Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 06-05-2005, 03:50 PM   #1
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Default Dash vent: boost gauge location
I have not decided on which boost gauge yet but I have modified a center vent to accomodate a gauge. I used a volt gauge I had in the garage as a test unit. I put a small hole in the bottom to allow for wiring.
The part number for the left vent is: SP6717 right: SP6716. I used a dremmel and a pair of snips. It is not perfect but I think it will serve as a good location for a boost gauge without interfering with the view of the main cluster.
02_Forester is offline   Reply With Quote
Old 06-05-2005, 08:17 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
not bad, cant wait to see the final product!
fibuz
fibuz is offline   Reply With Quote
Old 06-06-2005, 12:25 AM   #3
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
yea i must admit that is kind of innovative, its not where you would typically see a gauge, its cool be sure to up some pics
~Mike
pilfflip is offline   Reply With Quote
Old 06-06-2005, 10:54 AM   #4
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I got the idea from APR, they offer a vent gauge for the A4/S4 but it completely covers the vent. I'm hoping I can still get some air through this one.
Old 06-06-2005, 03:10 PM   #5
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
you should be able to.
Pretty sweet. Did you have a backing plate for where the u-bracket touches the vent, or did you just position it right?
IronMonkeyL255 is offline   Reply With Quote
Old 06-06-2005, 04:14 PM   #6
Bakergtt
Member#: 59207
'05 X was 98 LGTT
I kinda did the same thing with my a/f gauge but i didnt cut a hole in the actual vent. I pulled the whole vent out and made a plate to replace the vent.
Bakergtt is offline   Reply With Quote
Old 06-06-2005, 09:17 PM   #7
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I haven't sorted a backing plate yet, the gauge is pretty snug as is and I don't think it would go anywhere but I would like to put some sort of u-bracket or a cup style housing for it to sit in; help deflect direct A/C or heat. Once I decide on a a boost gauge I'll see what the options are.
Old 06-20-2005, 11:20 PM   #8
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I switched to the small vent after a good deal on the Subie boost gauge. It is a hair low so I'll adjust things up a little next weekend. But it seems to be working -- that picture is at idle and it goes to about 3 ticks past the .05 mark at full boost.
I need to get a bulb condom to get it closer to the stock light color. I connected to the dash lighting wire & a ground but the light does not adjust with the dash light, is that correct?
FS: AVO Dash Mount Boost Gauge & Pod Kannekt Interior/Dressup/Audio & Security 8 02-21-2007 01:28 AM
In-dash LED boost gauge on WRX / STI ? bani111 Interior & Exterior Modification 18 09-15-2006 11:05 AM
What size gauge will fit the stock boost gauge location? BGPKR Interior & Exterior Modification 7 10-27-2004 01:39 PM
Turbo Boost Gauge Location DaMax Forester Forum 6 02-11-2004 05:38 PM
Integrated In-Dash (Tach) Boost Gauges, Air Fuel Meters and >>> ShokWaveRider General Community 1 02-21-2003 05:38 PM
