Old 11-17-2009, 02:29 PM   #301
WRXerist
Member#: 20235
2006 FX45
My car does has a similar issue... It would start up fine and drives fine. When cold and when it hasn't been started for a couple of days, when starting it, it would make this struggling sound but it starts. You guys think it might be a dirty IAVC? Or do I need to clean the upper engine mount with the Subaru Upper Engine Cleaner?
The car has 88K miles. Just put in new plugs (NGK OEM).
WRXerist is offline   Reply With Quote
Old 02-08-2010, 05:15 PM   #302
miguel muņiz
Member#: 144962
Chapter/Region: PRSIC
2004 Forester XT
I have a Forester XT 2004 and the cel P0509 appears and is something about the IAC but I cant find the IAC in my forester does anyone know where it is??? I think I have the same throttle of the STI 04-up
miguel muņiz is offline   Reply With Quote
Old 02-15-2010, 11:32 PM   #303
ukranianization
Member#: 238506
2003 wrx
Psm
Talking wow
this thread just saved me.thanks a bunch.
i also have a cylinder misfire, does anyone know if that could be a result of a bad iacv gasket?
ukranianization is offline   Reply With Quote
Old 02-17-2010, 04:33 PM   #304
mysticmicman
I have loose ends in the classifieds!!
Member#: 232717
Hey can anyone tell me what the other black box'ed item is on the left side of the IAVC? Mine has a crack down the side of it (Not the black box but the metal itself!) and i have no clue what it is and i want to find out what it is so i can replace it. Thanks
mysticmicman is offline   Reply With Quote
Old 02-18-2010, 11:27 AM   #305
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Default Thank you!
I have 141K on my WRX and for the past 3 weeks Ive had my Idle surge on cold start up as well..
The Good ol' search button worked once again! Bought a new gasket and cleaned the IACV .. Idle surge is GONE!
Thank you OP !
AWDBoost is offline   Reply With Quote
Old 02-23-2010, 08:17 PM   #306
97legwagon
Member#: 239270
2005 Saab 9-2x Aero
I cleaned the IAC valve on my EJ22T and it made a very slight difference. I have a feeling that I will to replace it sooner or later. Just have to keep an eye on the check engine light and hopefully the CEL stays away!
97legwagon is offline   Reply With Quote
Old 02-24-2010, 12:16 AM   #307
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
you guys will be surprised at how much more gunk is below the shaft after you disassemble the whole unit. I spent an hour thoroughly cleaning the IACV, but was shocked to find out only about 1/2 of gunk was removed after disassembling the unit. You will need to use a grinder in order to be able to remove two bolts.
Old 03-26-2010, 06:54 PM   #308
WrxRD87
Member#: 240037
2002 Impreza WRX
Good write up! I followed all of the advice and techniques on this write-up and successfully replaced my IACV on my 02 WRX. Replaced it, left battery cable unhooked for about 15 minutes and check engine light has not come back on Originally received P1507 code for this problem.
WrxRD87 is offline   Reply With Quote
Old 05-03-2010, 01:28 PM   #309
highmtn
Member#: 245801
Really helpful! I followed the write up, took about an hour and saved $400. ('02 WRX)
highmtn is offline   Reply With Quote
Old 05-08-2010, 12:47 PM   #310
nelam
Member#: 93679
great write up and even easier fix on an 01 2.5rs. went the gasoline route. saved a few hundred bucks and the car is so much smoother. no more p1507 either. thanks very much OP.
nelam is offline   Reply With Quote
Old 05-22-2010, 07:38 AM   #311
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
looks like i got a hot date next weekend w/ some q-tips and alcohol (perhaps more than 1 type )
Evilchargerfan is offline   Reply With Quote
Old 05-23-2010, 01:37 AM   #312
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
make sure to disassemble the WHOLE unit....
Old 06-03-2010, 12:56 AM   #313
wrxmonster
Member#: 206388
Dam I should have done this!!!
wrxmonster is offline   Reply With Quote
Old 06-03-2010, 01:23 PM   #314
rick-l
Member#: 33868
2003 wrx
srp
I am not sure if you do more disassembly than take it off the intake manifold it will go back together.
rick-l is offline   Reply With Quote
Old 06-14-2010, 03:25 PM   #315
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
For anyone who doesn't have access to an impact to remove the screws, I was able to remove them with the large screwdriver method. It needs to be wider than the diameter of the screw head and also large enough to completely fill the gap in the screw (meaning no wiggle room for the driver). Also, one was really stuck so I attached vice grips to the shaft of the driver and cranked with my left hand while pushing the driver down hard with my right. This was on a 2002 with 107k and the IAC has never been removed.
