Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 05-26-2008, 06:43 AM   #151
Barnacules
Member#: 170018
2005 WRX STi
Will this work on a 2005 STI?
Barnacules is offline   Reply With Quote
Old 05-26-2008, 07:20 AM   #152
Siper2
Member#: 1134
2007 BMW 328xi wagon
I don't see why not.
Siper2 is offline   Reply With Quote
Old 05-26-2008, 12:10 PM   #153
mostasz
Member#: 170512
2012 WRX
Ice Silver
Yes!
mostasz is offline   Reply With Quote
Old 05-29-2008, 04:46 PM   #154
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
I just got my gasket and a bag of replacement cap screws. Here we go!
WC LATHE WERKS is offline   Reply With Quote
Old 06-01-2008, 07:51 PM   #155
Special
Member#: 145585
2002 S202 11.9@120
Yellow
Subscribed
Special is offline   Reply With Quote
Old 06-13-2008, 03:49 PM   #156
03wrxowner
Member#: 155088
2004 WRX
Platinum Silver Metallic
I wish I would have found this thread earlier, cause I just spent $300 to replace it at the dealer!
03wrxowner is offline   Reply With Quote
Old 06-18-2008, 02:56 PM   #157
rick-l
Member#: 33868
2003 wrx
srp
Has anyone tried to take those (I think they are) Ribe fasteners out to see if you can clean it better? Is there a gasket there?
Is there a way to exercise it while it is out to get the cleaning fluid in there? It doesn't seem to want to turn.
Is that black gunk coming up through the intake from the intake valves?
It has been so long.... Is this the way it is supposed to work? Cold start 1200 rpm, warm 750.
rick-l is offline   Reply With Quote
Old 06-18-2008, 04:05 PM   #158
08BlueWRX
Member#: 182055
i tried this hoping it would fix my idle issues but it only fixed half of it.
before my car would idle too low or too high. cleaning the iacv fixed the low idle issue but my car still idles 2k-2.5K in traffic.
i think i need to adjust my throttle cable.
08BlueWRX is offline   Reply With Quote
Old 06-21-2008, 12:18 AM   #159
rick-l
Member#: 33868
2003 wrx
srp
No Joy
After a thorough cleaning it seems to have improved but after a hot start it still sticks at 2000 rpm
Old 06-21-2008, 03:39 PM   #160
mostasz
Member#: 170512
2012 WRX
Ice Silver
Originally Posted by rick-l View Post
No Joy
IF engine is hot and idles at high RPM try loosen Your cruise control line. They are usually too tight, and when line heats up, outer part expands, pulling the inner part and making engine idle high.
My car was doing it, i pulled over on highway traffic and loosen it, and idle is fine ever since.
3 minutes of work, and so much better
Old 06-23-2008, 07:14 PM   #161
rick-l
Member#: 33868
2003 wrx
srp
You were right it worked. Look how much it was adjusted to get slack. I am at the end of my rope so to speak.
Old 06-30-2008, 02:37 PM   #162
wefbster
Member#: 183525
2002 impreza 2.5ts
Originally Posted by Rawker View Post
my engine looks like this, where is the IACV?
note this is not my picture
I am having the same issue. Please help!
wefbster is offline   Reply With Quote
Old 06-30-2008, 04:12 PM   #163
mostasz
Member#: 170512
2012 WRX
Ice Silver
I'm glad it worked for You! High idle was making me crazy
Old 07-12-2008, 12:46 PM   #164
dzurok
Member#: 94179
I just finished cleaning the IACV today, but this also sounds like a good idea. The car has been getting ridiculously hot in the summer heat, and maybe this is contributing to my high idle in traffic. Gonna def. give this a try. Thanks!
dzurok is offline   Reply With Quote
Old 08-13-2008, 03:26 PM   #165
gooder77
Member#: 32922
2002 WRX sedan
Excellent thread, though it appears my IACV is dead. I cleaned it twice. Well the first time i cleaned it using the alcohol and q-tip method, used a new gasket and put it back on. I used my AP to reset the ECU. Once I started it rpm climed to 2k and threw the CEL 1507...again.
I cleaned it again with MAF cleaner (I didnt have TB cleaner), soaked it and it looked much cleaner the second time around. I put it back in and idle climbed to 2000. I blipped the throttle and it dropped to 1500. Driving around it seemed fine until I came to a stop. RPM would bounce from around 1500 to 2000. Then it held at 2000 and CEL 1507 came on yet again.
Unless there's anything else I should do I'm thinking it's dead. I did manage to find someone in the classified selling whole throttlebodies. I also checked out car-part.com and they're got a load of TB's on sale. They also seem to list "TB valve assembly" which are listed cheaper than the whole TB. Would the IACV be part of the "assembly"?? Having to possibly spend $300 for a new IACV does not bode well with me
gooder77 is offline   Reply With Quote
Old 08-14-2008, 12:08 PM   #166
rick-l
Member#: 33868
2003 wrx
srp
See that picture right above your post? You did verify that the cruise control and for that matter the throttle cable wasn't holding the throttle open. Try pushing it closed when it is idling fast.
My 2003 threw code P0519 Idle Air Sytem Performance when the cruise cable held the throttle open.
