Old 01-26-2006, 06:58 PM   #26
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
thats where this damn thing is!
SubaruImpreza_power is offline   Reply With Quote
Old 02-10-2006, 01:46 PM   #27
BenOBS
Member#: 96854
Anybody can tell me where it is on a EJ22 N/A ??
BenOBS is offline   Reply With Quote
Old 03-20-2006, 09:24 PM   #28
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Excelent Write up
Kcwiro is offline   Reply With Quote
Old 05-03-2006, 04:58 PM   #29
WRX_REED
Member#: 38976
2000 RS 2.5 Coupe
Sedona Red
Question
I know this thread is a bit old but has anyone tried using RTV silicon in place of the rubber gasket in small amounts so no swished out silicon falls into the intake chamber?
WRX_REED is offline   Reply With Quote
Old 05-05-2006, 10:35 AM   #30
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
Originally Posted by ugetworked311
Has anyone tried this one?
My GOD thank you someone FINALLY has found this!!
Down here it's called sa459, (S-ubaru A-ust 459), upper engine cleaner. Used on EVERY SINGLE SERVICE-every 12,500kms down here.
I've been using delco stuff that smells and looks and behaves the same, but apparently it's off the market here. I just bought a dozen cans at $5.50 each!! GREAT STUFF, can't talk it up enough...
and I'll tell you something else...
I used to use it about once a month on my ea82Turbo that had a carby C/Case and used to re-breathe ALOT of blowby, as with WRX's, the PCV is upstream of the turbo, and with all that carbon/build-up on the compressor wheel, it took a while to spool. I have found that by spraying this stuff into the inlet tract of the turbo at 'fast idle', you can effectively clean the compressor wheel and remove unwanted oil/carbon deposits on intercooler, BOV, throttle body, idle speed controller, and even the catalytic converter gets a clean. You can use it on everything from boost solenoids to oxy sensors, (next best thing to sonic bathing). It is also really good weed killer and will cause birth defects in your unborn children. We had british petroleum test some to make a 'smokeless' version so the dealer network wouldn't have to fit carbon filters on the exhaust extraction at everysingle workshop. Bp came back and told me that "...once they took the 'smoke', (read;carcinogens), out, it just didn't work anymore.."
I cannot talk this stuff up enough-had a go just the other night.
Chainsaw wouldn't start-suspected a 'feathered' s'plug, gave it a squirt of SA459, (upper cyl cleaner), two rips later she was running!! I just love it.
Sorry to rant----it just gets me excited
Cheers
Sixpack
sixpack subaru is offline   Reply With Quote
Old 05-05-2006, 10:45 AM   #31
sixpack subaru
Member#: 64974
Also-it's the leaking gasket that can make an eng rev to 4000rpm??:?:
Old 05-05-2006, 10:52 PM   #32
matt7102
Member#: 12051
1999 Impreza
That Silver color
Default yes, that can happen
A leak in the intake tract can contribute to high idle and a lean mix.
Matt7102
matt7102 is offline   Reply With Quote
Old 07-05-2006, 10:47 PM   #33
wrxdevil666
Member#: 115552
great write up guys. I just came across this thread..........i have been having thins problem for the past couple months. Gonna work on it now and hope that this was indeed the problem.
wrxdevil666 is offline   Reply With Quote
Old 07-18-2006, 05:10 PM   #34
Judge
Member#: 15380
The link to endwrench will not open. What is this uppen engine cleaner called here in the US?
Judge is offline   Reply With Quote
Old 07-19-2006, 01:48 AM   #35
silver car
Member#: 113540
http://forums.nasioc.com/forums/show...2#post14563822
wonder if this is my problem.. My car hasnt been run since march of 06. Now just the other day when i started it up, it started doing this.
silver car is offline   Reply With Quote
Old 07-19-2006, 12:32 PM   #36
avk
Member#: 17252
'06 WX8
59E
The link works and the cleaner specified in the article is "GM Top Engine Cleaner or equivalent", same as for older IACs that use solenoids.
avk is offline   Reply With Quote
Old 07-23-2006, 09:37 PM   #37
Judge
Member#: 15380
Must be something with the network here at work....because it will not open all the time at work but at home I got to read it.
I cleaned mine the other day. We use spray methanol here...so I used it nice and clean now. My gasket was in perfect shape so I put the new one away for later.