Hope that helps.
Agkelos is offline   Reply With Quote
Old 07-16-2010, 05:06 PM   #316
DCrally43
Member#: 246653
2004 WRX
jbp
i drove all the way to the dealership today and bought their last IACV gasket, ready to do this but now im hung up on the bolts. their 5mm? thats a very odd size, what about the thread pitch?
DCrally43 is offline   Reply With Quote
Old 07-17-2010, 05:30 PM   #317
rick-l
Member#: 33868
2003 wrx
srp
If you get the impact driver you won't need new screws.
http://www.sears.com/shc/s/p_10153_1...o=4&blockType=
Old 07-23-2010, 09:16 PM   #318
Doroshujin
Member#: 235373
Default Where is my IACV?
I really hope I'm not being retarded but I can't find the IACV. My throttle body looks different than all the write ups. Can you help pic it out of this picture? Thanks
Doroshujin is offline   Reply With Quote
Old 07-23-2010, 10:59 PM   #319
mostasz
Member#: 170512
2012 WRX
Ice Silver
What year and model do you drive?
mostasz is offline   Reply With Quote
Old 07-27-2010, 06:17 PM   #320
Flyke
Member#: 215578
It's the one with the blue label.
//Flyke
Flyke is offline   Reply With Quote
Old 07-30-2010, 01:53 PM   #321
elchupanigre
Member#: 250498
04 wrx
jbp
just cleaned mine out today. took about 30 mins. great heads up on the flathead.
no surge, no freaking 3500 idle out of no where, and when the scoob is warm steadies at about 800 not 500-1200
thumbs thumbs thumbs up
elchupanigre is offline   Reply With Quote
Old 07-31-2010, 12:25 PM   #322
wrx720
Member#: 253514
2002 VF30 WRX
psm
Default New member
Hey guys, I'm new to nosioc, How you guys doin? I been having problems with my icv for a while, I just figure out how to fix this culprit, I know how frustrated this can be. I want to share this with you guys.
when you guys take motor and housing apart, make sure you clean it good, I mean really good. especially the top and bottom part where the bearing is. when you can move the flap and bounce back, you getting close. I cleaned my so good that it instant close back , when you pick it.
I used wd40 to clean and lube, now putting the housing and motor, make sure the flap is fully closed, you can adjust the two 5 star screws to line up, doesn't have to be straight. pay close attention to the mounting hole, it can be adjust. good luck!
wrx720 is offline   Reply With Quote
Old 07-31-2010, 08:00 PM   #323
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
Just wanted to say thanks to this thread and images.
02 wrx wagon
205k
returned from a 2 week vacation (took the fxt, so the wrx sat)
returned and on the restart of the wrx p1507, and surging idle.
I had purchased 2 iacv gaskets a couple of years ago (thinking ahead thanks to this thread again)
I cleaned up the top half as in the first post, i didn't get it anywhere as clean as the rest of you im sure. 205k of miles there was lot's of build up. Just put back on and no more p1507, idle is good. I really think I need to do a better job cleaning it out. But i'll open it up and do it again if I need to.
thanks again
I'll add i plan to do the iacv cleaning as listed in endwrench as well tomorrow. Throttle body cleaning.
dm
dwmoss_68 is offline   Reply With Quote
Old 08-01-2010, 12:43 PM   #324
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
I did this cleaning process yesterday. I first cleaned my perrin intake filter after which i start the car and the p1507 cel comes on. I take apart the iacv and fallowing cleaning procedures with the alcohol and q tips. As far as my gasket goes it came off in one piece, ever so gently. And yes it expanded, and I did reuse it again. To get the gasket to shrink back down i actually put it into the freezer for the duration of the time it took me to clean the part. And just like that it worked putting back on. I sat the gasket in place, put the iac back on and wiggled it back and for to ensure gasket fitment. Screwed her back on and no leaks. Car idles better than ever.
03WRX83 is offline   Reply With Quote
Old 08-12-2010, 10:21 PM   #325
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
I just went through and did this today. It was starting up at 1200 like it always does, but instead of dropping to 500 very shortly after, it would quickly spike to 2000 rpm. Figured it must be the IACV. The entire inside of the thing was just filled with black gunk. I laid it on the work bench and filled it up with seafoam. 5 mins later, I wiped around inside it with a q tip, poured it out, and it was squeaky clean. Did it a second time just to be safe, then cleaned out the seafoam residue with MAF cleaner.
Put it back on, and presto. 500 rpm idle.
I love seafoam. For degunking parts, you absolutely cannot beat it.
anickode is offline   Reply With Quote
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 02:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 03:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 11:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 11:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 06:52 PM