Here is the freeze frame data for the fault
Make: Subaru Model: Impreza Year: 2003
VIN: Not Reported
________________________________________
MIL: On
Diagnostic Trouble Codes
P0519 Idle Air Control System Performance
Freeze Frame (Frame 0) for DTC P0519
Calculated Load: 3 % Coolant Temperature: 192 F
Engine RPM: 1538 r/min Fuel System Status Bank One: Closed Loop
Fuel System Status Bank Two: Not Reported Intake Manifold Absolute Pressure: 10.9 in.hg
Long Term Fuel Trim Bank One: 3.12 % Short Term Fuel Trim Bank One: 1.56 %
Old 08-14-2008, 01:39 PM   #167
gooder77
Member#: 32922
2002 WRX sedan
Yep. Checked that. Even put a little more slack and it's still throwing 1507.
Old 08-21-2008, 10:34 AM   #168
lostkidd2
Member#: 187490
my friend just put his 02 wrx back together but now it idle alittle below 2000 and when slowing down it surge. the code that came up was the p1507 code and misfire on 2. so we did the cleaning to the iacv but it still does it. so we checked it by pressing the ac button but instead of the rpm rasing it droped alittle. what else should we check or what iwll fix this? thanks
lostkidd2 is offline   Reply With Quote
Old 08-21-2008, 01:02 PM   #169
dannypwr
Member#: 91700
I adjusted the throttle cable and havent seen the idle surge now , its been about 2 months. I also have the gasket but never istalled .
dannypwr is offline   Reply With Quote
Old 08-25-2008, 08:58 AM   #170
1BDREX
Member#: 153047
04 WRX
i wish i would have known the problem w the gasket before doing this to my car. got code P0519 and the cars idle was like 1900rpm. pulled the valve to clean it, put it back on and it didnt work. took it out again, cleaned it again and put it back on and now i had coolant flowing into my TB. when i pulled it out again i noticed the gasket was broken and i had a LOT of coolant inside the TB. after drying it ran the motor again w the coolant line disconected and it just started smoking real bad and running like ****. shut it off and tryed cranking it back on and now it seems my plugs are fouled cause it will turn but wont fire. now i gotta pulled the plugs and try to get watever coolant is left inside the motor before is too late, which i hope is not too late.
1BDREX is offline   Reply With Quote
Old 08-25-2008, 05:26 PM   #171
Jason Temple
Member#: 42135
2003 wrxsedanstageII
WR Blue
I had been plagued by this same problem (not on the low side, only high idle on hot days). I had ESP tuning in Shirly, MA take a look at it and they put in on their dyno and ran it hot to reproduce. The conclusion:
I have a cobb tuning dp that necessitated the removal of the stock dp heat shield. Without the shielding the extra heat on hot days was enough to shrink the cruise control cable casing causing it to bind up and not release (idle climbs with driving and never backs off).
Solution: disconnected cruise control (who uses it in these cars anyway) and am looking to get a proper heat shield from cobb.
They cleaned my IAC too which helped smooth out the idle (or maybe it's in my head).
hope this helps someone...drove me nuts all summer long idling at 3K in stop and go traffic!
Jason Temple is offline   Reply With Quote
Old 08-25-2008, 11:50 PM   #172
gooder77
Member#: 32922
2002 WRX sedan
Just wanted to update my situation (abridged): Had bad IAC and got the cel 1507. Cleaned it as directed on this thread several times with no luck. I picked up a used one on the boards and I'm back in business! I did notice that the valve on the used one moved both directions when I swabbed it. My bad IAC was stuck though after one last shot with some aggressive swabbing today it moved in one direction, but not the other. I'll be taking it apart completely to see if I can fix the bad IAC. It might have been that the bad IAC was just really gunked up...or the little motor might be really dead. If it's the former I may have a spare IAC for someone.
Old 08-26-2008, 12:03 AM   #173
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Dude, I have the Cobb catted DP and I'm using the stock heatshield that has been trimmed a little, works perfectly fine.
eurospek is offline   Reply With Quote
Old 08-26-2008, 09:18 AM   #174
horriblesars
Member#: 152239
2004 MY05 WRX 290WHP
White + VF35
referring to the 1st post and the 1st pic, may i know what is the hose on the right side of the IACV used for?
i noticed that my IACV has not gotten a hose connected to it.
must be that my mechanic didnt put it back when removing the TGV.
horriblesars is offline   Reply With Quote
Old 08-29-2008, 09:23 PM   #175
daisyGT
Member#: 78203
Would this be the same location on a 98 Legacy GT, and are there any better pictures out there of the IACV location? My engine bay doesn't look like the one pictured.
daisyGT is offline   Reply With Quote
WTB: IACV (Idle Air Control Valve) JasonF Private 'Wanted' Classifieds 1 07-29-2009 01:40 PM
WTB IACV (Idle Air Control Valve) Tical Private 'Wanted' Classifieds 2 05-22-2009 02:31 PM
wtb- IACV (Idle Air Control Valve) BrettS Private 'Wanted' Classifieds 2 05-03-2006 10:57 AM
IACV Idle Air Control Valve jvcastillo21 Private 'Wanted' Classifieds 6 02-10-2006 10:02 PM
How To Replace The IACV Gasket (Idle Air Control Valve) scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-21-2005 05:52 PM