Old 07-24-2006, 01:03 AM   #38
mgrenoble
Member#: 120997
2003 WRX
Default gasket
where did you guys buy the replacement gasket? I've searched all over the internet but can't find it! I REALLY don't want to buy it from the dealer, they already screwed me out of $90 for the diagnostic check.
mgrenoble is offline   Reply With Quote
Old 07-26-2006, 05:31 AM   #39
poopooscrum
Member#: 31543
02 bugeye wagon
pm subiegal at subarugenuineparts.com
they usually have good prices and fair shipping.
If you guys really need to replace the iac you can considering buying a used one, or a complete throttle body here on the forums instead of shelling out 300-400 bucks for a new iac.
poopooscrum is offline   Reply With Quote
Old 07-28-2006, 08:21 PM   #40
zoomfactor
Member#: 30440
03 WRX
WR Blue
I saw that there is concern about coolant leaking past the gasket, if not properly installed and seated. Is this still a problem if you have the throttle-body coolant bypass mod?
If so I may go for the full port/polish & coolant bypass.
FWIW - I noticed another poster had the same problem. I got the P0519 after the car sat for about a week and a half in this wicked heat. Started crazy idle this morning on the way to work. Not the way to get back to work after vacation
zoomfactor is offline   Reply With Quote
Old 07-28-2006, 10:56 PM   #41
Judge
Member#: 15380
If you have the bypass done I would doubt there is an issue...considering the coolant is not being fed into the throttle body housing
Old 07-29-2006, 12:47 AM   #42
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
The part number is in the first post (22659AA120) - any online parts place (www.subarugenuineparts.com, www.subaruparts.com, etc.) can get it for you - it's a $6 part, though, so the dealer really can't mess with you too much on price...
Old 08-14-2006, 01:54 AM   #43
HolyGhost22
Member#: 122887
if you clean with gas, how do you remove the gas when your done? Will mass air flow sensor cleaner work?
HolyGhost22 is offline   Reply With Quote
Old 08-14-2006, 11:31 AM   #44
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Remove the IAC from the "dip" and just dab it with a towel. The gas will evaporate off in any decent heat. Put it in direct sunlight for faster results.
cdvma is offline   Reply With Quote
Old 08-15-2006, 11:21 PM   #45
HolyGhost22
Member#: 122887
thanks alot...
Old 08-29-2006, 10:04 AM   #46
Vicious LSD
Member#: 103539
2009 WRX Premium
Coming to stop lights my car does this sometimes. I have a 05 with about 23k on it and the idle sometimes drops to 0 and stalls out. Other times it gets close to 0 and bounces up. Any ideas?
Vicious LSD is offline   Reply With Quote
Old 08-29-2006, 05:39 PM   #47
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
I cleaned mine by taking off the unit and flipping it upside down and soaking it in gas. It cleaned up very well and I reinstalled it with a new gasket and reset the ECU. I primed the pump 3 times and started it. The car started and right off of the bat I noticed that the CEL came back on immediately. Could I possibly need a new IACV? I noticed that when the engine is shut off it sounds like the engine takes a second to turn off after. Maybe this is from the 1500 idle or maybe it's a problem. I threw the same CEL originally as everyone else. Any thought? I just did this about 5 minutes ago and I'm stumped.
digitalmethods is offline   Reply With Quote
Old 08-29-2006, 05:44 PM   #48
scooterforever
Member#: 55011
Sometimes the IACVs just die.
scooterforever is offline   Reply With Quote
Old 08-30-2006, 07:43 AM   #49
digitalmethods
Member#: 33734
02' Snow donkey FTL
I tried unplugging the IACV when the car was running and it made little to no difference in the idle condtion. Could that be my answer? I have a very choppy idel noise so I'm freaked that the car isn't running on all cylinders. If that was the case would I be throwing a blinking CEL with a different code. Last I checked it was only the p0519 and the high idle code.
Old 08-30-2006, 11:15 PM   #50
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I just did the cleaning and it made quite a bit of difference in both idle and throttle tip-in and lift-off throttle behavior. Would definitely recommend this.
Simply used lots of throttle body/carb/choke cleaner and lots of Q-tips.
-Biggly
DrBiggly is offline   Reply With Quote
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 02:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 03:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 11:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 11:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 06:52 PM
