#76 | |
Member#: 72861
Vehicle:2008 BMW 335i Coupe Montego Blue & Saddle |
My rpms are borked because of the TGVs, the car starts at around 2000rpms and drops to 1500rpms, then 1000rpms then around 800rpms where it should be after awhile. I guess I'm going to try to open it up tomorrow and see if the gasket lifted or something. Hopefully it won't be a problem, but I was worried about the antifreeze. Is there anything I should look for that would be a tell tale sign of anti-freeze? I was going to check the air intake filter for antifreeze but I think the throttle body is already further down the intake system that it would affect the filter. I guess I'll see if there's any antifreeze that leaked out into the throttle body. Another note, when the sensor open overnight to dry antifreeze came into one side of the sensor - was this my problem or did everyone experience antifreeze? No one really mentioned it, but I figured most didn't let their cars sit overnight. The cavity was still wet with rubbing alcohol and I didn't want to seat the gasket until it was dry so I left it overnight. I'll try to reseat the gasket tomorrow, I just want to make sure the engine won't be fubar'd.
#77 | |
Member#: 72305
Vehicle:2004 Subaru WRX Java Black Pearl |
i have a similar problem, mt car is warm when i started to take it off, and antifreeze is spraying everywhere. I guess I gotta let the car cool down a little first. |
#78 | |
Member#: 72861
I went back, cleaned the little pool of antifreeze that had accumulated out. Retorqued everything back down and had no problems. To this day, I don't know if I had any coolant blowing by or if it was just condensation because of the cold that was throwing off white smoke. ...you should never be working on anything that has to do with the cooling system when the car is hot if you like yourself. It will be quite easy to burn yourself, just like it would be if you changed a car with hot oil. |
#79 | |
Member#: 72305
#80 |
Member#: 144390
South East
Vehicle:2002 WRX PLATINUM SILVER |
there is a good possibility that i might have to go through this cleaning process but i just wanted to run the symptoms im having by you guys before starting the process...
i was driving on a rainy day in 3rd gear i gave the car a good rev up then put it into 4th, once i was in 4th at about 2500 to 3000 rpm's (cruising at low throttle) the check engine light came on i stopped to check if it was something obviouse but i didnt see anything. the car was still runing fine untill i turned the a/c on, then the car dropped down really low in idle (under 500 rpm's)and started idling rough, but didnt turn off. so i turned the a/c off and it was back to normal. now i just havnt been using my a/c untill i get a hold of a scanner to do a check up. but today i noticed that i pulled into my driveway and as i was letting the turbo cool off i noticed that as soon as the radiator fans kicked in (even though the a/c was off) the car started doing the same thing again. what do you guys think? time to order a new IACV seal? by the way its an 02 wrx only mod on it is full 3" exhaust from the turbo back no cat with resonator and apex can at the end, also a greddy oil catcher boositng 10psi. oh yeah one more thing i just got the car but i have had variouse turbo cars in the past but the turbo on this beast sounds completly diffrent when its spooling up, it almost sounds like a super charger ?!? is that normal ?? thanx for all of your time !! Last edited by GHOST R1DER; 03-26-2007 at 10:34 AM. |
#81 |
Member#: 145050
My 2003 Legacy Outback VDC has been stalling at every red light. I've tried looking for the IACV, but couldn't find it. Where is the IACV on a 2003 Legacy Outback VDC? I'd appreciate if anyone can point it out to me. Thanks.
#82 |
Member#: 144390
South East
whats up everyone, i just wanted to follow up on my previouse post...
i hooked the car up to the scanner once i got the reading it was the 2nd o2 sesor that was causing the problems the scanner also said to check all grounds as well so i lifter the car up and found one of the cables on the sensor had been snaged and cut in the proces of dropping in motor, so i took the sensor off the old engine slapped it on the new one and problem was eliminated !! |
#83 |
Member#: 125687
SWIC
Vehicle:2006 Outback XT ABP |
+100 on having a new gasket beforehand. Mine "grew" exponentially the moment the IAC was off and of course the dealer was out of stock.
BTW it cured my idle woes ( rough with and w/o AC ) plus the throttle response feels better. I had done the TB coolant bypass so no worries on the antifreeze. |
#84 |
Member#: 61799
NESIC
Vehicle:1999 Impreza L Silver |
Hi, I think I could provide some info that might help you check your IAC. I've never tested one on a Subaru, but my friend's Mitsubishi IAC went bad.
