Old 06-04-2005, 04:00 PM   #1
somperson
Member#: 11203
1999 2.5RS
Blue Ridge Pearl
Default Blinkers won't work
I dont know what happened, but my blinkers won't work in my 1999RS. When they dont show any light/click or anything... I check fuses and everyone is fine, and everything else in the car is fine inlcuding reverse lights and brake lights.
Anyone ever heard of thise cause I thought it would just be a bad fuse or something...?
thanks,
Jason
somperson is offline   Reply With Quote
Old 06-06-2005, 06:47 PM   #2
somperson
Member#: 11203
1999 2.5RS
Blue Ridge Pearl
bump... People bitch at me left and right on the roads cause I dont use blinkers... I can't keep this up.. anyone have any ideas before i go and drop like 150$ on a Suby dealer to check it out....?
Jason
Old 06-06-2005, 08:39 PM   #3
Zypper
Member#: 5201
'02 WRX Wagon
'11 Versys 650
Can you put the blinker stalk into position, does it work like normal even if your blinkers don't? If not, inspect and replace the turn signal stalk if necessary. Also, you may want to check continuity.
Alternatively, does the emergency blinker switch work? if both are out, look into the possibility of a faulty relay.
Zypper is offline   Reply With Quote
Old 06-06-2005, 10:55 PM   #4
somperson
Member#: 11203
1999 2.5RS
Blue Ridge Pearl
I can put the lever into position and it clicks off normally on turns when it should. Hazard lights don't work. So I'm guessing a faulty relay switch as pending not a damaged wire somewhere in the car?
Thanks,
Jason
Old 06-07-2005, 10:20 PM   #5
R_W
Member#: 76896
If neither the turn or hazard work, it has to be something common. If the fuses are good, I'd check the turn signal module. Lay upside down with your head on the brake pedal, looking up. Should be right there (at least it is on WRX). I'd say turn it on and listen for the click-click, but that's the whole problem...
Small square box with 3 wires going to it.
RW
R_W is offline   Reply With Quote
Old 08-07-2008, 06:14 PM   #6
rae-anne
Member#: 186383
1992 subaru loyale
baby blue
Default blinker issues
my 1992 loyale's front turn signals will not blink, any advice? The parking lights work and the bulbs are good. The front hazards, however, do not blink. the backs blinks fine and the arrows and signal arm work fine also.
rae-anne is offline   Reply With Quote
Old 08-07-2008, 06:28 PM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The problem is most likely in connector F65. It is under the dash on the far left side and goes through the firewall. Try moving the connectors around to see if that helps.
Cougar4 is online now   Reply With Quote
Blinkers Not Working Temporarily Doz Newbies & FAQs 2 02-01-2010 04:17 PM
Upper Front Blinkers not working superbowl3232 Electrical & Lighting 0 03-06-2009 08:41 PM
front and side left blinker not working Der_Dude Electrical & Lighting 1 09-11-2005 09:16 PM
Attn: WAC my car won't work bill harvey New England Impreza Club Forum -- NESIC 8 04-23-2001 12:43 AM
Why the WRX won't work WRXrumors General Forum Archive 54 11-21-2000 02:12 PM
