Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 06-02-2005, 05:55 PM   #1
ragnarok
Member#: 40784
04 sti
blue
Default Why do low beams turn off when you turn on high beams?
I'm curious as to why this is and if there is any technical reason for it. I have an sti which has the highbeams and low beams seperate so it would seem they shouldn't interfere with each other.
I'm thinking that instead of installing more lights, I'd like to use what I have to illuminate the close as well as the far.
ragnarok is offline   Reply With Quote
Old 06-02-2005, 06:21 PM   #2
ChrisL2
Member#: 1444
Huh? STi low beams don't turn off when the high beams are on.
ChrisL2 is offline   Reply With Quote
Old 06-02-2005, 06:50 PM   #3
2phless
Member#: 69343
1998 TransAm cnvrtbl
Ditto. Mine stay on. A lot of cars do drop out the low beams but the STi doesn't. Unless you are not referring to the STi in your sig.
2phless is offline   Reply With Quote
Old 06-02-2005, 07:06 PM   #4
ragnarok
Member#: 40784
04 sti
blue
Thanks for the replies! then my issue might be something else... I thought it was weird...
Old 06-02-2005, 09:31 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
ragnarok are you in Canada?
Old 06-02-2005, 10:56 PM   #6
WRXRgr
Member#: 54942
2004 WRX
...they don't have the HIDs up there, right? But on MY04 WRX (non-STi), the low's stay on with high's...
WRXRgr is offline   Reply With Quote
Old 06-03-2005, 05:22 AM   #7
Clavo
Member#: 22303
2002 WRX Wagon WRB
2006 W211 e55 AMG White
I wish teh WRX lows stayed on with teh highs.
Clavo.
Clavo is offline   Reply With Quote
Old 06-03-2005, 10:33 AM   #8
WRXRgr
Member#: 54942
2004 WRX
On 04s they do.
Old 06-03-2005, 02:35 PM   #9
ragnarok
Member#: 40784
04 sti
blue
no, not in canada, I've got a usdm sti... i was just comparing my hid's with my friends and for kicks we checked out the highbeams too... only i noticed my lowbeams go dark- which to me didn't look like it needed to.
Old 06-03-2005, 03:23 PM   #10
sevendhappy
Member#: 16283
Teh Car n00b!
G-Club represent!!!
I believe all factory HID systems (sti, bmw, audi, s2000) are setup so that when you activate the hi-beams the low beams stay on with them since it's not good to be flashing HID bulbs on and off. I believe halogen bulbs are different and can be flashed on and off, which is why halogen headlamps turn off the low beams when the hi-beams are activated.
Someone correct me if I'm wrong here. I'm just taking a shot in the dark with what I've only seen.
sevendhappy is offline   Reply With Quote
Old 06-03-2005, 08:12 PM   #11
Clavo
Member#: 22303
2002 WRX Wagon WRB
How can you take a shot in the dark when talikng about lights
That answer sounds the best to me.
Clavo
Old 06-03-2005, 08:16 PM   #12
WRXRgr
Member#: 54942
2004 WRX
Clavo
Never heard of Lucas electronics, eh?
Old 06-03-2005, 08:42 PM   #13
Clavo
Member#: 22303
2002 WRX Wagon WRB
Yes, As a matter of fact I have. Why do you think the English drink warm beer ??
Because Lucas makes refrigerators too.
<------------ His Dad races a 67 Vintage MGB.
Old 06-03-2005, 11:09 PM   #14
Zypper
Member#: 5201
'02 WRX Wagon
'11 Versys 650
Lucas, prince of darkness...
Don't want to overload the bulb housings when in hi-beam mode. HID's use less watts than Halogens so it isn't as big of a problem, also as others have pointed out cycling HID's = bad for life.
Zypper is offline   Reply With Quote
Where to Tap Fuel Pressure Line & Defis Turn off When I turn my headlights on 04ImprezaWRX Interior & Exterior Modification 7 05-22-2009 09:31 AM
Radio sometimes turns off when I turn off engine dauss Newbies & FAQs 3 04-06-2007 01:07 AM
Autometer Nexus gauge turns off when headlights turned on wazup Electrical & Lighting 1 08-13-2006 03:58 AM
Why would a car shut off when you lift off the gas? linux>windows Off-Topic 28 03-08-2006 09:38 PM
JDM headlights will not turn off when car is on druxboyz Electrical & Lighting 4 01-13-2006 09:39 PM
