remember that the ET's are "mostly" the driver, and the trap speed is mostly how much WHP the car is putting out.
Drews_WRX is offline   Reply With Quote
Old 05-30-2005, 03:53 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Kind of contradictory. :wink:
Just kidding, but you should have said "But my TIMES dont show that not TIMESLIPS" because as you pointed out your trap does show you are making more power, in hotter weather too good job.
I would go away from Cobb from what I have read on here. Times/power dont seem to be up to par with the utec and ecutek.
You need to really think about what you want before you buy the EM.
Heres my little list of pros/cons between UTEC and Ecutek:
UTEC
Pro - Plug and Play, no tuning REQUIRED
Pro - Can have different maps (street and race gas)
Pro - Can tune yourself if you so desire
Con - The UTEC will run where you tell it to, and if conditions change enough it could be bad to your engine
Ecutek
Pro - Ecutek still keeps all the stock safety measures in place. If you start detonating it will pull timing and save your motor.
Pro - Keeps the "learning" function. If you add higher octane gas ecutek will add timing accordingly.
Con - As of yet, cant have maps
Con - As of yet, cant tune yourself
Con - Tuning is required, you have to pay for the software and then pay for the tuning
If any of thats wrong correct me. I know people have been saying that Ecutek is supposed to be releasing self tuning devices and adding the capability to have different maps, but i have heard that it was released yet.
I had the UTEC before, but switched to the Ecutek. I am kind of mad that i did because i really want a race gas tune. Now if i want one I either have to get a UTEC and run it in conjunction with the Ecutek software or buy another ECU and get a race gas tune on it and switch out ECU's when i go to the track.
The hydra is supposed to be pretty good too. Its pretty cheap for stand alone EM too.
Old 05-30-2005, 07:31 PM   #9
1CLNWRX
Member#: 58994
2011 WRX Limited
If you spend $500+ for an accessport, why not spend the extra cash and go with an ecuteck reflash and custom tune. Many cars are 240whp+ on a dynojet with stock turbos going this route, including mine. It cost me $750 for the tuning session and reflash tuned by Shiv from Vishnu. Reliable power for the past 8months. Only problem is if I upgrade the turbo, additional tuning would be necessary. Since my tune though, for me it is plenty of power for a daily driver. It will still accomidate minor mods and "learn" a little bit, but additional fuel and air would require a re-tune. It all depends on where you want to take your car. For me I knew I was stopping here and am fine with it knowing I have the "most" out of my setup and it is a custom tune. Obviously if you can, any custom tune is going to be better than an off-the-shelf map/program. But for the additional $250 it was worth it to me. good luck sorry, no times. Raced an M6 C5 though. From a roll, ate my friend up until third then he just left me. From a stop he was done up until about 90mph IIRC then he started to pull. Maybe mid-low 13sec on a track.
1CLNWRX is offline   Reply With Quote
Old 05-30-2005, 09:01 PM   #10
Timmysubie
Member#: 67043
2005 WRX
CGM Cobb stage 2!!
Good tuners arent everywhere.
Timmysubie is offline   Reply With Quote
Old 06-01-2005, 08:45 PM   #11
dagspeed
Member#: 88334
2005 STI
Grey+'00Mustg.w/manymods
my_sti_1 where did you get your dynotune done? i just ordered vishnu stage 1 with xede, i am going to have shiv dyno tune both 100 octane and 91. i like your numbers!
dynamics: 263whp
dynojet:284whp
dagspeed is offline   Reply With Quote
Old 06-01-2005, 10:14 PM   #12
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
eachother.
(i crack myself up)
MeetMrGlock is offline   Reply With Quote
Old 06-01-2005, 10:56 PM   #13
my_sti_1
Member#: 86713
04 STi GT35r .82
dynamics: 263whp
dynojet:284whp
hayward CA. boss performance shop. Shiv has his dyno there. Let him know that you want my map and he'll hook you up. Someone had these numbers before me and he used the 100 ocatne map and adjusted it specifically to my car. it took 10 minutes and that it.
$200 for dyno tuning time
$65 for test pipe tuning.
Old 06-01-2005, 11:16 PM   #14
wrxtony
Member#: 69422
2004 WRX Sedan
Blue and blue.
