Old 06-02-2005, 03:26 PM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default High RPM power loss (stutter?)
I have an 02 wrx, just recently completed an ej22t swap. I am trying to iron out all the bugs from the swap. One unusual issue that I am having is at about 6700-ish rpms, the car just seems to sputter out. It pulls really strong all the way up to that point and then just poofs out. It drops power too quick for it to just be the turbo dropping off.
It's a rare occasion that I make it to 7k rpms. I have datalogged using the UTEC and on paper everything looks good. AFRs are ~10.8:1, boost is full on and no knock (I have even played with lower timing values, but no change). Although if you keep the pedal sustained between 6700-7000 rpms, it occasionally will throw the knock signal, but it seems more like the sputter you get from misfire than it does knock.
My plugs were brand new just before my #4 piston bit it on the 2.0 ltr. I had them gapped at about .030, so last night I regapped at about .027-.028, still no change. I comp. tested the engine. My cheapo guage showed 135, 135, 136, and 140 so there doesn't seem to be a problem there.
Any other ideas? I may try just changing the spark plugs out alltogether.
Matt
TyranosaurusWRX is offline   Reply With Quote
Old 06-02-2005, 03:37 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
What are your IDCs?
mcowger is offline   Reply With Quote
Old 06-02-2005, 04:03 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I am at work at the moment so I cannot give the exact number, but rest assured it was less than 70%.
My MAF voltages are approaching 4.7v. It may be entering the grey area, but my no means is it maxxed.
Old 06-02-2005, 04:41 PM   #4
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Well, if your IDCs are that low, then I'm out of ideas given that you've pulled out the timing.
Old 06-02-2005, 05:14 PM   #5
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Yeah, it's unusual. I am hoping it is nothing more than an ignition issue..I considered the fuel pump (Walbro)....but then I'm sure I would see a lean condition if that were the case.
Old 06-03-2005, 02:31 PM   #6
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Man this is complete crap. I changed out the plugs with different ones, still exact same scenario. I happen to have a spare crank pos. sensor lying around so I swapped that out.....now the sputtering is happening before 6k instead of after. I swear if this is another coil pack I am going to rip out the coil-on-plug system and find a new way to fire this thing.
Old 06-03-2005, 03:40 PM   #7
TAZ_WRX
Member#: 33364
clean the MAF and see what happens
TAZ_WRX is offline   Reply With Quote
Old 06-03-2005, 04:37 PM   #8
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I'll try that. The MAF is actually brand new, but, I do have a lightly oil K&N, maybe it dirtied it up.
I have confirmed that it is definitely misfire.
Old 06-03-2005, 07:26 PM   #9
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Welp, a dirty MAF is not the problem either.
Old 06-07-2005, 04:58 PM   #10
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
We can add coil pack to the list as not the problem. I give up... This is a tough one. Valve adjustment maybe????
Old 06-07-2005, 11:33 PM   #11
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
misfires are a b***h
2008 STi high rpm power problems uuarex Warranty Issues & SOA Problems 44 05-02-2013 05:00 PM
Large exhaust causing low RPM power loss? fugazni Newbies & FAQs 14 05-22-2010 07:42 PM
how damaging is high rpm/power missfires SOOBE Engine Management & Tuning 1 02-27-2006 11:57 PM
high rpm = power loss ? poopysnaps Transmission (AT/MT) & Driveline 10 03-01-2004 11:51 AM
high speed-high rpm power drain KITTbri Normally Aspirated Powertrain 18 04-19-2001 06:22 AM
