Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 06-02-2005, 09:43 AM   #1
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Default Big brake kits?
Has anyone researched larger brake kits for the Baja? The stock front rotor is 11.4" on the Turbo. I was wondering if there was a Brembo or Stoptech kit that would work.
Would a kit for a WRX/STI work? I'm thinking yes but want to make sure.
Cobb lists 328mm (12.9") front kit on their "hidden" Baja page:
http://cobbtuning.com/baja/
thanks.
02_Forester is offline   Reply With Quote
Old 06-02-2005, 09:51 AM   #2
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
there are a few out there but it's BIG MONEY i'm not sure if i would make that move with needing brakes first..
Fully cast and CNC machined aluminum to ensure the highest quality; Rotora's new 4-piston caliper brake system enables better controlled braking and achieves better brake pedal feel and overall brake performance gain by increasing the clamp load/force to the optimum level of the caliper while still utilizing the stock master cylinder. The new front brake system includes a set of 1-piece cross-drilled and slotted vented "e-coated" black rotors (330mm or 295mm, depending on application), a set of 4-piston calipers (red or blue caliper of your choice), high carbon steel (S45C) mounting brackets, Rotora street performance pads, and stainless-steel braided front brake lines (DOT approved). All Rotora brake systems are direct bolt on replacement of the stock front brake system with minimal modifications required (ex: some applications requires the removal of the stock dust cover shield).
Subaru Impreza WRX, Forester XT, Baja Turbo, Legacy GT, 2002-2005
Front - RBK11.01 4-PISTON 330X24 1-PIECE (13'' rotor) - $1,495.00 - 17'' or 18'' wheels
Front - RBK11.04 4-PISTON 330X30 2-PIECE (13'' rotor) - $2,095.00 - 17'' or 18'' wheels
Front - RBK021.05 6-PISTON 330X30 2-PIECE (13'' rotor) - $2,595.00 - 17'' or 18'' wheels
Rear - RBK16.01 2-PISTON 290X18 1-PIECE (11.5'' rotor) - $1,095.00 - 17'' or 18'' wheels
Rear - RBK16.04 4-PISTON 330X30 2-PIECE (13'' rotor) - $2,095.00 - 17'' or 18'' wheels
http://xcceleration.com/itemdetails.cfm85.htm
they seem to have a number of items for the Baja I'm looking at the full exuast..
holland_patrick is offline   Reply With Quote
Old 06-02-2005, 11:31 AM   #3
iON Performance Inc
Vendor
Member#: 7673
02_Forester - Chris, we have several different BBK's that we offer. Our 310x25mm version will even fit your factory Baja wheels
iON Performance Inc is offline   Reply With Quote
Old 06-02-2005, 11:34 AM   #4
BajaNut
Member#: 36905
2014 Outback SAP
leggtnut on lgt.com
www.rallitek.com carries a couple of break upgrades as well.
BajaNut is offline   Reply With Quote
Old 06-02-2005, 08:07 PM   #5
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
ive looked at a lot of brake upgrades, but dont know if i can spend the 1500-3000 per set... im guessing that the legacy aftermarket brake kits will fit, correct me if im wrong... ion performance, im interested in what you have to say, i went to your website but no links would work so i couldnt check stuff out, and you didnt seem to have the baja on there anyway... what is the largest rotor you can fit under the stock 16's ? im guessing a 12 or 12.5? thanks for choosing to cater to us 'outcasts' that love their bajas, ion!
cliffhanger is offline   Reply With Quote
Old 06-02-2005, 08:11 PM   #6
cliffhanger
Member#: 80446
2005 5spd Baja-T
oh, 310mm x 25mm lol, ok how much slotted, drilled, material, pics? thx
Old 06-03-2005, 04:47 PM   #7
iON Performance Inc
Vendor
Member#: 7673
cliffhanger - Here are the details ->
Technical specs: (Please note that these are the largest & lightest BBK's to fit under the factory 16x6.5" wheels)
[FRONTS]
Calipers
- Custom AP Racing CP5100
- 4 x 38.1mm pistons
- Dust Seals
- DOT compliant
- 1.9kg/caliper
- Compatible pads -> Ferodo DS2000,2500,3000; Pagid RS14B, RS42; PFC 83, 93
Rotors
- 12.2" (310mm) x 0.98" (25mm)
- 2-piece system. CNC machined billet aluminum hat.
- SS NAS fastening hardware (same hardware used in F1 & CART)
- Directionally vaned/vented (48 vanes, same design as AP Racing)
- Available in either x-drilled, slotted or plain
-> Calipers & hardware weighs in at a feathery 4.50lbs each side (this is the caliper, caliper mount and SS lines)
-> Pads weigh in at 2.00lbs each side
-> 12.2" 2-piece rotors weigh in at 11.75lbs each side
Total weight / side = ~18.25lbs vs. Subaru OE 11.4" Rotor w/ FHI 4pots which is approxiately 32lbs. Therefore a total weight savings of 13.75lbs!
