Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-30-2005, 01:26 PM   #51
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
I am sitting in my car right now and when I hyperterminal into the Tuner it only takes shift + '1' to go into the .csv data 1 logger.
This is what I thought. I did some bench testing (without Tuner), to make sure the keystrokes were being sent to the Tuner during a "Connect"... it it working just as the UTEC port does.
However, before sending the Shift-"1" to the Tuner, I am sending a Carriage Return first... do you think this is causing it to mess up?
I send the CR with the UTEC too, because when you first connect you need to "wake" it up, but perhaps the Tuner is not this way.
Could you test in hyperterm to see if sending a CR before sending Shift+"1" is causing it to go into a different menu, or somewhere unexpected? I definately want to fix this before I post the next release of fixes.
Thanks,
-jason
jmussetter is offline   Reply With Quote
Old 06-30-2005, 10:12 PM   #52
Tap
Member#: 21893
2002 WRX w/STi swap
When I go into hyperterm I can start logging by immediately sending shift+'1' or I can go to the main menu using CR and then shift +'1'. What you are sending (CR, shift + '1') should work.
I can hyperterm into the Tuner and start logging and close the hyperterminal, if I reopen the hyperterminal the Tuner is still logging. So this shows the tuner will continue to log even if the port is closed. If I try opening the MPS logger with tuner still logging (and the hyperterminal port closed) still nothing happens. BUT when I hyperterminal back into the tuner (after closing the connections in MPS logger) the Tuner is no longer logging. I tried this several times with the same result. When the MPS accesses the Tuner it causes the Tuner to stop logging. Whats that mean? Hell if I know.
Travis
Tap is offline   Reply With Quote
Old 07-26-2005, 04:28 AM   #53
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
New version available on Download site...
No new features, except some important "bug" fixes made. The Sti logging should now work properly.
TAP - I also made changes to the Tuner connection attempt, if you could check it out and see if it works or not I'd appreciate it...
-jason
Old 07-26-2005, 12:55 PM   #54
battlewagon
Member#: 90855
It's telling me that the compressed folder is invalid or corrupted.
battlewagon is offline   Reply With Quote
Old 07-28-2005, 07:42 PM   #55
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Is this during downloading it, or installing it? I will do some testing myself on it. Is anyone else having these issues? I'm now running an updated version of VB as well as the Package and Deployment Wizard. This may be the cause.
-jason
Old 07-28-2005, 11:38 PM   #56
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
I did some testing on both of my XP Pro PC's with no problems. I even downloaded the file from the website to reproduce the steps that would be taken to install the program.
I removed my previous version via Add/Remove Programs and installed the newer version without a hitch. No errors or warnings were given...
What OS are you running on your PC? I know that Win2000 has known issues installing programs made with package and deployment wizard. Another thing to try would be to download the file again and retry, maybe the file got corrupted during download.
-jason
Old 07-28-2005, 11:42 PM   #57
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Default Tech Edge WB
BTW, I should mention before someone asks about it...
Yes, the new version 2.2 lists the "Tech Edge" as an available wideband unit...however this doesn't function yet... Don't bother trying it, it won't work in version 2.2. The code for the TechEdge is only partially developed and I felt I needed to get the Sti logging bug fixed and released as early as possible.
-jason
Old 07-31-2005, 03:17 AM   #58
Tap
Member#: 21893
2002 WRX w/STi swap
-jason
I am currently having serial/usb cable issues and will test out the logger later in the week (after I buy a new cable )
Travis
Old 08-03-2005, 03:53 PM   #59
battlewagon
Member#: 90855
jason, I redownloaded the program and it seems to have worked this time. No problems with the install either, thank you for that.
Now I need to hook up with the WRX again.
Unfortunately, I drove the truck in this morning.
I'll keep you updated.
cheers, Steve.
Old 08-03-2005, 07:06 PM   #60
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Default New Version 2.3
New Version 2.3:
Now supports Evo8 UTEC logs, and has minor speed improvements...
Here is the link to the updated download page...
MPS_UTECLogger Download Page
-jason
Old 08-03-2005, 07:15 PM   #61
gadget951
Member#: 18419
WR Blue
Just updated to 2.3, thanks for the great program and all the work you put in to it.
Scott
gadget951 is offline   Reply With Quote
Old 08-03-2005, 07:30 PM   #62
gadget951
Member#: 18419
WR Blue
"Create "compliant" UTEC LogFile" Why the rewording?
Is there a way to have the log map page open to full screen by pushing say f11 like with IE or just a maximize box in the top right corner?
Old 08-04-2005, 02:18 AM   #63
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Mostly because now that the Sti and Evo UTECs are supported, they don't have a AFR column at all, so the program isn't "overwritting" the UTEC AFR, it instead "inserts" a new AFR column where the regular WRX AFR is located, thus making it compliant.
-jason
Old 08-05-2005, 03:37 AM   #64
bluesube2000
Member#: 54446
03 WRX
wut does the cell hit count (sum) do 4 this prog?
bluesube2000 is offline   Reply With Quote
Old 08-05-2005, 02:11 PM   #65
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
The "cell Hit Count (sum)" simply keeps track of how many time the program has recorded data for each cell on the map. each time a log-line is received and processed to the LogMap, the Hit Count for that cell is incremented. The Hit Count is used internally for calculating averages, however it can be handy to check how many "Hits" a cell has had to determine how accurate the data in that cell may be.
For instance, if AFR was showing 12.4 in a cell where you want it to be 12.2. You can look in the Hit Count of that cell, and if the hit count is low, 1or2, then you know that the AFR reading "might" be a fluke, however, if the hit count is something like 100, then you know you definately need to richen up the cell.
