Old 06-04-2005, 11:39 PM   #1
T-St WRX
Member#: 24100
2003 WRX Wagon
Default Reattaching clock ?'s (keyless entry no longer works . . . )
Hello -
Today I removed a gauge pod and gauges that were in the factory location. For power/wiring I had originally clipped off the clock's wiring harness and attached the gauges there. To reinstall the clock I was planning to just rewire the wires to their corresponding colors on the harness, but this didn't seem to work (no power to clock/dash lights). I then tried a few combinations of attaching wires to each other and was able to get the clock to work, but now the keyless entry/alarm doesn't work.
Does anyone have suggestions as to what I could do to fix this? I thought I would ask all of you before I frustrate myself more.
Thanks in advance,
Robert
T-St WRX is offline   Reply With Quote
Old 06-05-2005, 10:57 AM   #2
T-St WRX
Member#: 24100
2003 WRX Wagon
More details i forgot to include last night . . . yesterday i also uninstalled an aftermarket cd player and an amp (which involved disconnecting the amp from the + battery terminal). Could this have affected the keyless entry/alarm?
Old 06-05-2005, 12:20 PM   #3
BMacushnet
Member#: 44988
YES is very well could have. Iv found that one fuse is wired to several devices. the factory alarm is also wired to the stock clock. The aux 12v power supply next to the ash tray shares the same fuse as the power windows. Look under the steering wheel there is a pull out tray. pull it out to open it up. then pull some more to pull it off. behind it is a fuse box. You could also check the alarm box itself. if you have the arm rest extenson open it up and pull off the panel that covers the e brake. there should be a box there its the alarm check the wires. my plug has a tendency to come out.
hope this helps
regards
BM2 Wester
BMacushnet is offline   Reply With Quote
Old 06-05-2005, 02:23 PM   #4
T-St WRX
Member#: 24100
2003 WRX Wagon
Thanks my friend . . . I appreciate it!
Keyless entry horn not working?? GTR STI Car Audio, Video & Security 13 08-30-2007 07:32 PM
dome light, map light, keyless entry will not work Samirr76 Electrical & Lighting 4 10-09-2003 08:41 AM
Keyless entry no longer beeping ZMANNH25rs Electrical & Lighting 13 07-10-2003 10:43 AM
Keyless entry does not work when WRX is running?? burton13 Car Audio, Video & Security 9 10-28-2002 11:51 AM