This Kit Comes With: (Front Only)
(1) AP Racing 4pot calipers CP5100
(2) DOT compliant SS Brakelines (F&R) & Hardware
(3) 12.2", 2-piece directionally vaned rotors, w/ CNC Billet Aluminum Hat (anodized black) [your choice of slotted, x-drilled or plain]
(4) Chromolly Brake Brackets (anodized black)
(5) Ferrodo DS2500 pads (front)
(6) Ferrodo 5.1 brake fluid (1.5L)
Replacement cost of the rotors are ~ $175US/ rotor. *Note that this is for the bare rotor only and doesn't include the aluminum hat. The Al. hat is reused along with the SS locking nuts. ie: only the outter piece, not the inner piece is $175US/each*
Retail pricing on the front kit is $2549US+shipping, NASIOC member discounted price is $2229.99US + shipping. [Note: this is for payment via International MO, CC via Paypal subject to 5% equalization charge]
Options available:
(a) Thermal indicators on calipers - +$125US/pair
(b) Cryo Treatment on rotors - +$120US/pair
(c) Upgrade to Motul RBF600 brake fluid - +$25US
[Rears]
Calipers
- Custom AP Racing CP5211
- 2 x 38.1mm pistons
- Dust Seals
- DOT compliant
- 1.5kg/caliper
Rotors (vented!)
- 12.2" (310mm) x 0.79" (20mm)
- Multi-piece system. CNC machined billet aluminum hat.
- Directionally vaned/vented (48 vane design, same as AP Racing)
- Available in either solid, x-drilled or slotted
- Retains factory e-Brake mechanism
This Kit Comes With: (Rear Only)
(1) AP Racing 2pot calipers CP5211
(2) 12.2", multi-piece slotted directionally vaned rotors, w/ CNC Billet Aluminum Hat (anodized black)
(3) Chromolly Brake Brackets (anodized black)
(4) Ferrodo DS2500 pads
Retail pricing on the rear kit is $2349US+shipping, NASIOC member discounted price is $2119.99US + shipping. [Note: this is for payment via International MO, CC via Paypal subject to 5% equalization charge]
Options available:
(a) Cryo Treatment on rotors - +$120US/pair
Pictures: (Fronts - Slotted)
(Fronts - X-drilled, optional thermal indicators)
(Rears - Slotted)
Old 06-03-2005, 04:52 PM   #8
iON Performance Inc
Vendor
Member#: 7673
cliffhanger - We do also other brake upgrades that will fit under the factory 16" wheels; those would be more suitable for those not intending to track their car.
We offer 2-piece OEM sized rotors for the Baja in the front, as well as pads, SS lines etc.
We only recommend our BBK to those who'll be tracking the car. Our 310x25mm BBK is designed for those who want to use their factory wheels for racing or in the winter. We only use AP Racing calipers due to their internal dust seals & anti-rattle clips. They are completely DOT complaint; which unlike all of the other brands which aren't.
Old 06-13-2005, 10:52 AM   #9
holland_patrick
Member#: 72014
05 Baja gone
Stage I Brake Upgrade Kit for All Impreza, Legacy, Forester and Baja. When you are looking for braking performance that won't break the bank the Stage 1 kit is the right choice. Braking performance is increased by up to 60% with 40% less dust than the factory setup. Includes everything listed below.
STi Version V and VI 4-pot Brake Caliper Kit. The Subaru 4-pot brake caliper kit comes standard on the STi version 6 in Japan. This is a must have for fast street, Autocross and Track days. Must have 16x7" or larger wheels.
The Kit is a direct bolt on kit including 4-pot calipers, Pins, Clips and CarboTech Bobcat brake pads. Includes CarboTech slotted rotors.
Rear brake rotor 11.3" upgrade kit with Carbotech Bobcat pads. Upgrade the small stock rear rotors with this kit that includes the CarboTech Rear 11.3" slotted rotors and Genuine Subaru caliper brackets. All of the benefits of a rear brake upgrade without the cost.
Direct bolt on replacement. Kit includes Two rotors with left and right caliper brackets.
Russell's patented new Speed Bleeders are the one-man bleeder valves with a stainless steel one-way check ball and spring.
Set of 4 included for a quick one person brake change.
Goodridge Stainless Steel Brake Line Kit for.These race bred brake lines are constructed from the finest quality hose, consisting of a PTFE inner and stainless steel overband. Eliminates sponginess under heavy braking and increases braking efficiency.
Set of 4 lines. DOT approved.
Motul RBF600 Brake fluid. The ultimate high performance brake fluid. It exceeds the standards of DOT 3 and Dot 4. Extremely high dry boiling point helps prevent vapor lock and brake fade during hard use.
Includes 2 Bottles for complete system flush.
$1,379
Installed
$1599
Call or email for appointment.
http://boxer4racing.com/
Brembo Brake Rotors, Brembo Big Brake Kits, Axxis Pads, Goodridge SS Brakelines importrp Suspension/Brakes/Handling 1734 05-21-2015 03:07 PM
SS brake lines & big brake kit / WRX kit Piecode314 Brakes, Steering & Suspension 3 01-31-2009 03:07 PM
WRX Brake Upgrade: 4-pots or big brake kit! TRUDAWG Private 'Wanted' Classifieds 4 07-26-2006 11:13 AM
SUPER BIG BRAKE KIT SALE! We have more kits than you can imagine! P&L Motorsports Inc. MWSOC Vendor Classifieds 7 06-23-2006 03:40 PM
I Need Help Finding Brake Pads For Stop-tech Big Brake Kit! SNEEZER Brakes, Steering & Suspension 2 02-26-2004 02:29 PM
