Old 08-20-2009, 01:35 PM   #1
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
Default shifter suddenly feels very "loose"
i'm in the process of breaking in my car after 18 months of everything, including the drivetrain being torn down and reassembled. As i passed the 350 mile mark for the motor, and after about 100 miles driving in dry, hot weather, the shifter suddenly felt EXTREMELY loose for the last 20 yards of my drive. in neutral, the shifter moves side to side with just a gentle touch. it still retains it's rebound affect however. in gear, the shifter feels like it is in neutral (when neutral was normal). still, loose and almost limp. the shifter has remained this way even after a full day of colling off.
does anyone know what would cause this? any help would be GREATLY appreciated, as i would like to be able to drive my car regularly again for the first time in almost 2 years.
DigitalPunk is offline   Reply With Quote
Old 08-20-2009, 01:58 PM   #2
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Are all of the shifter bushings there?
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
Old 08-20-2009, 03:35 PM   #3
DigitalPunk
Member#: 124236
yes, the shifter bushings were installed with the shifter. is there a possibility that they cam loose or off?
Old 08-20-2009, 03:53 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
busted bolt in linkage
busted roll pin
busted rear stay
busted bolt for front stay
Put it up in the air and take a look, and let us know what you find.
Old 08-20-2009, 06:57 PM   #5
DigitalPunk
Member#: 124236
having a look in one hour
Old 08-21-2009, 03:18 PM   #6
DigitalPunk
Member#: 124236
well it turns out the the mechanic who installed my clutch/flywheel did not tighten a few bolts down there. after bringing it to my friends house he found one nut was missing, and two were loose. one of them was cross threaded or just the wrong thread. things are back together now and running well!
Old 08-21-2009, 04:44 PM   #7
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Which bolts? The nut that holds the front shifter stay bushing on? and/or the bolts that hold the rear stay on?
09rexwagon is offline   Reply With Quote
Old 08-21-2009, 05:43 PM   #8
DigitalPunk
Member#: 124236
hmm, not sure about terminology but it was the vertical bolt under the shifter the the horizontal bolt a little bit of a ways down from the vertical one.
Old 08-21-2009, 06:18 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Those would be the trunnion bolts (as in the linkage itself)
Old 08-21-2009, 07:07 PM   #10
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I have had a bolt fall out of the shift linkage, and I had to lower the tranny to fix it properly.
use lock-tite when you replace the bolt
aboothman is offline   Reply With Quote
shifter suddenly very sloppy Jaxx Subaru Conversions 5 06-15-2008 11:25 PM
Car suddenly feels sluggish.. strange.. any thoughts? Twelvesorbetter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 10-10-2006 09:46 PM
Post here if your clutch feels very light (more) S-WRX Transmission (AT/MT) & Driveline 2 10-06-2002 09:43 PM
How are RE730s supposed to feel? 215/45-ZR17 on Prodrive P7 feels very mushy...Luke? Sean Brakes, Steering & Suspension 10 10-01-2001 12:36 PM
Steering feels very light. Ru fan Brakes, Steering & Suspension 4 01-13-2001 12:29 AM