A lower hit count is more effected by skewed data than a high hit count is.
-jason
Old 08-06-2005, 03:21 PM   #66
Tap
Member#: 21893
2002 WRX w/STi swap
-jason
I tried it out and now it takes the very first value that it reads for the WBO2 and only shows that. for example, it 13.8 is the first value that the logger reads from the tuner that value does not change on the display or the logger output, no matter what the true reading is. If you disconnect and reconnect without shutting the program down just "0" is displayed and inserted into the log.
I would really like someone else to try this logger with their Tuner to ensure this problem is not caused by WinXP or my toshiba laptop.
Old 08-06-2005, 05:51 PM   #67
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Sent donation. Thanks for your hard work
kingtut12 is offline   Reply With Quote
Old 08-08-2005, 01:28 PM   #68
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
OK, does this mean we are getting closer? So the question I need to ask is this, if you start fresh, and try to connect, then disconnect, then open up hyperterminal to see where in the Tuner menu it was left off? Did it actually make it to the <shift>+1 logging screen, or is on the main menu like before? That was very good troubleshooting you did last time to determine if the Logger was connecting or not.
Getting 1 value from it *could* mean that it's logging now and I just have a parsing error to deal with, or it could be a fluke, and we're still back at step 1 with the connection not working still.
Also, if you want to send me your email address, I can email you changes to the logging program to test after I make changes to the Tuner stuff. I would really like to get this sorted out, as I'm sure you would like to have it working correctly as well. Any troubleshooting you can do would be appreciated.
I would be curious as well if others have the same problem. My guess is that the problem is NOT WinXP or your toshiba laptop as I'm devoloping the program on a Toshiba Laptop and WinXP Pro SP1. Your system is about the same as my development pc.
-jason
Old 08-12-2005, 12:10 AM   #69
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
News Version 2.4
New Version 2.4 Available for Download...
New Feature: Ability to save out LogMap tables to .csv file for importing in Excel (or other spreadsheet program). Exports any combination or ALL of the 8 LogMaps to file.
Fixed: Evo8 parsing bug causing timing and IDC to display incorrectly.
Happy Tuning!
-jason
Old 08-12-2005, 12:21 AM   #70
gadget951
Member#: 18419
WR Blue
Thanks for the update and all the work you put in to this. I use your program every morning on the way to work, at lunch, and then on the drive home not to mention at the track (1/4 mile that is).
Scott
Old 08-12-2005, 09:00 AM   #71
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Question: I want to view the AFR information in that nice big window you have. When using this with a WRX UTEC with Tuner Pro do I have to seperate the serial cables and have both plugged into my laptop? By default the AFR info is already in the UTEC log file. Does the SW extract the AFR info itself or do have have to seperate the serial cables and setup the SW to look at one for the UTEC and the other for the tuner?
mick_the_ginge is offline   Reply With Quote
Old 08-12-2005, 01:53 PM   #72
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Yes, the software was designed as a bridge, so AFR is not parsed from the UTEC port at all. (I know this would be handy, and will maybe be added in the future, but will require quite a bit of code rewriting to change). The software treats the Tuner like any other stand-alone wideband that needs to be connected seperately from the UTEC.
Let me know if this the Tuner is works for you once connected in this fashion. TAP reported to me that the Tuner isn't being put into Logging mode properly from the software, and has been having issues getting it to work. I myself use an LM-1, so I don't have a Tuner to test/debug with either, so I'm not sure if this issue is resolved yet or not.
If you do have problems (or success) getting the Tuner to log, I would like to hear from your experiences. The more info I can get about the problem, the more likely I can figure out what is causing it.
-jason
Old 09-20-2005, 02:26 PM   #73
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Jason,
I stumbled upon this last night. So I downloaded 2.4 and hooked it up to my utec. Everything went well.
Then today, I grabbed one of the LM-1's here at work and plugged it in via a serial->usb plug. UTEC logs comes up but the LM-1's numbers don't. Thought, OK maybe i'm having issues with the serial->usb connector, so I switched the UTEC and LM-1 around and changed the com ports in the software. Still no luck with the LM-1 numbers coming up.
One thought I have is do I have to download the LM-1 software to get this to work? Or can I just plug the serial cable into the computer and your software sucks it out?
I'm not real computer literate when it comes to this stuff, but any help is appreciated.
thanks,
Tim
SloRice is offline   Reply With Quote
Old 09-20-2005, 03:11 PM   #74
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
The most probable cause is the LM-1 that you used at work is probably running older firmware. Download the latest LM-1 firmware from Innovate Motorsports website and flash the LM-1 with it...
Firmware versions prior to 1.4 for the LM-1 do not output any data during operation. Earlier versions of the LM-1 need to be upgraded in order to receive data from them.
Good luck!
-jason
Old 09-20-2005, 10:38 PM   #75
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Thanks Jason!! Downloaded 1.41 and works like charm!!
Calling all UTEC users in NoVA/DC/MD area Chino1 Mid Atlantic Impreza Club -- MAIC 22 01-03-2008 06:27 PM
Calling all UTEC and/or Tuner users - need some help lancelucas North West Impreza Club Forum -- NWIC 0 11-03-2006 12:26 AM
calling houston UTEC users datdudedennis Texas Impreza Club Forum -- TXIC 6 03-06-2003 09:08 AM
EcuTek Delta ECU - calling all DDash users Ken C Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-03-2002 04:09 AM
Calling all intake users (kindof) mike270 Normally Aspirated Powertrain 3 01-06-2002 08:49 PM
