Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-05-2005, 02:16 AM   #1
sessions
Member#: 85687
99 legacy SUS
white
Default speedometer electronics
I recently had an outbreak of mice in my 99 legacy SUS. Although I did not catch any of them, they did some damage to my car. I am pretty sure that they chewed on the speedometer cable, as my speedometer and odometer does not work correctly. It usually won't work when I am driving on the highway and only sometimes when I press and hold the trip reset button. Other times it works just fine.
I have no electric experience so I have not yet put apart my dash to confirm what is going on. I also have no idea what wires I should look at.
I was wondering if it was possible to just replace the wires that run from the instrument pannel to the ecu? If it is possible is it hard and where can i find a wiring diagram if nessecary to do it? Also what parts would I need?
If it is not possible to just replace the wiring, what needs to be done.
Any help is appreciate, thanks in advance.
sessions is offline   Reply With Quote
Old 06-05-2005, 09:08 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Since you have no experience and apparently don't have the wiring manual either, this is not a good DIY project. I'd suggest you take it to a shop or find someone in your area with the proper experience to help you. Ask in your local forum for assistance, I'm sure you'll be able to get the help you need.
Old 06-06-2005, 12:27 AM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The gauge cluster gets the speed signal from the transmission itself, not the ECU. The vehicle speed sensor sends a signal into the passenger compartment where it forks and goes to both the ECU and the gauge cluster. If the ECU doesn't see a vehicle speed signal then it goes into a sort of limp mode (my car won't rev above 4000rpm, for instance). It may be that you have lost the wire going to the gauge cluster but the wire going to the ECU is just fine. It could just be that your gauge cluster died too...
To check that, you have to pull the trim away from the gauge cluster and pull it back a bit to expose the wires. You can look at the back of it and see where most of the wires trace to. Get out your trusty volt-ohm meter and see if you are reading any voltage from the wire going to the speedometer (obviously without running anything over). If you get a signal then check for the gounds for the cluster as well as power. If both the ground and the power check out, then the speedometer portion of the cluster may be suspect.
-Jon
Old 06-06-2005, 12:39 AM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
IRT#3
That explains why I had rev problems when my speedo and odo went. I was going through town one day and I realised I had no speedo! Then on the way to work the next morning on the motorway I wondered why my engine refused to go above 4,000. I also had a CE come on too, so combined with rev problem I thought it was majorly serious. It turns out when my clutch was done the cable wasn't connected to the gearbox properly and it eventually came out with driving.
Well, that's what the grease monkey told me.
i_c_the_light is offline   Reply With Quote
It is designed like a big electronic part but actually NOT. Cole Off-Topic 13 06-02-2010 12:52 PM
ok. who actually knows ej20K electronics and ej20G electronics well? swapstar Subaru Conversions 24 12-21-2005 04:48 AM
('93-'01) Milage is stored in the speedometer wonko Impreza Forum 9 05-05-2001 01:06 AM
('93-'01) What makes a speedometer needle "shakey" Dobes Impreza Forum 4 04-09-2001 12:15 PM
('93-'01) 2002 WRX - Can't see the speedometer! RidinLow Impreza Forum 13 04-07-2001 01:14 AM
