Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 10-30-2010, 02:45 AM   #126
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
Dead thread... but in case anyone is still trying to get this to work... I got the trial and got it working pretty quickly. I just installed an AEM UEGO and picked up a second Serial-USB adapter and will test that tomorrow.
However, based on the lack of updates in this thread or on the website, I'm guessing it's not supported anymore and will be looking at the UTEC Interface (UTI) instead which has been updated this year.
filbert is offline   Reply With Quote
Old 11-08-2010, 09:15 AM   #127
wrxsubie2008
Member#: 262393
2008 Subaru WRX
This sounds like a cool program will defentily try it once i get my utec. Hopefully it will arive tomorrow.
wrxsubie2008 is offline   Reply With Quote
Old 11-08-2010, 09:15 AM   #128
wrxsubie2008
Member#: 262393
2008 Subaru WRX
What is some good software to start out with while using the utec. Mine is arriving hopefully tomorrow
Old 11-08-2010, 09:21 PM   #129
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
I got this to work with my UTEC but it's having problems with my AEM UEGO. It works for several seconds, then craps out and gets stuck on the last reading. The rest of the UTEC info continues to updates correctly, it's just the AFR that stops. If I disconnect and reconnect, it does not work. I have to close out and re-load it, but then it will freeze again after a minute, making the AFR logging useless. I tried logging in directly to the UTEC and UEGO using PUTTY (I'm on Vista which has no HyperTerminal) and those seem to work fine, I'm not getting strange AFR values or anything.
I'm going to check out UTI as soon as some PayPal funds clear and see if that works any better.
Old 11-08-2010, 09:35 PM   #130
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I never could get it to work at all.
bcblues is offline   Reply With Quote
Old 11-22-2010, 01:35 AM   #131
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
Ok, it seems the problem was with my computer. I was using my work computer, an HP Elitebook 6930p running Vista.
I just switched to an old VAIO I got from my mom running XP with USB 1.1 drivers (couldn't get USB2.0 drivers to work after reinstalling XP) and both the UTEC and UEGO work fine with this setup.
Also, i found an USB-to-Dual Serial Port cable from Fry's so I can hook both devices up to a single USB port.
Old 10-05-2011, 08:37 PM   #132
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
I can't seem to get the logger to work. Im running the utec with LC-1 and its says there is a error if I have both plugged in and if im trying to just log the utec it trys to connect but then doesnt show anything?
And I seem to be having a problem with the utec communicating with the TPS and MAP?
I found a link to a explanation but the link doesnt work for me.
http://www.burago.com/wrx/Files/WRX-...er%20Guide.pdf
Garrek11 is offline   Reply With Quote
Old 10-06-2011, 09:47 AM   #133
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
Just the logger doesn't work? or you can't even get connected with both? does the UTEC and LC1 both connect fine on their own (use hyperterminal or putty). What is the error? I've seen that pdf many times, i'm sure there are other copies on other sites.
Old 10-06-2011, 08:20 PM   #134
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Hyperterminal works with utec
LC-1 connects to its own software
So they both will connect seperatly to there own. But neither of them will connect in the logger. Except sometimes I can get the utec to connect but then it seems to just freez before it can do anything.
Old 10-06-2011, 08:42 PM   #135
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
Hmmm... I don't know. You're using two separate serial ports and cables? I would say check that the connection/protocol settings for both are correct in UTECLogger, but I haven't used an LC1 so I probably can't help you much...
Old 10-06-2011, 09:05 PM   #136
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Ya to serperate ones both go from serial to usb.
Old 07-07-2012, 08:51 PM   #137
matthewhiggins118
Member#: 197478
2003 Wrx
Sedona Red
So with this can you tune it or Just view it?
matthewhiggins118 is offline   Reply With Quote
Calling all UTEC users in NoVA/DC/MD area Chino1 Mid Atlantic Impreza Club -- MAIC 22 01-03-2008 05:27 PM
Calling all UTEC and/or Tuner users - need some help lancelucas North West Impreza Club Forum -- NWIC 0 11-02-2006 11:26 PM
calling houston UTEC users datdudedennis Texas Impreza Club Forum -- TXIC 6 03-06-2003 08:08 AM
EcuTek Delta ECU - calling all DDash users Ken C Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-03-2002 03:09 AM
Calling all intake users (kindof) mike270 Normally Aspirated Powertrain 3 01-06-2002 07:49 PM
