Old 06-05-2005, 11:29 AM   #1
humdinger4u
Member#: 82905
Default Auto dim rear view mirror 1998 outback,Best place to buy it from?
Where can I buy it at the best price? What all does it do......auto dim and what else? Clock?
Thanks, Michael
humdinger4u is offline   Reply With Quote
Old 06-05-2005, 01:42 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Since AFAIK this wasn't available as a plug-in option on your car and it's not prewired for it, you'll likely be going aftermarket, although it would be possible to install one of the OEM Subaru mirrors- you'd just have to run the wires yourself.
There are two companies that manufacture these mirrors, Gentex and Donnelly. They supply the auto-dim mirrors used for OEM applications as well as aftermarket retailers. Either one can be installed in a Subaru as long as you get the proper "cam lock" type mount. The mirror sold by Subaru is a Donnelly and has a built-in compass display, other versions are available that also have outside temp display and/or map lights.
Check the classifieds on here for used Subaru mirrors, and Ebay for aftermarket ones. Do a search on both "Donnelly" and "Gentex".
Old 06-05-2005, 02:09 PM   #3
palpullero
Member#: 21170
1992 SVX, 2005 STi
Satin Pearl, CGM, 03 Baja
Thanks, Michael
Try subaruparts.com and subaruxtras.com. Wiring is mostly done to the courtesy lights on the Impreza.
palpullero is offline   Reply With Quote
Old 06-05-2005, 02:26 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The wiring consists of switched 12V, ground, and a connection to the reverse light circuit (to undim the mirror when backing up at night). You can't get switched 12V at the courtesy lights, only constant 12V. The reverse connection won't be there unless the car is prewired for the mirror.
Old 06-05-2005, 02:39 PM   #5
palpullero
Member#: 21170
1992 SVX, 2005 STi
Would you say that an '05 STi without the auto-dim mirror option is prewired for the mirror or not? I would like to use my '02 WRX auto-dim mirror on an '05 Sti.
Old 06-05-2005, 02:50 PM   #6
palpullero
Member#: 21170
1992 SVX, 2005 STi
I am assuming the '05 STi is wired like the '02 WRX based on this installation guide:
http://www.subaruparts.com/guides/44...ompass_IxI.pdf
Let me know.
Old 06-05-2005, 03:10 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
AFAIK the 05 would still be prewired and should have the same setup. But I haven't looked at a mirror install on one so I can't say this with 100% certainty.
Old 06-05-2005, 05:26 PM   #8
humdinger4u
Member#: 82905
Do any of these come with a clock as a feature? And thanks for the help too!!
Michael
Old 06-05-2005, 05:31 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Never seen one with a clock, don't think this is available. That's not a good place for a clock anyway, you wouldn't want to have to look up there for the time.
Old 07-24-2009, 12:13 PM   #10
kenbadger
Member#: 209141
2003 WRX wagon
Default Gntx-177
I am in the process of installing a GNTX-177 auto-dim mirror (from a GMC Sierra, ebay $25). Has temp sensor and compass. Only thing I need to find out is where the reverse circuit taps into, for overriding the dim feature when you are in reverse. Anyone know?
kenbadger is offline   Reply With Quote
Auto-dimming rear view mirror wrx6fan Interior & Exterior Modification 23 04-10-2007 11:45 PM
Need to do anything special to add auto-dimming rear view mirror/compass to 06 STi ? FleaDog Interior & Exterior Modification 3 02-19-2006 11:11 PM
Auto dim rear view mirror 1998 outback,Best place to buy it from? humdinger4u Interior & Exterior Modification 1 06-05-2005 04:10 PM
Auto dim rear view mirror 1998 outback,Best place to buy it from? humdinger4u Outback Forum 0 06-05-2005 11:31 AM
compass/auto-dimming rear view mirror for MY00? TSDScooby Interior & Exterior Modification 7 03-23-2001 11:14 PM
