Old 08-31-2006, 11:54 AM   #51
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
Wish I had the same result. Instead mine is junk. Now I'm getting another unit. I soaked it in gas and was very carefull but it was already dead. I tested the unit and it has a broken circuit. Probably somewhere in the coil or something. So for anyone who tried cleaning it and it didn't work I had 60k and meticulously maintain my vehicle. They die so check the contacts before you even bother cleaning it. You can learn from my time.
digitalmethods is offline   Reply With Quote
Old 10-02-2006, 11:01 AM   #52
KKoepp31
Member#: 13544
2011 ML550
I hate to bump an older thread, but I'm having issues. I'd been suffering from an idle surge and occassional stalling so I decided to clean out the IACV. The gasket of course gave me issues...the car has 85k miles so this doesn't come as a huge surprise. I do have the throttle body coolant bypassed, so I'm not worried about coolant getting into the manifold, but the car is running very rough now and going into limp mode or just stalling out, losing power entirely, etc. Could a screwed gasket really cause this much of an issue or do I have other things to worry about? I have a new gasket on order, along with new plugs and I think I'll change the fuel filter for good measure. I'm worried I may have major ecu issues. I did have the codes scanned at autozone but i had just done an ecu reset to make it there so I'm not sure if that cleared them out because nothing worthwile showed up. Anybody have any input on this?
KKoepp31 is offline   Reply With Quote
Old 10-02-2006, 11:12 AM   #53
digitalmethods
Member#: 33734
02' Snow donkey FTL
Did you throw another code yet? I would get the CEL codes and search them on here. I took mine out and reinstalled it after cleaning it. It didn't work and I used a new gasket. I wouldn't be too worried. I thought I had some major issues but changing out that valve did the trick. Do you have access to a voltmeter? Check the to terminals on the IAC itself. If you have a electrical loop then it's good. If you have no loop made then the connection is lost inside of the unit making it defective. It's really easy to do if you have the right equipment. Autozone could probably do that for you. Check and see if it's sending out a signal basically. PM me if you are confused.
Old 10-02-2006, 12:41 PM   #54
scooterforever
Member#: 55011
If you bork the gasket, you'll have a boost/vacuum leak. You should have a new gasket on hand before doing the cleaning.
scooterforever is offline   Reply With Quote
Old 10-02-2006, 12:47 PM   #55
KKoepp31
Member#: 13544
2011 ML550
The gauge shows no vacuum leak. I do have a new gasket on order and it should be here in a couple of days. I did let the car idle and then pull the plug off the IACV. The idle definitely did change, but I don't think I left it unhooked long enough to tell how drastic it would have been. I'll have to test the circuitry of the sensor when I get home tonight. My dream of an easy fix is quickly fading with this headache.
Old 10-02-2006, 01:27 PM   #56
digitalmethods
Member#: 33734
02' Snow donkey FTL
It's way easier than you think. Don't worry about it. I'm almost postive that your IACV is junk. You already cleaned it and reinstalled it so then that's your next step. Just check the terminals on the IACV. The idle will drop when you unplug it but not by much. The best way to test it is with the voltmeter.
Old 10-02-2006, 01:43 PM   #57
scooterforever
Member#: 55011
They do go bad from time to time. Sometimes cleaning fixes it... sometimes they just go bad.
Old 10-02-2006, 02:18 PM   #58
KKoepp31
Member#: 13544
2011 ML550
I can't imagine it is something cheap to replace. Anyone have a spare they could send me to test out?
Old 10-02-2006, 02:26 PM   #59
scooterforever
Member#: 55011
PM me your address, if you cover shipping I'll drop one to you. It's for sale for $70, but haven't sold it yet. I actually have 2 on hand, one is JDM and one is USDM, but they look the same. If it solves your problem u can by it, otherwise just return it to me.
Old 10-02-2006, 07:51 PM   #60
rally me
Member#: 100127
02 WRX wagon
just cleand mine (IACV) this weekend and installed a new gasket from the dealership. at first it was the same old shiot but she fixed herself on her own after a 30 minute drive. +1 i too think your IACV is junk. at least you can $ave some ca$h my doing the install yourself. good luck.
rally me is offline   Reply With Quote
Old 10-02-2006, 07:56 PM   #61
rally me
Member#: 100127
02 WRX wagon
oh yeah... scooterforever. nice write up and pics. thanks. this helped out a bunch. i soaked the IACV in superunleaded overnight let dry and installed with a new gasket.
