Old 12-05-2010, 08:54 PM   #351
El Guapo
Member#: 234937
2004 STi
20G'd Blue
Originally Posted by K.Linchpin View Post
El Guapo, if you can get the iacv to spin freely, I don't see a reason for taking it apart.
how is everyone getting it to spin without taking it apart?
El Guapo is offline   Reply With Quote
Old 12-09-2010, 10:57 AM   #352
obyone
Member#: 16523
Originally Posted by Rawker View Post
my engine looks like this, where is the IACV?
note this is not my picture
Originally Posted by eXotek View Post
anyone have any coment on this? My engine looks like that too, 2003 Impreza TS. where is the IAVC?
Originally Posted by GDAryder View Post
it could possibly right under that fixture where the throttle body meets the air filter.
I know it's an old post but the Idle Control Valve is here:
held in place with 2 phillips head screws.
This is off a 2000 RS.
obyone is offline   Reply With Quote
Old 12-09-2010, 05:29 PM   #353
nategreat923
Member#: 178798
1992 240sx
Has anyone tried this on a Legacy? The BC5?
nategreat923 is offline   Reply With Quote
Old 12-24-2010, 11:55 AM   #354
subrandon
Member#: 62015
2003 wrx
I cleaned mine with alcohol and qtips and re installed with new gasket(had to go to two dealerships to fine one) last night. No change to idle and still throwing the P1507 code.
I noticed while cleaning the valve "door" wouldn't close all the way. It would stay 1-2mm open.
I could move it open quite easily and it would spring right back immediately.
Is this right? is it supposed to stay open just alittle?
subrandon is offline   Reply With Quote
Old 12-24-2010, 11:04 PM   #355
rick-l
Member#: 33868
2003 wrx
srp
Don't remember but you did check to be sure the cruise control cable isn't holding the throttle open right?
rick-l is offline   Reply With Quote
Old 12-25-2010, 10:28 PM   #356
subrandon
Member#: 62015
2003 wrx
Cruise control cable is fine. first thing i checked. picking up a used IACV unit from another member in two days for $75.
Old 01-07-2011, 07:59 AM   #357
H240sx
Member#: 268503
1997 impreza
white
i think this is what is wrong with my impreza. tired cleaning the MAF and fuel pump becuase i though thats what was causing the car to die out after 5secs. ill try and pick up a new gasket and hopefully solve the issuse
H240sx is offline   Reply With Quote
Old 01-25-2011, 02:12 PM   #358
ezil71
Member#: 207118
2003 Wrx Wagon
My bugeye idle isn't high/low, but it sounds like either a misfire or some coolant is getting past the gasket because at idle I get a stumble and see some white smoke when it does.
Does this sound like the IAC is dirty, or is it more likely a spark plug/gap issue? The car is otherwise running nicely (especially after some seafoam).
Edit:
Used some seafoam to clean the IACV, which worked quite nicely. With new plugs I still have a bit of a stumble at idle, but the cleaning of the IACV was well worth doing. I poured SF into the cambers and let to sit for 15 minutes, then used q-tips to clean it to a like new shine (same with the part still in the car)
What is the sensor right next to the IACV on the throttle body?
ezil71 is offline   Reply With Quote
Old 03-11-2011, 10:02 AM   #359
z0mgluke
Member#: 247675
2001 WRX
Can't begin to thank the OP for this thread enough, thank you so much. Saved me the extortionate price that Subaru here in Australia wanted to charge for a replacement IACV ($800... yeah)
Cleaned it out with petrol and degreaser, new gasket ($14... urgh) and all sorted. Cheers!
z0mgluke is offline   Reply With Quote
Old 03-11-2011, 02:40 PM   #360
SoCalWrx
Member#: 15794
2002 PSM WRX
2003 BMW e46 M3
Thx OP the fix solved a hunting idle I'd been having since changing the clutch. I soaked it in seafoam and used the qtips. Dried it and then applied wd40 to the hinged areas. Works great.
SoCalWrx is offline   Reply With Quote
Old 03-17-2011, 07:13 PM   #361
SubieRSjustin
Member#: 262254
2000 00rs/99 legacy
silver/ tan
Replacing my iac tomorrow. Brought my swapped rs to Precision Tuning for a smoke leak test and sure enough my iac was leaking. The o ring is actualy coming out. Been having some weird idle issues lately so I'm hoping this will fix er right up.
Did some haggling and got it for cost $230 from dealer $4 for gasket.
Great thread!
SubieRSjustin is offline   Reply With Quote
Old 03-17-2011, 07:15 PM   #362
Boostmaster
Member#: 62056
2004 WRX Wagon
Java Black
O'reilly's auto parts can get this IAC for around $160 or so... Unfortunately no gasket is included.
Boostmaster is offline   Reply With Quote
Old 03-30-2011, 06:39 PM   #363
SoCalWrx
Member#: 15794
2002 PSM WRX
2003 BMW e46 M3
Just thought I chime in with another piece of info that might be of interest. I recently did the IACV cleaning. It helped a bit, but the car was still missing a bit of the bottom end torque I had long ago. Long story short I replaced the engine to purge-valve hose and voila the torque returned to my low rpms.
Part #09530C040
When I replaced the hose I noticed that the diameter of the one coming off the car was three times that of the one going on.
Old 03-31-2011, 10:26 PM   #364
sgdought
Member#: 278508
Talking Disconnected and reconnected power to the IACV and Shazaam!
