Old 06-05-2005, 01:20 AM   #1
scooterforever
Member#: 55011
Default Ideas for more power with same turbo, engine
I am wondering if I am overlooking any potential power adders -- however modest -- from my roadmap. VF-34 and 2.0L stay for now. Intake, TMIC, and headers to be upgraded. Am undecided on water injection. My current setup:
1. VF-34, pinks, walbro
2. Y hoses
3. stock intake <-- to be upgraded; probably filter + silencer delete
4. stock TMIC <-- to be upgaded; probably Helix
5. stock headers <-- to be upgraded; probaby Fujitsubo
6. full 3" TBE (MadDad DP w/ cat, 3CE, Borla hush). Cat stays.
7. underdrive pulley
What else, without changing the turbo or upgrading engine components? Lightened driveshaft, lighter wheels. Other ideas?
scooterforever is offline   Reply With Quote
Old 06-05-2005, 01:40 AM   #2
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Nickel and dime stuff man. You are at the end of the line. NOS, Big turbo or new motor. There you have it.
ebeck is offline   Reply With Quote
Old 06-05-2005, 01:53 AM   #3
scooterforever
Member#: 55011
Yeah, that's what I figured. Just wondering if I can cobble enough of them together (e.g., throttle body coolant bypass -- during the summer at least, etc.) to get 4 or 5 whp.
The port & polish mods (e.g., knife edge on the throttle body) are spooling, not power, focused, right?
I should drop the VF-34 and put in a SBR-12... but I would rather spend $2,500 now rounding out the stage 4 setup than jumping to $4,000+ on the big turbo... but maybe I should just bite the bullet...
Old 06-05-2005, 01:54 AM   #4
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
colder spark plugs, grounding system, lightened flywheel(stay away from aluminum; forged chromoly, or billet steel).
dont get underdrive pulley only a lightened one, i had a unorthodox underdrive and i got cel flashes too often, so i got an agency power, although perrin is another good choice.
utec, ecutec..etc
aluminum radiator
ported throttle body
magnus motorsports intake manifold
perrin turbo inlet hose
better oil cooler
im sure there is more you could do.
jam69007 is offline   Reply With Quote
Old 06-05-2005, 01:59 AM   #5
scooterforever
Member#: 55011
Already done.
4EAT. No flywheel (or... just not the same, and not upgradeable)
Been running an underdrive pulley for 16 months, so far so good.
utec, ecutec..etc
EcuTek, custom dyno tune
aluminum radiator
Need to stay stock for the integrated ATF cooler/warmer. But good idea. Hadn't thought of that.
Is that a power adding or spool improvement mod?
Interesting
better oil cooler
Nice idea, but I'm already running a big ATF cooler, and am running out of room up front.
im sure there is more you could do.[/quote]
Thanks for the ideas! - scooter
Old 06-05-2005, 02:17 AM   #6
dust12
Member#: 13417
I would say water or alchahol injection. Approx 20+ hp depending on your tune.
dust12 is offline   Reply With Quote
Old 06-05-2005, 02:32 AM   #7
scooterforever
Member#: 55011
Yeah, I just need to decide whether I'm up to it on a daily driver.
Old 06-05-2005, 02:45 AM   #8
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
what is 4EAT, some type of auto trans?-unfamiliar territory
magnus motorsprts claims pretty decent power gains, it is also $1K ouch!
perrin inlet hose; definetly spool improvement
ported throttle body; small power improvement
what underdrive pulley are you using? our cars are so tempermental!
definetly power gain by getting thermal coating or wrap on exhaust parts, header,uppipe, downpipe
water injection is pretty neat, a guy on vivid racing has done this and raves about it.
colder thermostat ie. zero sports
since you are stuck on keeping cats, check out QTP (quick time performance) electric cutout for your downpipe. at the flip of a switch, exhaust exits before cat if you only have 1. if you have both cats in downpipe it would exit after first cat. about 1o hp gain so iv'e heard. you can buy a kit for what ever size pipe your downpipe is and cutting tool and welder you can fab your own.
Old 06-05-2005, 03:04 AM   #9
scooterforever
Member#: 55011
Yeah, need to port the throttle body. 4EAT is the auto version -- 4 speed electronic controlled auto.
I've been running the Vishnu underdrive pulley.
Old 06-05-2005, 08:50 AM   #10
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Default W/i
I have the 2d Aquamist system on my wrx, other than refilling the resivoir every three fuel stops, it is maintenance free. It lowers my EGT's greatly upon activation and I'm sure that it is the reason that I have not already toasted my engine I will never run another high-performance engine without w/i whether it's forced air or N/A.
Your biggest blocks for making more power right now are your:
Stock airbox (in your post you still haven't upgraded the filter or deleted the silencer).
Stock TMIC only cools and flows so much, not to mention pressure drop and heat soak.
Make the car breath better, in and out, and you will unleash the power potential of the car.
Other than the things others have already listed I have nothing else to add.
Kent
wrx plus is offline   Reply With Quote
Old 06-05-2005, 09:12 AM   #11
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
hey scooterforever you can geta new torque converter. that will help you with your tranny and get more power to the wheels. i had a 4EAT RS and i was thinking of upgrading mine. but i got a WRX instead. go to protorque.com they custom build one for your car.
hockeygm is offline   Reply With Quote
Old 06-05-2005, 10:49 AM   #12
scooterforever
Member#: 55011
Sorry, I left out my tranny mods. My tranny is pretty heavily built up, short of a full race tranny from IPT. I have a ProTorque high stall speed converter, a LevelTen valvebody (so far no problems [crosses fingers]), a 40,000 lb towing capacity ATF cooler, and an ATF temp gauge.
Old 06-05-2005, 11:30 AM   #13
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Oh sure. 4-5 whp is definitly possile. 20-30 is kinda stretching though. Can you feel 5whp? Good luck man. Sounds like a fun car.
Old 06-06-2005, 12:01 AM   #14
Rickyh
Member#: 40453
water/alky is fine on a daily driver. If anything I would think it increases reliability cuz it supresses the hell out of detonation and lowers egt's. I have a 3 gallon fuel cell in the trunk with alk/water and I went 2 months before filling it up. It still had almost a gallon in the tank at that point. You should really look into it. It doesn't have to be that expensive. I have a 2 stage setup that is controlled by pressure switches. I have about 400 bux into it, that is including the price of the fuel cell.
Rickyh is offline   Reply With Quote
What non-turbo/ecu mod upgrades exist for more power (STi) XFD Newbies & FAQs 64 09-02-2009 09:13 AM
more power with stock sti turbo... yoonjaechung Newbies & FAQs 22 01-24-2009 01:36 PM
Any ideas for more power? Subleg4 General Community 1 11-16-2002 01:01 PM
What can I do to my engine for more power? 95SubLegacy Legacy Forum 19 09-12-2001 03:00 PM
What is the safest set up for more power with out spending too much $$ Hanzo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2001 01:11 PM
