Old 07-14-2007, 02:51 PM   #101
scooterforever
Member#: 55011
Originally Posted by AVATAR-X View Post
Also, anyone know what the part number is for the IAC valve.
You could try cleaning it again, but sometimes they just go bad. You can get the parts number from subaruparts.com, but you'll need to register (free). You can get 'young' IACVs by buying complete throttle bodies off car-part.com, I've seen them go for $100 or less, and you get a spare TB in the process.
scooterforever is offline   Reply With Quote
Old 07-14-2007, 03:31 PM   #102
AVATAR-X
Member#: 4889
1996 Impreza LX 2.2
Aegean Blue
My question is this, it is now worse after cleaning it than it was before. Now it actually throws a code P1507, where before it just had some cold start/idle issues.
So, is it more likely that we broke it by removing/cleaning it, or did we somehow not seat it properly/tightly enough? Did we need to go and drive it more to be seated correctly, get it on boost or something (we just did off-boost driving). Or is it something else - is there some procedure for "resetting" after having unplugged it we kinda did the priming thing that was mentioned, though we might not have given it as much time as called for in the instructions.
Hmm... I wonder if I can find a test procedure for the IAC somewhere - I thought I saw some reference to using a volt-meter.
AVATAR-X is offline   Reply With Quote
Old 07-15-2007, 11:34 AM   #103
Metallrulz
Member#: 100148
2003 WRX Wagon
The easiest way to take off the IACV's screws is with an impact screwdriver, like this:
Just use a flat head bit and it comes off in seconds and doesn't mess up the screw heads.
Metallrulz is offline   Reply With Quote
Old 07-15-2007, 12:37 PM   #104
rick-l
Member#: 33868
2003 wrx
srp
Originally Posted by OLO View Post
SWEET!! I have been having the same issdue, high idle of 1500RPM in slow traffic and hot weather. I will give this a try also. Thanks for the great advice.
Did cleaning your IACV fix this?
rick-l is offline   Reply With Quote
Old 07-16-2007, 12:41 PM   #105
jc54 wrc
Member#: 154119
2002 WRX Wagon
WR Blue/mud
Originally Posted by WRX_REED View Post
I know this thread is a bit old but has anyone tried using RTV silicon in place of the rubber gasket in small amounts so no swished out silicon falls into the intake chamber?
Out of desperation, I tried that, but the RTV didn't keep the coolant out. On the second try, I used a small amount of RTV and fashioned my own gasket with rubber gasket paper, and I still don't think it's keeping the coolant out. I know it already got a little coolant into the intake, so I let it run to burn that off, but the amount it's burning off makes me think the new gasket isn't secure.
Now that I know the gasket is cheap to replace (and now that I know where to find it), I think that's the best way to go.
jc54 wrc is offline   Reply With Quote
Old 07-23-2007, 09:53 AM   #106
subywrxtuner6969
Member#: 119526
That was a awesome write up, it really helped
subywrxtuner6969 is offline   Reply With Quote
Old 07-24-2007, 03:06 PM   #107
TurboRex
Member#: 8635
04 STI, 07 FXT
I have an 04 sti with a big maf intake (perrin). The car idles rough at times and is becoming harder to start. It also dies most of the time if you push in the clutch when slowing down from the freeway (or at a speed of around 40mph or so). If you rev the motor or hold it at a high speed when just sitting there, it will not die.
My iacv appears different than the picture noted earlier (assuming due to the DBW). The dealer noted there is an IACV gasket for my car but I am not sure. Anyone know about the sti and/or what could be my problem?
Thanks,
Greg
TurboRex is offline   Reply With Quote
Old 07-25-2007, 11:59 AM   #108
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Thanks,
Greg
Same boat as you Greg!
Bumping up to see if anyone can help...
-nigel
NewShockerGuy is offline   Reply With Quote
Old 08-04-2007, 03:11 PM   #109
veilside5
Member#: 153972
Many thanks for this DIY thread!! Sorry about bringing an old thread alive but I'm having some questions.
I own a 02 WRX and when I shift, my RPM goes up (between 200-500RPM). I'm sure that it's not because I press the gas pedal, it's really something else. I'm 100% stock. Some people told me it could be the IACV that was dirty. So I cleaned it all, but it still doing the same thing. My idle is fine...
What do you guys think??? (And please rep me, I can't start a new thread )
veilside5 is offline   Reply With Quote
Old 08-07-2007, 04:48 PM   #110
veilside5
Member#: 153972
ttt anyone??