I went by the Subaru dealer in Denver and ordered a gasket and was going to try to clean it this weekend. The symptoms were idle dropping to 0, car stalling at stop, idle so low it was rough if it did not die. This afternoon, before I picked up the gasket, I was going to try running the engine with the power to it disconnected. I disconnected the wiring harness, and thought, "it is just going to die", so I did not even try to start it with the power disconnected. I reconnected the wiring harness after maybe 10-20 seconds, started it, and it died immediately. I started it a second time, and the idle went to 1200, down to 1000 after maybe 30, seconds, and settled in a 700 - 800 like before. Shazaam, Sarge! I guess I "rebooted" my IACV.
It has run beautifully all afternoon and evening. I now have a spare IACV gasket in case I do decide to remove and clean it It was only $8.32, so I can't complain. After spark plugs and a new air filter, it's running very well, especially considering my 2005 Baja has 155,000 miles. (I'm the original owner). I dodged that 500 dollar repair.
Thanks again for the PICs, as I would never even known what I was looking for.
sgdought is offline   Reply With Quote
Old 03-31-2011, 11:08 PM   #365
jaegmeister
Member#: 236092
2004 wrx full exhaus
vf48 aps big tmic nstuff
Part #09530C040
is this legit?
jaegmeister is offline   Reply With Quote
Old 04-12-2011, 06:11 PM   #366
shemoves
Member#: 80663
2005 STi
Just want to confirm, cars that have a DBW throttle don't have to worry about this or am I mistaken?
shemoves is offline   Reply With Quote
Old 04-13-2011, 04:11 AM   #367
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
No IACV on DBW throttle cars. If you've seen the naked manifold, there isn't even an opening for air to enter the IACV. In DBW throttle, the throttle plate is actually opened to maintain idle.
OrbitalEllipses is online now   Reply With Quote
Old 04-13-2011, 05:30 PM   #368
shemoves
Member#: 80663
2005 STi
What I thought, just want to make sure though. Thanks.
Old 05-08-2011, 01:18 PM   #369
Radys
Member#: 280870
2002 Impreza TS 2.5
Hi all, can someone help me?
I replaced the catalytic converter and 2xsensors on it, on me car Subaru Impreza 2.5l TS 2002. Then I discovered the error on Knock sensor. I replaced the Knock sensor tu. After replaced it no error for 14 days. Bud now the car start have error P1507 Idle Control System Fault (Fail Safe Mode).
What I have tu du pls? Clean the IACV and putt new gasket? Need help pls coz the errors just show up 1 the converter, then i replace it and another error show up the knock sensor, I replaced it tu and now I am on this P1507 and I do not want bay new IACV coz i ready spend 2000$ for all the sensors and catalytic converter. Du U recommend clean the IACV and new gasket? The car run good, no problem with low engine speed. All sound ok but still error P1507. Btw the car have remote starter, can there be problem? Thx for any help.
btw the error show up when I putt the V-power gas 95 octan, when I run the regular 91 octan gas, the error disappear...
Radys is offline   Reply With Quote
Old 05-08-2011, 02:28 PM   #370
rick-l
Member#: 33868
2003 wrx
srp
This is a shot in the dark, and I don't know if my 2003 wrx is similar to the NA version, but that is the code I got when my cruise control cable was hung up and would not let the throtle return to idle.
Old 05-09-2011, 08:31 PM   #371
Boston WRX
Member#: 109899
I just cleaned my IACV on my 2005 WRX wagon with 118K miles this past weekend following the instructions in the first post. My car ran terribly during the first start and run cycle. I got a check engine light and awful idle, but my Accessport reported no trouble codes found. I reset the ECU and let the car sit over night.
This morning the idle was a little high, but smooth. During my 8-mile, 20-minute commute, the idle rpms descreased a little bit at every stop sign and red light. By the time I got to my office, the idle was close to 800 and nice and smooth. I took a drive at night and again this evening. The is still smooth and drivability is much improved. no more herky-jerky if letting off the gas in 1st gear at low rpms.
Boston WRX is offline   Reply With Quote
Old 05-14-2011, 01:43 PM   #372
ogboot
Member#: 170906
psm
I'm doing mine right now, and the last shop to have their hands on it didn't use a gasket at all, and it's covered in gray looking permatex junk. What's the best method for getting all this trash off of the throttle body and IACV? Would a scouring pad damage it too much?
Edit: Used a scotch pad, some gasoline and a blade.
Two things that really helped me out were using an impact driver to remove the phillips head screws, and then replacing them with 5mm x20mm socket top screws. Getting it on and off was a cinch.
ogboot is offline   Reply With Quote
Old 05-16-2011, 07:00 AM   #373
mercfan33
Member#: 282887
2005 Impreza 2.5 RS
metallic blue
i have a 2005 2.5 rs 5 speed and it constantly revs itself up when in neutral or when idling it will rev all the way from 1k rpm all the way past redline the only way to stop it is to put it in gear or shut the car off could it be the IACV? i am in desperation as my warranty runs out on the car in a week
mercfan33 is offline   Reply With Quote
Old 05-16-2011, 10:50 PM   #374
racerwrx
Member#: 10054
My '02 started up this morning with a wandering (up to 2000 RPM) and lean (reading '--' on a TUNA) idle. With a little gas it ran fine, but dropping back to idle it returned to this lean, wandering mode.
I pulled the IACV, cleaned it per instructions, replaced gasket, reset ECU, etc. etc. And IT WORKS! So far, so good anyway. We'll see how it handles the commute tomorrow.
I was a little concerned when I first pulled the IACV, because it didn't look like what I'd call dirty. But the cleaning process did pull a small amount of gunk out of there.
Thank you very much for this post!
racerwrx is offline   Reply With Quote
Old 05-17-2011, 03:44 PM   #375
ogboot
Member#: 170906
psm
If it's under warranty don't waste your time on it unless you can fix it quickly.
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 01:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 02:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 10:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 10:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 05:52 PM