The IAC is basically a stepper motor that opens and closes a door to allow air into the intake when the throttle plate is closed. They usually get gunked up, and you can usually clean them and they're fine. I think if they get gunked up enough, you may end up burning out some of the windings in the motor as it tries to turn against the gunk, but gets stalled instead. When you stall an electric motor, it just becomes a wire between the 12V and GND, which will heat up and fail. To check your IAC, you'd probably need to just measure the resistance across the different sets of windings. Like i said, i've never checked the Subaru ones, so I don't know how many pins or sets of windings there are. If you don't have a multimeter, and you're willing to experiment with your old IAC, try putting 12V across 2 pins at a time to see if it steps the motor. That may or may not work depending on the type of motor. Using a multimeter is the best way. I'm going to check out a friend's WRX's IAC later this week, so hopefully I'll have some measurements. |
#85 |
Member#: 114572
TXIC
Vehicle:2003 WRX Wagon Blue |
SWEET!! I have been having the same issdue, high idle of 1500RPM in slow traffic and hot weather. I will give this a try also. Thanks for the great advice.
#86 |
Member#: 87430
SCIC
Vehicle:02/5 BugEye-Peanut Sedona Red Silver |
Just been reading and following this thread for sometime. I'm finally going to get down to cleaning my IACV today. Got the gasket and tap screws as recommended from way...top.
I've been tackling other issues like cleaning MAF, replacing air filter, PCV and fuel filter and such...just...I guess!...over-due maintenance/cleaning .Car's been feeling better and better after every one of the mentioned items were serviced/cleaned and now this should (I hope ) complete the better "idle" and acceleration problems I was having.Wish me luck ! |
#87 |
Member#: 87430
SCIC
OK!...It's been a little over an hour now and... D-A-A-A-A-A-A-A-A-MN
!!!!!!I mean...WHAT IN THE NAME OF... !That thing is DUHhhhh....reeee!!!!! I can't believe the car's been even rolling/running like that! I was expecting "dirty" but this is overwhelmin!!! Those of you who haven't cleaned your IACV or experienced the many mentioned syntoms...PLEASE!...take a few minutes to do it now. You'll be very surpriced how much "YUK" you can get in there! My only question now is...Do I have to reset the ECU after the cleaning is done and all the parts are back in?? |
#88 |
Member#: 87430
SCIC
DONE
!My baby hasn't felt this good since 2002 !Drove it below "boost" around the block, the car feels so good...I think I'm in love again .Maybe it doesn't even need an ECU resetting...Does it?? |
#89 |
Member#: 11482
South East
Vehicle:02 WRX Acute Stickeritis |
I don't think I bothered to reset mine. It just immediately started driving better. Any 'compensation' it learned for the IACV (which won't be much if at all) will be unlearned soon enough. I'd only reset if you are having some really odd issues that might be related to suddenly going from gunky to clean IACV i.e. it is acting like it's compensating or fighting itself.
![]() -Biggly |
#90 |
Member#: 55011
Vehicle:2002 |
Yeah, I can't remember whether I reset or not the first time I cleaned. I don't believe I reset the ECU the second time, and for the third... today... I didn't.
The bad news... today's cleaning (again, the third time) is the first one when cleaning improved things a little bit... then this evening the car stalled out at a stop sign. At 82k miles, on my second block and fourth turbo... it's probably time to get a new IACV. Alas... $280 (give or take) down the toilet... but this cleaning technique bought me at least two years. It lasted longer than the connecting rod in cylinder #2 (I have a great paperweight, but that's another story). |
#91 |
Member#: 150075
wow I have been searching for an iacv fix for some time and finally stumble on this...
is this the same for a 2000 Forrester (obviously not turbo)?? I have a CeL for my speed sensor (no speedo or odometer) and IACVI can deal with no speedo or odometer (I have a GPS that I am using until I get the money for the speed sensor) but the rough idle is killing me- it come and goes... and I went to the parts store and am not willing for shell out the $400 they want for a IACV thanks for the write up- seems simple enough hopefully it's the same application -Noah |
#92 |
Member#: 40736
Vehicle:2005 WRX STI Aspen White |
Is this the same for the STI?
My only question is you soak the metal block that you unscrew? I am not understanding how people are saying that is going bad.... if it's just a metal block above the manifold that has a gasket, how does other than the gasket go bad.. does the metal wear..etc? I am going to do this, just gotta get the gasket and screws as mentioned above... my idle fluctates and is throwing my car a p0304... even though I am NOT misfiring... Thanks, -Nigel |
#93 | |
Member#: 55011
Vehicle:2002 |
I don't know personally, but would assume the idle controllers are similar.
