Old 06-04-2005, 04:21 PM   #1
STi-Spec C
Member#: 75923
2004 18g WRX
Default car died and it won't start
hey i was driving my 98 impreza l wagon beater and took and corner pretty fast. i hit a pot hole mid corner and car dies at the corner exit. i tried to start but it won't start. the engine turns but then it just stalls. any help would be great
STi-Spec C is offline   Reply With Quote
Old 06-05-2005, 12:04 AM   #2
myobsej22
Member#: 88024
1997 OBS
red/gun metal two tone
will it turn over at all? and if so does it idle for a second and then cut out?
myobsej22 is offline   Reply With Quote
Old 06-05-2005, 04:35 PM   #3
Hayes
Member#: 11808
Look for loose electrical connections. Some models have a roll-over switch that shuts off fuel in the event of a roll-over. If you hit the pothole hard enough while in a high G cornor then you may have tripped the switch which must be reset manually.
Hayes is offline   Reply With Quote
Old 06-06-2005, 11:25 AM   #4
STi-Spec C
Member#: 75923
2004 18g WRX
thanks i bet that's what happened. how do you reset it manually though?
Old 06-06-2005, 06:11 PM   #5
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
You could have a MAF sensor issue, if it turns over then sounds like it is missing, and when you try to give it gas then you need a new MAF.
allsubaru83 is offline   Reply With Quote
Old 06-06-2005, 06:31 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Fuel slosh...Put a gallon of fuel in and it should start. Stupid saddle bag tank with only one pick up...
Subura died and now won't start 3maxman Normally Aspirated Powertrain 10 01-06-2008 01:40 AM
1993 Loyale: Turn Key, lights come on, and it won't start. Later it starts. Help Dance Electrical & Lighting 3 11-03-2007 09:32 PM
HELP!!! Car died and won't start back WRXINTX Engine Management & Tuning 2 08-10-2006 11:21 AM
my car got broken into...now it won't start hoostw Bay Area Impreza Club Forum -- BAIC 2 08-09-2004 02:20 AM
Car died on highway won't start?????? scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-27-2003 10:09 PM