Old 08-12-2007, 10:47 PM   #111
prez04tswag
Member#: 156476
Can anyone help me locate the IAC valve on an '04 impreza ts wagon? It doesn't seem to be on top of the TB as shown in these photos.
prez04tswag is offline   Reply With Quote
Old 08-14-2007, 08:37 PM   #112
MK19
Member#: 21977
Bear s like food
First off- tested the harness going to the IACV and it checks out per Subaru specs. If you want to see the manual for that troubleshooting the IACV, click here (right click, save as...) and search the PDF for Idle Air Control Solenoid. I didn't check the ECU connections yet, but if I am getting good power and the correct resistance at the IACV, odds are the ECU connections are ok- but I will check them just the same. I am going to clean the IACV yet AGAIN, this time by soaking it in SeaFoam and using Q-tips after. Has anyone ever disassembled the valve? I may bite the bullet tonight and do that.
MK19 is offline   Reply With Quote
Old 08-22-2007, 09:19 PM   #113
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Thanks for the post. I will be receiving a gasket this Friday and try to clean the IAC.
Old 08-24-2007, 09:49 PM   #114
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I cleaned it out today with MAF cleaner. Also replaced a gasket.
Old 08-25-2007, 12:00 PM   #115
MK19
Member#: 21977
Bear s like food
Followed Subaru's technique- no change... Tried to test the neutral position switch and it seems out of range. Replacing it next.
Old 09-01-2007, 03:21 PM   #116
20SUBIEWRX02
Member#: 153112
2006 STI
hey guys i have a problem with my rpms. smetimes when i start my car it will start up normal and then just die and one day i started it three time till i got to the poit i had to keep the rpms up for like 3 or 4 sec before it would stay on and oneday it was high like in the 2000 rpm range so i was just wondering if that would be the IACV
20SUBIEWRX02 is offline   Reply With Quote
Old 09-01-2007, 05:58 PM   #117
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
QUE?
superhawk44 is offline   Reply With Quote
Old 09-03-2007, 09:38 PM   #118
20SUBIEWRX02
Member#: 153112
2006 STI
what superhawk
Old 09-05-2007, 12:42 AM   #119
triguy
Member#: 27109
2002 WRX Wagon
2.5L Crawford, 6 spd
Did this service recently. Instructions were helpful. I did have to remove the throttle body to get the vice grips on the IACV screw closest to the intake maniflod. A screw driver wasn't enough to loosen it. Once I got the vice grips on it, it loosened right up. I replaced the screws with the allen head bolts recommended. I cleaned the IACV using a spray bicycle chain degreaser that doesn't affect plastic parts. Followed the instructions on the install of the new gasket and break in and everything went fine.
triguy is offline   Reply With Quote
Old 09-05-2007, 12:30 PM   #120
fantomas
Member#: 87500
2012 Outback 2.5i P
Graphite Gray
How many miles are on the car? could be the IACV or a cam sensor. any check engine lights?
fantomas is offline   Reply With Quote
Old 09-10-2007, 08:18 PM   #121
fastlanerex
Member#: 133391
2004 boosted saleen
white
Originally Posted by overdose View Post
this gasket and it's proper replacement is BY FAR one of the most irritating features of the WRX, thank GOD my sti is dbw!
drive by wires suck you get real ****ty throttle response
fastlanerex is offline   Reply With Quote
Old 09-10-2007, 10:24 PM   #122
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
I used to think the same thing.
Old 09-11-2007, 12:21 PM   #123
20SUBIEWRX02
Member#: 153112
2006 STI
I have a check engine light and i looked at it and it said that my cat sensor was in the wrong place so i am getting a o2 harness so i can put it in the right spot. so i think that is why my check engine light is on but ill check it again. and what is the cam sensor and where is it located so i can check it out.
Old 09-14-2007, 09:16 AM   #124
scooterforever
Member#: 55011
I finally had enough. My idle was starting to go again, and after cleaning the IACV about 4 times, it was ceasing to have a positive impact. So...
I just installed a brand new IACV. Idle is perfect. Expensive, but at least cleaning bought me about 2 years of extra life to the controller.
Tonight I am installing a catch can to try to reduce oil vapor through the IACV.
Old 09-14-2007, 01:58 PM   #125
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i did the coolant bypass mod and the next day i got a cel for the IACV. should i reconnect the coolant line or just clean the IACV?
distorto is offline   Reply With Quote
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 01:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 02:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 10:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 10:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 05:52 PM