#94 |
Member#: 52801
SCIC
Vehicle:1999 Legacy Wagon L Green 30th Anniv. |
If it is the same as a Toyota, the motor eventually wears out. The more resistance it has, the quicker it will wear out or burn up.
So, a sticky IACV will have more stress on the little DC motor that opens the valve, and over time it will just go dead. Thank the Subaru Engineering Gods for designing an easy to work on auto - my Toyota Sienna IACV cleaning project took almost 5 hours. Subaru - maybe 10 minutes after you do it once. I spent 20 minutes the first time, trying to put the old gasket on. Get a new gasket *before* performing removal! Bill in SD |
#95 | |
Member#: 40736
Hmm... I physically can't find this on the sti... I think they might have changed it from a wrx to sti..? Anyone with an sti that could help verify.. I'm looking in my engine bay right now and where that picture above is a I have a little black box, took it off and definatly not what was pictured above... mine was a long straw like thing... -Nigel |
#96 |
Member#: 82556
Vehicle:1996 Legacy L wagon |
I have a 1996 EJ22, and have a very stumbly idle right now. So I bought a gasket for what I thought would be my IAC. However, it instead of having the two rectangular chambers like in the pictures, it has a circular hole and a square hole below it with 4 bolt holes to the sides. I have no IAC ontop of the throttle body, so is this what I need to be looking at? The IAB line goes right into it.
#97 | |
Member#: 116132
Vehicle:2006 wrx tr Stage II sgm Jorge tuned -RIP :( |
#98 |
Member#: 96448
Vehicle:02 WRX VF34 |
If you've done TB coolant mod, is cleaning still necessary to do?
#99 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
06gray- the drive-by-wire engines do not need an IAC since the ECU now controls throttle position at all times. They don't have cruise control modules either.
gopsu- the bypass mod has nothing to do with IAC function. If there is no longer coolant going through the TB then you won't see any coolant when you take the valve off, but that's about it. The gasket should still be replaced to prevent any intake leaks. |
#100 |
Member#: 4889
BAIC
Vehicle:1996 Impreza LX 2.2 Aegean Blue |
I need some advice. The car is an '02 WRX 4EAT, with 17X,000 miles.
We've been having a problem with our cold start/idle recently. On occasion, the cold start would start rather poorly, with the rpms being both lower, and really uneven - it would cause the whole car to shake. This would work itself out as the car started warming up, and when warm the car seemed to be ok. We had no CELs, but thought trying to clean the IAC valve might help. So, we removed the valve and cleaned it by putting gas in the holes, letting it sit, and draining the gunk out. We reinstalled the unit with a fresh gasket, and started the car and the idle was running faster than normal. It was holding a fast idle for several seconds, then it threw a CEL (P1507), and the idle started changing (it would drop to 1200 or something, then start climbing up). We took it for an "off-boost" drive as described in this thread, and let it sit for 20mins. After clearing the CEL we started it up again, and we had the same problem/CEL. EDIT: Oh, also, there was no smoke coming out of the tailpipe when we took the car for a drive. So we left it overnight, made sure the bolts were still tight in the morning and fired it up again. The start up wasn't quite as smooth (it didn't turn over as quickly) as when the car was new, and it went immedietly to a high idle. After 10 seconds, there was a shudder, it threw the same CEL, and the idle start being odd again (it went lower, than started creeping up). So, any thoughts. Did we break something. Did we somehow install the valve wrong. Is the IAC now completely gone? Should we bother to remove and reinstall the valve again, just to make sure? Also, anyone know what the part number is for the IAC valve. Last edited by AVATAR-X; 07-14-2007 at 11:53 AM. |
| Thread Tools | |
| Display Modes | |
| WTB: IACV (Idle Air Control Valve) | JasonF | Private 'Wanted' Classifieds | 1 | 07-29-2009 01:40 PM |
| WTB IACV (Idle Air Control Valve) | Tical | Private 'Wanted' Classifieds | 2 | 05-22-2009 02:31 PM |
| wtb- IACV (Idle Air Control Valve) | BrettS | Private 'Wanted' Classifieds | 2 | 05-03-2006 10:57 AM |
| IACV Idle Air Control Valve | jvcastillo21 | Private 'Wanted' Classifieds | 6 | 02-10-2006 10:02 PM |
| How To Replace The IACV Gasket (Idle Air Control Valve) | scooterforever | Factory 2.0L Turbo Powertrain | 10 | 04-21-2005 05:52 PM |