Old 11-25-2006, 02:30 PM   #62
thejean
Member#: 17763
Any ideas what my issue may be? I tried setting my idle rpm to 2000 rpm. I went back to stock and now I get the P0171 code (lean condition) and the car wants to idle at 500 rpm... seems to want to stall but manages to pick itself back up before it does. My lambda's during idle are between 1.3 and 1.6! So, yeah, I'd say I'm running lean (new front O2 sensor installed as well). When in the throttle, all is fine and lambdas peg where they should. Strange. I was thinking about cleaning the IACV and replacing the gasket. If the gasket is busted from me trying to mess with my idle, could this be causing my lean idle issues? By the way, my idle issues are still present when running stock idle settings. Thanks, J.C.
thejean is offline   Reply With Quote
Old 11-25-2006, 03:25 PM   #63
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
Is this part the same on an 00 2.5na?
superhawk44 is offline   Reply With Quote
Old 12-06-2006, 07:38 PM   #64
Crump
Member#: 72305
2006 Sti Sgm
15 FXT CBSP
great write up. I am going to clean it tomorrow and give it a shot
Crump is offline   Reply With Quote
Old 12-12-2006, 12:07 AM   #65
Crazy650
Member#: 109498
05 Wrx turned STI
going to try this tommorrow
Crazy650 is offline   Reply With Quote
Old 12-14-2006, 12:28 AM   #66
Crazy650
Member#: 109498
05 Wrx turned STI
seams it went away not sure?
Old 12-25-2006, 12:28 PM   #67
dryvyr
Member#: 99805
black
I just joined nasioc and was investigating my iac problem.
Everything checks out fine and moves feely so I expect the IAC electonics itself is bad. Before I spend the $300+ dollars to find out its not the problem does anyone know how to test the module itself? Barring that does anyon have a used one to sell?
dryvyr is offline   Reply With Quote
Old 12-27-2006, 09:42 AM   #68
scooterforever
Member#: 55011
Well... I think my IACV is dirty again... coming up on the 2 year anniversary from the last cleaning.... The car idles funny some of the time, and last week even stalled out on me. I picked up a replacement gasket yesterday.
Dryvyr -- I am not sure how to check the electronics. There might be details in the DOHC Engine manuals for the 2002's... but I don't know. Have you tried cleaning it yet? Often cleaning helps/fixes the problem, but sometimes the IACV just goes. Try car-part.com for a used replacement, you might get lucky there.
Old 12-28-2006, 08:12 PM   #69
scooterforever
Member#: 55011
Today I cleaned my IACV for the second time in as many years. I removed it, blasted it with throttle body cleaner, then let it soak, upside down, in throttle body cleaner. I seated the gasket over 8 miles of vacuum driving, and voila, I now have a rock solid idle.
What makes this job super easy the second time... is the hex bolts I replaced the old, soft metal screws with. Easy removal, no stripping.
Old 12-30-2006, 11:43 AM   #70
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
I have an 05 RS with 25,000 miles on it. Would you guys recommend going this now as a preventative maintance step? Basically could it be dirty enough to warrant a cleaning
mike_b49431 is offline   Reply With Quote
Old 12-30-2006, 11:59 AM   #71
dryvyr
Member#: 99805
black
Scoot
I have tried cleaning and i could find no electronic check out in the manuals
Thanks for the tip on car-parts.com Ill try it.
Old 12-31-2006, 01:45 PM   #72
scooterforever
Member#: 55011
I just checked out car-part, they don't have idle controller listed, but they do have tons of throttle bodies for sale. I would source an entire throttle body if you can get one for under $100 -- that way you get the IACV (~$300 new), the stock MAP sensor (~$200 new), and have an extra throttle body if you want to port the TB intake.
Old 01-01-2007, 09:40 AM   #73
dryvyr
Member#: 99805
black
Default good tip
I was just there and came to the same conclusion.
Thanks for the help.
Old 01-18-2007, 05:29 PM   #74
totalburnout
Member#: 72861
Now the question becomes, what to do if there is white smoke.
I cleaned everything, put a new gasket in, sealed it back up and started the car and I have white smoke coming out of the exhaust.
Its freezing cold out, so I let the car get up to normal operating temperature and smoke is still coming out of the exhaust. I'm not quite sure if its normal or not and can't tell if its white smoke from antifreeze or the cold - but I figured after normal operating temperature the car shouldn't be blowing smoke anymore.
The car doesn't have TGV's in it, so thats a differing factor from a stock car on cold start ups, but I let the thing run for 15minutes.
Not sure what to do now.
totalburnout is offline   Reply With Quote
Old 01-18-2007, 06:41 PM   #75
scooterforever
Member#: 55011
Hmm, white smoke feels like antifreeze to me. Did you seat the gasket by driving under vacuum (no boost at all) for 10 miles? The gasket could have gotten borked. There's also a chance the 'smoke' is condensation (normal) given the cold.
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 01:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 02:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 10:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 10:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 05:52 PM
