Old 06-06-2005, 01:27 AM   #1
zuczek
Member#: 64971
BP05
Default HID retrofit in a MY02
Hi all,
I have an 02 WRX Bugeye. I purchased Hella Bi-Xenon E-Spec HID projectors and shrouds with Hella Ballasts and 4300K Phillips bulbs. I want to retrofit the projectors in the bugeye headlamps. I have an idea how to do it but I figured I will post here to find out if someone had done it already and can give me some tips.
Also, is it recommended to use a harness to bring the power to the ballasts directly from the battery? Or can I simply replace the stock fuse to support the higher current draw at the ballast startup?
Ohh BTW, I'm in Canada. I don't think the cops here are really anal about HID's.
Thanks
zuczek is offline   Reply With Quote
Old 06-06-2005, 06:48 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Depending on the particular ballast you may not need to change the fuse value. You should however directly ground the ballast negatives and not use the low beam switched grounds to power them.
Although you may not have a problem with HIDs up there remember that this will eliminate your DRLs (and you should disconnect the module when installing HIDs) which are required in Canada.
Any one in WI doing HID retrofit? trueno16v MWSOC Private Classifieds 2 07-14-2008 10:18 PM
looking to keep hi and low beams in HID retrofit - possible? aznfoos Electrical & Lighting 8 07-29-2004 04:04 AM
HID retrofit in Subaru hunts Electrical & Lighting 8 04-16-2004 04:18 PM
HID retrofit kit on stock WRX headlights? Sideways Interior & Exterior Modification 2 10-10-2002 05:08 PM
anybody want to help with a HID retrofit on my car? Sideways North West Impreza Club Forum -- NWIC 3 10-10-2002 12:28 PM