I have a Cobb Stage II (91) with only a Helix downpipe, no exhaust yet, and I ran a 13.8 with a crappy 1.95 60-foot. A 1.8X 60-foot, which I was getting consistently when I was stock, and I would have easily gotten a 13.6 or even a 13.59 Add an exhaust and an uppipe and even better. I'm perfectly happy with my Cobb AP and I would highly recommend it. I just need to work on my launch.
Tony
wrxtony is offline   Reply With Quote
Old 06-02-2005, 01:42 AM   #15
MARKGSTI
Member#: 70197
a extra $65 cause you have a test pipe>>>whats that about?
MARKGSTI is offline   Reply With Quote
Old 06-02-2005, 02:21 PM   #16
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
Shiv lung replacement down the road
Old 06-02-2005, 03:19 PM   #17
MARKGSTI
Member#: 70197
Thats B.S.
To each his own i guess...
BTW when you gonna hit up the track next time??
Old 06-02-2005, 03:22 PM   #18
Bryan Frye
Member#: 87891
2004 wrx
i have cobb stage 2 i've ran a 13.1
Bryan Frye is offline   Reply With Quote
Old 06-02-2005, 03:59 PM   #19
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
Thats B.S.
eerr...dont know. The clutch is going away slightly, which is another $500+, but Im always eager to see what she can do with my new found power. I might wait til the weather settles down a bit, I always seem to race in the heat.
FWIW-my buddies E500 sees my taillights often
Old 06-02-2005, 04:01 PM   #20
1CLNWRX
Member#: 58994
2011 WRX Limited
stock turbo on that stage 2? Best I've seen on here is mid-high 13s. Slip from the track, or is this g-tech? This is afterall the proven power bragging forum. Not calling BS, just looking for more definitive proof.
Old 06-02-2005, 04:14 PM   #21
yamez
Member#: 60639
2008 135i
graphite
i just bought a vishnu stage 1 unichip from a fellow member on here for 100 bucks.... uppipe/downpipe/unichip get installed this weekend i will give a follow up after install.... and some track times next week
yamez is offline   Reply With Quote
Old 06-02-2005, 04:44 PM   #22
INTEGRAtoWRX
Member#: 13931
02 WRX
13 Boss 302
This works if you live relatively close to a tuner. The nice thing about accessport though is that you can switch it back to stock anytime you need to, use the anti-theft map, and can read/clear CEL's etc....(which is nice in Ohio since we fail E-check if we have any CEL's) Also, since the AccessTuner is out, you still have the option to hit up a shop for a custom tune.
INTEGRAtoWRX is offline   Reply With Quote
Old 06-02-2005, 05:06 PM   #23
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
Just for comparison, I run a Cobb 2.5 w/93octane and my best is [email protected] in 1000 ft. I don't have a 1/4 track in the entire state. Yes, it's not a Cobb stage 2 like the thread asked, but...
jikhead is offline   Reply With Quote
Old 06-02-2005, 09:30 PM   #24
1CLNWRX
Member#: 58994
2011 WRX Limited
If you can, get a custom tune. That is all I am saying. Not only do you get more power in most cases but if there are going to be any issues you will more than likely work them out on a dyno. Mailing in your ecu to a company for a reflash or buying an accessport works, but it is not the most efficiant and is not specific to your car. When I went and did mine I drove for almost an hour. A guy that was there drove like 3hrs from CT to Norhtern NJ. It is up to you what you want in the end.
Old 06-02-2005, 10:40 PM   #25
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
[quote=jikhead]best is [email protected] in 1000 ft. I don't have a 1/4 track in the entire state. QUOTE]
Lol...thats like a top fuel drag time that launches and just coasts the rest of the way down the track.
Swine is offline   Reply With Quote
cobb vs vishnu WRXer187 Engine Management & Tuning 5 08-10-2005 02:23 PM
cobb vs vishnu vs xxxxx ? pissedoffsol Engine Management & Tuning 9 08-07-2005 10:08 AM
COBB vs. Vishnu? CarsonFranklin Engine Management & Tuning 14 08-30-2004 07:01 PM
Cobb vs. Vishnu vs. TurboXS xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 50 04-30-2002 11:35 AM
